Question about Microsoft Xbox 360 Console
My xbox well not connect to the network - Microsoft Xbox 360 Console
    Problem Solver:
  • 6 Answers
How are you trying to connect? Most times you need to allow your pc or router to recognize your xbox into the network?
Posted on Nov 19, 2009
Cant connect to xbox live
What you need:A high-speed Internet connection such as cable A router, gateway, or wireless access point (WAP) that is compatible with Xbox LIVE. An Xbox 360 Wireless Networking Adapter (original Xbox 360 console only) Instructions: On your console, go to My Xbox, and then select System Settings. Select Network Settings. Select the name of your wireless network. Enter your wireless network password. Select Yes if you are prompted to update your console software. When you successfully connect to Xbox LIVE, your screen will look like this:
Jul 25, 2011 | Microsoft Wireless Network Adapter Xbox...
Tip
How to connect your Xbox 360 to the internet
In this guide I will go over how to connect your Xbox 360 to the internet either via wired or wireless connection.
Wireless Connection
*For a wireless connection you need a wireless access point(router) and either a Xbox with built in wifi adapter or purchase a xbox wireless adapter*
-Turn on your xbox and go to "My Xbox" then go to "System Settings"
-Select "Network Settings"
-Select the name of your wireless network.
If you do not see your network, select "Advanced options" then select "Specify unlisted Network" then enter your network name.
Enter your wireless network security key. It may prompt you to update your console, select yes.
Wired Connection
*For a wired connection you need to use an Ethernet cable and plug one end into the back of your xbox and the other end into your router or cable modem.*
-Select "Test Xbox Live Connection", afterwards it may prompt you to update your console, select yes.
Now, you are connected to the internet and can enjoy xbox live.
Regards,
G33k
on May 12, 2011 | Microsoft Xbox 360 Console
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
How do i hook my mi-fi internet to the xbox 360? i have purchased an adapter and can not figure out how to get the internet working
Here's how to configure your wireless settings:
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. If you are prompted to select a wireless network, complete these steps, otherwise skip to step 4.
    1. Select the name of your wireless network.
    2. Enter your wireless network password and select Done.
    3. The console will automatically try connecting to Xbox LIVE. If you get an error message, go to the following webpage for help: support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx (http://support.xbox.com/pages/xbox-live/troubleshoot/connection-issues/connect-xbox-live.aspx)
    Note If you do not see the name of your wireless network, select Advanced Options. Then select Specify Unlisted Network and enter your wireless network name. Select your wireless security type (WEP, WPA, WPA, or No Security). This security type needs to match the security of your wireless network.
  4. Select Configure Network.
  5. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article: 977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  6. Select Scan for Networks.
  7. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article: 909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  8. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  9. Press B on your controller, and then select Test Xbox LIVE Connection.
Mar 07, 2011 | Microsoft Xbox 360 Console
Xbox 360 wireless adapter doesnt work the light on the back just stays red and i dont get how to make it work
Hi. You just need to configure your adapter. It is not broken, it just needs to be set up properly. For information on how to do this, please see: http://support.microsoft.com/kb/908877
Feb 28, 2011 | Microsoft Wireless Network Adapter Xbox...
Tip
How to set up WiFi on XBOX
To connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
On the Xbox 360, use the "Test Xbox Live Connection" option instead. Tips: Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
on Feb 07, 2010 | Video Game Consoles & Games
Im programing my x box 360 it needs me to program the wpa net work to get this new x bow to work. im new at this expain things very clear , thanks
Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network. These instructions assume the wireless router is already installed with a working Internet connection. If after following these instructions you are unable to network your Xbox with the wireless router, see - Connecting Xbox to Wireless Networks - Why Things Go Wrong
Here's How:
  1. Connect the appropriate wireless network adapter to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet port (sometimes also called a wireless network bridge) must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi game adapters that connect to a USB port.
  2. Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -> Network Settings -> Advanced -> Wireless -> Settings" On the Xbox 360, the menu path is "System -> Network Settings -> Edit Settings."
  3. Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.
  4. Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)
  5. Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard Microsoft Xbox 360 Wireless Network Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.
  6. Save your settings and verify the network is functional.
Tips:
  1. Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.
Feb 27, 2011 | Computers & Internet
How to hookup wireless internet
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
I am trying to set up xbox live for my son but when i try to go live on the xbox dashboard it says that wireless network not connected but i have a wireless network running in my house and need to know how...
Tips:
What You Need:
  • Active Xbox Live subscription (to access services)
Source: About.com
Sep 29, 2008 | Computers & Internet
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
