Question about Philips SA3125\02 MP3 Player
Battery not charging
The battery starts to charge then the 3 lights on the display flash and the battery shows full. The reality- when unplugged from the USB is that its empty. Tried resetting. Tried different USB ports and different PCs- to no avail.
If you know a solution please let me know.
My main PC is an AMD K6-2 450 with 256mb ram, Win XP home edition.
    President:
  • 4,402 Answers
Try a new battery
Posted on Jan 10, 2008
6ya staff
SOURCE:
Power portastudio
Gel cell batteries usually are good for 3 to 5 years and from your description, it sounds like the battery is not recharging properly. They will indicate a full charge but in reality, do not have the stored power to operate the device. Check for replacement batteries at your local burgular alarm shop or buy online BUT make sure to match the voltage and AH (amp hours) ratings.
May 09, 2014 | Anchor Audio PB-2500 Battery powered sound...
Fast flashing green light when trying to charge
usually fast flashing charge is faulty battery its trying to get volts in to the battery. you see the battery has a charging board on the battery not in the camera the camera sends the volts to the battery and the battery tells the camera its voltage, and when at the right volts stops charging. but these batteries can only be charged to around 10000hrs depending on the type of battery. you see when you get a new battery you need to charge it before use, now this can be 6hrs to 12hrs for fist time use if you interrupted the charge or have a power cut while it charges it can damage the charging chip in the battery. if this does the flashing light on other batteries then the signal is not being read by the camera and the camera can be faulty on the charging circuit, usually (sometimes) removing the battery for a few hours can fix this but it will rest the camera. hope this helps you.
Mar 24, 2014 | Nikon Coolpix S6300 Hd Digital Camera
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
Mar 17, 2013 | Health & Beauty
My Sony Vaio battery light remains orange
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all.
OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time.
If the battery drops to an unacceptable charge level then the battery needs to be replaced.
May 26, 2010 | Sony VAIO Notebook
Dell laptop battery has 3 lights flashing when hit battery tester
You can't get the modern batteries to come back to life. Time to get a new one.
A suggestion: When using a laptop battery, run it on battery and discharge it until it shows about 2 to 3% charge left at least once a month. Do not keep charging it without letting it run down periodically. Most important--do not run always plugged in to line current.
Sep 09, 2009 | Dell Latitude D810 PC Notebook
Toshiba satellite A210 11-P crashes when i disconnect the power lead
From Toshiba, try step-charging the battery or Battery conditioning procedures:
Batteries don't last forever. All types of batteries gradually lose their ability to hold an electrical charge as they age. Eventually, the computer's battery charge indicator may show that the battery contains less than a full charge, even though the battery has just been fully charged. The computer will then not run for as long a time from the battery as when the battery was brand new.
You may prefer to simply replace the battery if this happens, but you may also wish to try 'step-charging' the existing battery per the following instructions.
This procedure should work for the battery in any Toshiba notebook. Follow it only when you find that the computer will run from the battery for just a short while.
Check the User's Guide for more specific information about charging the battery in your computer .
Procedure
Step-charging the computer's battery
  1. Unplug the AC adapter from the computer, and turn ithe computer on. Let the computer run from battery power until the computer turns off, indicating that the battery is fully discharged. Time this interval, but not with a software clock running on the same computer.
  2. Remove the battery pack from the computer.
  3. Unplug the AC adapter from the computer.
  4. Wait at least 30 seconds. The first time through this procedure, use a soft cloth to wipe the battery pack's contacts and the AC adapter's plug.
  5. Re-insert the battery pack.
  6. Plug into the AC adapter into the computer again and check the fit of its plug in the wall outlet, making sure the connection is secure.
  7. With the computer turned off, let the battery charge until the battery status light or icon glows green, or otherwise indicates a full charge.
  8. Unplug the AC adapter from the computer.
  9. Remove the battery.
  10. Wait at least 30 seconds, then re-insert the battery.
  11. Plug the AC adapter back into the computer.
  12. Let the battery charge again until the battery status light turns green or otherwise indicates a full charge, again.
Repeat this procedure, starting from step 1, at least three times. Each time, check to see if the computer runs longer from its battery than the previous time.
Battery Conditioning:
IMPORTANT!!
Interruptions in the charging cycle can be responsible for an issue called "memory effect" which may reduce the battery's charging capacity. Whenever you suspect the battery performance is not at it's optimum you should try using the following "Battery Conditioning" procedure.
Before you start: Turn off your battery saving features temporarily.
***IMPORTANT*** Repeat the following steps 2-3 times!
  1. Unplug the power cord from the computer
  2. Turn the computer on and let it run until it shuts itself off.
    Note: Using the CD-ROM to play an Audio CD will speed the discharge.
  3. Plug in the power cord (While the system is off) charge the battery until the battery light changes from flashing green to solid green
  4. Remove the battery for 30 seconds and then replace it.
    Note: If the battery light isn't lit, wait a few moments, if it still does not light check your power connections.
  5. Continue charging the battery until the battery light turns solid green once again.
    **REPEAT THIS PROCEDURE 3 TIMES**
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 04, 2008 | Computers & Internet
Flashing amber battery light
Sure, this just mean your are in charging mode, but your battery is at full charge. Should your battery need charging and in charging mode the lights would be green most likely.
Regards,
Worldvet
Please don't forget to rate our solutions as fixed if we answered your questions or fixed your problem.
Jul 13, 2008 | Dell Inspiron 2200 Notebook
Philips SA3125\02 MP3 Player Logo
46 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
