Question about Sony KP-46WT510 46" Rear Projection HDTV
My sony KP-46WT510 the color in three corners is blured and the picture is bowed.
  • 336 Answers
Hi,it seems you are experimenting a light engine problem.This is how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo So basically the 3 Lcd chips that create the colors and image is going bad and thats why you get that color discoloration.Contact Sony or look for your light engine online.God bless you and your house!
Posted on Nov 18, 2009
My sony tv model # KP-46WT510 the picture bows to the middle i tried fixing the convergence and it does nothing what else should i try
If the convergence feature did not fix the issue then you will need to install a convergence repair kit. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com and includes the parts and the CD with instructions.
Aug 28, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
I have a kp-46wt510 and the picture is messed up. The colors are not matching up and the picthture squeezes in in the middle. What can I do to fix it?
You need to replace the two stk392-560 IC's located on the D Board. They are hidden behind two very large finned heatsinks. Recommended procedure would be to replace both IC's, along with pico fuse and be sure to apply thermal paste to stk IC's when mounting to heatsinks. Here is link to purchase all three items:
http://www.electronic-repair-kits.com/STK392-560.htm
Jan 17, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Tv sony 46 inch colored blurry..and picture is bowed
This problem is due to failure of two convergence out ICs in TV that will be replaced to get correct picture.
If you can solder parts in circuit board and have necessary tools to do so, let me know exact model of TV to provide you more technical info or call local TV tech to replace convergence out chips.
Thanks.
Oct 29, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Sony 46 inch proj tv picture is bowed in the middle and color is
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sony projection tv convergence problem
You need to replace the convergance IC's and a pico fuse on the power supply
Sep 03, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Colors have separated. and top and bottom af pictures are bowed. i have a sony kp-46s55. its about nini years old and it was free. currently the colors are separated and the top and bottom of the pict
nbad convergence ic , this need to be done by a profecional tv tech , because need to check for the pico fuse and resistor around the area
May 08, 2009 | Televison & Video
My sony wide screen projection model kp-46wt510 has a red shadow
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when when using the convergence menu.
Screen is bowed in but stationary.
Solution:
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kit for your exact model. The kit inlcludes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself. Its an easy fix.
Jan 20, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Picture looks curved (concave curve) on my sony KP-46WT510
You may have a convergence problem. Here are some of the most common symptoms and example photos.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
May 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Common problem?
You have a convergence issue and it is most likely fixed with the replacement of your convergence amps. Replacement should run around $200.00 or so depending on labor costs in your area
May 09, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-46WT510 46" Rear Projection HDTV Logo
142 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
