Question about Honeywell Programmable Thermostat Heater
Filter sign is showing how do we change the filter
    Habit-Forming:
  • 47 Answers
Are you saying that the filter indicator on the thermostat screen is flashing filter? If so this feature is built into the thermostat as a reminder. It can be set for 30, 60, 90 days to remind you. It also can be turned off. Of course the air filter is in the cold air return, or blower compartment of your furnace.
Posted on Nov 21, 2009
New mechanic reccomended transmission flush and service. is this good advice?
for automatic transmissions where the oil is not fresh but shows signs of burning ( burnt smell) , the transmission shows signs of sluggish changing the a flush would be recommended
There are 2 methods that can be used
the first is a cheap method where the pan is removed and the oil taken out and the filter cleaned
While the pan is off , the clutch packs and bands can be adjusted
The more costly method but a far better choice is to flush the transmission while the engine is running
Oil is sucked in from a fresh drum and delivered to a waste drum. this changes all the oil in the transmission and torque converter where as the first method leaves dirty oil in the torque converter
The second method does not require the pan removal so adjustments are not done and the filter is not cleaned
While the advice to change the oil is good you have to decide which method you want to use
I suggest a discussion of the merits of both with an accredited transmission shop and get quotes.
Jun 09, 2015 | Cars & Trucks
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
My Honda Pilot is showing a maintenance sign on the dashboard and also 10% oillife. what do these mean?
It is time to change your oil and filters, including the fuel and air filters.
Feb 17, 2011 | 2006 Honda Pilot
2004 mdl durango hemni5.7 i pass by in water level around the 3/4 of the wheel sign trottle comes out and engine check i park the car and i try to start no accelerator or no power until my battery was...
First..-DO THIS NOW - Change the oil and filter, change the transmission fluid and filter.. grease ALL the fitting you can find... make sure both battery cables show NO signs of corrosion..(they WILL corrode from the inside and not show on the outside!!).. clean all terminals and clean the battery terminals... a little grease on these prevents corrosion...
Jun 27, 2017 | Dodge Durango Cars & Trucks
Changing fuel filter and transmission fluid on a 1990 gran prix
just follow the fuel line and you will find the fuel filter ,but if its running ok then just check the fuel lines for deterioration and leave well alone ,the fuel pumps at the garage have filters in them so you shouldnt need to change the filter unless the metal casing is rusting,as for the transmission again if it works ok then do not disturb as its only hydraulic oil and it doesnt get dirty like engine oil but if your gearbox is showing signs of bad changes and you can see bits of worn brake band in it then change the vehicle as even if you change the oil it will pack up with or without a oil change.
Jul 15, 2010 | 1990 Pontiac Grand Prix
I have a White-Rodgers Thermostat and it has the word (Filter) on the left side and a (Flame) showing on the right hand side, I'm not sure why we changed the filter two months ago. Does anyone know what...
Flame Icon is displayed when the SYSTEM switch is in HEAT position. Display "FLTR" when the system has run for the programmed filter time period as a reminder to change or clean your filter.
You can reset the counter by going inside the configuration table of the thermostat. If you need further clarification call our WR hometechline 18002842925.
Mar 07, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I cannon print the @ sign from my acer keyboard
If the @ symbol does not show up, but the " shows up instead, then there is a language change on the keyboard. It can be remedied by going to the control panel and changing the location and keyboard settings fromEnglish-United KINGDOM" to English-United States. Also check the procedure below and make sure this is done.
Go to control panel, click on accessibility options..in the keyboard tab, click on the settings buttons for sticky keys, filter keys and toggle keys and deselect the option to use shortcut..hopefully this will help you and other people that have had this problem.
Mar 05, 2010 | Acer 2581168-0001 Keyboard
Air conditionair will not start thermostat has flashing filter sign
The flashing filter sign has nothing to do with the a/c not running. Have you checked the breakers for the a/c. Is the indoor blower running? Would need more info to further diagnose. The flashing filter sign is only a indicator set by internal timer in the stat. You should change your filter every 30 days unless your using an aircleaner that says its okay to go longer. if you have the brand and part # of the stat i coud get you a manual so you can learn how to reset your filter change indicator
Aug 27, 2009 | Honeywell Electronic Programmable...
A13 sign the dash
The 15% is a warning the oil change is near, The "A" means change oil only ("B" would mean change oil and filter) The 1 means to rotate the tires, The 3 means to change the trans fluid. The owner's manual has the complete chart.
Apr 28, 2009 | 2005 Honda Odyssey
Peugeot 307 hdi 110 dash show sign saying fuel filter blocked if i change filter will it still show on dash
ı have a peugeot307 in 80300km I DON'T KNOW exactly when take it to care ,brake.steering wheel,gearshift hydraulic,trigger set etc when will they change in what kilometers Can you help me? Thank you already
Aug 05, 2008 | Peugeot 405 Cars & Trucks
Heating & Cooling Logo
468 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
