Question about Mitsubishi WS-55513 55" Rear Projection HDTV
Ws55513 blinking green light. have tried unplugging for 5 - 10 mins and reset all without effect. Can you help>
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
THIS IS MY STANDARD ANSWER TO THIS QUESTION==SOMETIMES PEOPLE DO NOT TRY THE EASY POSSIBLE REASON--IF YOU HAVE ANY QUESTIONS LET ME KNOW---
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 18, 2009
  • booniesman88
    booniesman88 Nov 27, 2010
    I had a similar problem a two years ago i replaced the cheap caps with better ones and it worked fine. Now i am getting a code 21 ,no picture, no sound, just a click after the dm boots and the led goes out
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
Is there a reset button on a Sanyo 2011 flat screen
most likely depends on the model.
and what are you trying to 'reset'
unplug it for a few min and plug back in
find menu scroll through settings until you find factory reset or something to that effect.
if doesn't reset after unplugging few min leave unplugged over night or as long as possible before using ... most devices reset after a few hours without power
call customer service.
Nov 10, 2016 | Sanyo Televison & Video
Need instructions of 55"t.v model ws55513 d m board with capacitors
  • Try going To http;/www.techlore.com/24711/Mitsubishi-Blinking-green-light-repair-procedure.... It Suppose Load up about Nine Pages of Stuff on how to fix the (DM Module Board) If you Can't Fine The 1000 uf 35 wvdc Operating temperature 105 C: Electrolytic capacitor Try The Radio Shack one It Rated At 40 To+ 85 C It Will Work If You Can 'Fine The Other one !05 Deg. C Type -----Check Out This One Too 78 Pages (http://www.techlore.com/x/article/24711/Mitsubishi-Blinking -Green-Light-Repair-Procedures.(Ps) It Want Hurt To check The Ones In the power supply area,other Area .Too You might Have Change them All If You Have All The 1000 uf Check If they Showing Under Less Then The are Rated at Then It Want Hurt To Them All
May 27, 2014 | Mitsubishi WS-55513 55" Rear Projection...
The tv wont power on and the green timer light continuously blinks. I have unplugged the the tv and also hit the reset button.
...OK to begin troubleshooting this. Unplug the set and leave for 1 min then plug up and leave for 2 min push the power button and let light blink for 2 min.... now push and hold at the same time the MENU and DEVICE buton st the same time. this is the self diagnoses feature ... the lights should link then pause then blink again... this 2 digit code will help narrow it down. Also have you check the lamp yet?
Oct 22, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Ws55513... blinking light
No...but you may not have replaced all of them (there are 8 total in a "repair kit")
Jul 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Jun 04, 2009 | Canon I990 InkJet Photo Printer
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WS55513 tv
capacitor problem.
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
Dec 14, 2007 | Televison & Video
Green Blinking Timer Light Mitsubishi WD-62527
hold the menu bottun for 10 seconds
after press power
see if that works
Sep 22, 2007 | Mitsubishi WD62527 62 in. LCD HDTV
Mitsubishi WS-55513 55" Rear Projection HDTV Logo
287 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
