Question about Sanyo SCP-7050 Cellular Phone
My phone accepts my bluetooth headset, and others can hear me when calls are accepted but I can't hear them through my bluetooth, instead it comes through my phone even though it's shut! I can hang up and accept calls, but talking is not an option! I've tried everything.
    Problem Solver:
  • 6 Answers
The earplug of your headset is defective.replace it
Posted on Nov 18, 2009
How to accept the incoming call.
has it been 'paired' with your phone via bluetooth?
Apr 13, 2015 | Jabra Bt2035 Bluetooth Headset...
Plantronics Explorer 320 I can hear but nobody can hear me
ok..try to go your sound settings, maybe the microphone is turned off. OR try to restart your phone just to make that headset is working properly.
Jan 22, 2008 | Plantronics Explorer 320 Wireless Headset
Can not get my Jabra Bluetooth to accept my calls
So here's some info on the bluetooth headset:
http://headsetplus.com/product690/product_info.html
Also, Jabra's tech support is solid. Consider giving them a call if you still can't figure it out. GL!
Oct 14, 2014 | Plantronics Explorer 220 Bluetooth Headset...
Need help to accept calls answering with bluetooth
Not sure if you have provided the correct model. You need to pair the headset with the corresponding mobile phone and then accept the calls.
Refer this table on the link and select the correct Jabra model and the mobile phone model and you will find the correct instructions.
Bluetooth Pairing Guide
Aug 01, 2014 | Jabra Radio Communications
My wife and I have identical Samsung GT S5230 phones. Both will pair with my Kia Ceed bluetooth. The head unit will accept 5 devices but both will not connect with the unit at the same time meaning we...
the issue with Bluetooth connections is that with two headsets and two phones, you have to have your firmware set up to handle ONLY ONE set per phone. This means that if you set it to ONLY accept YOUR headset on your phone, it should work regardless of any other Bluetooth capable devices in range. If there are two possible devices in range and the phone is set to accept either one, it does not know where to send the signal -- and as a security feature, it turns the Bluetooth off so in a crowd no one can use your phone, or listen in on your conversations.
Setting your Bluetooth to accept only one device (being your headset) should allow you to work in the car next to your wife, but will also limit you on which headset you can use -- if you accidentally grab your wife's headset as you are out the door on your way to work, it will not function until you open the channel again. I am not even sure if every Bluetooth capable phone has a function to limit their connectivity, but if this issue is bothering you a lot it might be worth a look in your Bluetooth settings).
Just as a test, and because it sparked my curiosity, I recommend trying this:
Be out of range for your wife's headset and make a phone call on your headset to someone who is willing to hold on the line while you do this. Then, while you are connected with your Bluetooth to your friend, sit in your car with your wife and her phone and Bluetooth. The connection to the headset on your phone should be locked in place from the beginning of the phone call, and so it should not cut out when your wife's Bluetooth headset comes into range of your phone. While this conversation with your friend is still going on on your headset, have your wife make a call on her headset if she can. Because there is only one Bluetooth device available (since yours is in use) she should be able to make the connection with her phone, in spite of it being in proximity to yours. Finally ... hang up your phone, and have your wife do the same. With both phones inactive, try placing a call from the Bluetooth on one of the phones -- the system may set your headset as the default device for your phone, and your wife's would do the same, and the issue should be rectified.
I make no guarantees that this will work ... I am not all that familiar with the complexities of the Bluetooth wireless system and whether or not you can set the system this way, but it is worth a shot. The system may be designed to prevent this type of back door approach, but it would seem reasonable that it could work. Best of luck to you!
May 26, 2011 | Car Audio & Video
I have a bluetooth headset mounted in my motorcycle helmet and I can make a bluetooth connection between it and my nokia 6727 but now I got another Nokia 3727 and when I try to pair it with my helmet - I...
It is very posible that it is not connecting, reason being: compatibility. U should get a bluetooth headset that is compatible to both ur phones n pair it, that should solve ur problem. For example I can use any of BH320, BH200, BH600 on my Nokia 6120c n other bluetooth headsets I tried wont b accepted. U can try them n c. Good luck.
May 05, 2011 | Nokia 6120 classic Cellular Phone
I am trying to pair a Blackberry 8900 to the HS830 Bluetooth device. I know the passcode is 0000. But the Blackberrry is not detecting the HS830 at all. It detects other Bluetooth items, but not this one....
Put the headset in PAIRING mode, if it has been paired with another phone, it will not accept a new pairing or another phone until you put it in pairing mode again. Press the button until the LED gets steadily ON, search the headset and pair it with the new phone. It only accepts one paired phone at a time.
Nov 04, 2009 | Motorola Mobility HS850 Consumer Headset
Want to conect BH-102 to Nokia E75
1. Switch on blue tooth on phone, and then on device with pressing 'call accept' button on the bluetooth device till the light glows on the device.
2. if any other mobile is paired with the headset, press and hold the 'call accept' button and the 'volume up' button, to unpair all connections. and the headset confirms with continuous glowing of light.
3. Search for the headset from your E75, when found, click on it to pair. When prompted for password, give 0000 as this will be the default password for every bluetooth headset. It will connect in a matter of 10 seconds, and the phone asks 'whether to make the connection authorized' press YES.
There you go. You can use the headset for calls and also to listen music.
Aug 10, 2009 | Cell Phones
Wireless bluetooth headset
  • press the answer button at the side of the headset
Sep 17, 2007 | Samsung SGH-D900 Cellular Phone
My bluetooth
Sorry I post the wrong link before, for plantronics manual it is: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Jul 31, 2007 | Plantronics Explorer 320 Wireless Headset
Sanyo SCP-7050 Cellular Phone Logo
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
rey francis basa
rey francis basa
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
