Question about Linksys Wireless-G WRT54G Router
Where do i find the ssidon my linksys router?
  • 591 Answers
The SSID (network name) is what you have named your network. To set the SSID, log in to the router and go to the Wireless section. Here you will find the SSID area, and you can name your network pretty much any thing you want. Logging in to the router usually involves going to http://192.168.1.1 and supplying the correct login information.
Posted on Nov 18, 2009
Coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
What is ssid connect laptop to pc.laptop to be used in family room laptop is toshiba c650
the ssid is the name of the router that you are trying to connect to. the name can also be changed to whatever the end what the name to be as well in the router. so if your linksys router uses the default name then the ssid would be "linksys" or "link".
Aug 25, 2011 | Linksys Cable/DSL 802.11n Security Rtr...
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
I pushed the reset button on my router and now I have no protection from others with my wireless, how can i protect that?
admin user: blank
admin pws: admin
ssid: linksys
wep : none
to setup wireless
May 04, 2010 | Linksys Wireless-G Broadband Router
I formatted my hard drive and can't connect wirelessly.
If you've lost your ssid, then the best way to connect is to reset the router. That linksys router has a reset button on the back of it. Hold in for about 10 seconds, and it will reset it back to the factory defaults. Then login to it and reset your ssid.
Good Luck
Mark
Mar 20, 2010 | HP Pavilion dv5120us Notebook
My WRT300N Linksys router shows all lights, I've hit the reset button onece, but I can not get online without plugging the cable directly into my computer.
Since you hit the reset button on the router, it will go back to default settings.
By default, the SSID is linksys and the wireless security is disabled.
So on the wireless network connections on your computer, you should see linksys and then just connect to it.
However, it is advisable to change the default SSID and to enable the wireless security.
Follow this link to change the SSID.
Follow this link to enable wireless security.
Dec 30, 2009 | Linksys WRT300N Wireless Router
I just wanna know how to hide my ssid
Login into the Linksys router, in the wireless settings for the SSID there is a box to tick Stop SSID broadcast, save the setting and exit.
Dec 08, 2009 | Linksys Wireless-G Broadband Router
Trying to use belkin router with linksys adapter cards..do i need new drivers
You need to configure the Belkin router with a SSID and WAP or WEP encryption, Then install the Linksys adapter driver in the computer and then configure the Linksys adapter with the Belkin router settings (ie. the SSID and encryption) before the Linksys can communicate eith the Belkin router.
Aug 02, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
No conncections
SSID is the network name for your routers network. If you use a linksys router, then the default SSID is Linksys (don't know what it is for others, but would be easy to find out from their website, and the manual for the router.).
SSID's should always be changed, and secruity encryption enabled, when yu set up a wireless network.
Jan 26, 2009 | NetGear WGR614 Wireless Router
Linksys wireless G range expander
Hi David,
I need to know that what type of router u r using.
If it is Linksys router just follow these steps,
with the help of the Ethernet cable connect the range expander to any one of the 4 ports in the router...
ur computer shuld be directly hook up to the router..
open internet explorer in ur computer..in the address bar type in 192.168.1.240(ip address of the range expander)
it will prompt for a username and password...leave the user name blank and the password will be admin.
u can see the linksys range expander set up page...
u can find SSID at the bottom of the page...
ur router's SSID and the range expander's SSID should be same..and also the password should be same..
If the ssid or password mismatch between the router and range expander u can find these kind of Error messages...
Good Luck....try it and revert back
Jul 03, 2008 | Linksys Wireless-G Broadband Router
Linksys Wireless-G WRT54G Router Logo
758 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
