Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
I have a dishwasher when i put the detergent in it, the detergent doesn't dissolve while its washing. i often have to rewash the dishes, and it still doesn't dissolve.
  • 375 Answers
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
My dishwasher doesn't seem to be washing the
Hello
Water Inlet Valve
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Upper or Lower Spray Arm
Your dishwasher has a lower spray arm. It may also have an upper spray arm at the top of the dishwasher. These spray arms are designed to shoot high pressure, high temperature water at your dishes. It is possible that the holes of the spray arms, where the water comes out, are blocked with debris, affecting wash quality. You should inspect your dishwasher's spray arms regularly. Clean out the spray arms as need be.
Heating Element
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
Filter/Drain Grate
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishw ashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher. Consult your owner's manual for specific directions for removing your dishwasher's filter and cleaning it.
Detergent or Detergent Cup
It could just be that you aren't using enough soap to completely wash your dishes. Your dishwasher may be designed to dispense soap at two different times during the wash cycle. If you don't fill all of the detergent cups, then the diswasher will lose a cleaning cycle. Also, if you use a gel-type detergent, try switching to a powered kind. Powders tend to dissolve better in hot water. And don't buy in bulk. Detergents are most effective in the first two weeks. After that, they decrease in potency.
Alternatively, your dishwasher's detergent cup could be defective in some way. It is possible that it is gunked up full of built up detergent, and a thorough cleaning may be enough to get it working again. If that doesn't do the trick, you probably need to replace the entire detergent cup assembly. If your cup isn't even opening, please see our section My dishwasher detergent cup won't open.
Aug 09, 2011 | Viking 24 in. Professional Series VUD040...
The soap does dot dissolve
assuming you are using the correct dishwasher detergent type and quantity recommended for the dishwasher, the likely cause for detergent not dissolving is that the water is not circulating well enough through the wash arm. Check the wash arms are clean. Do dishes come out clean? Run the dishwasher with a cup correct side up on the top rack. If it is empty at end of wash then there is no water in the top arm.
Is the detergent dispenser door open during wash cycle?
Also lack of adequate wash water template can cause detergent to remain undesolved. Hope this helps.
Feb 15, 2011 | Asko D1796FI Built-in Dishwasher
Some of the dishes are not getting clean, and the detergent packet is not disolving.
Be sure you're not blocking the detergent dispenser with dishes or pots & pans. If blocked, it won't open and the detergent will not dissolve. Put smaller items closer to the dispenser.
Jan 19, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Soap not dissolving in dishwasher. stays in compartment
Hi, dishwasher detergent stays in the compartment because Bosch has designed a gap at the top of the compartment that feeds water onto the detergent before the cover opens. This has possibly been done to soften up deteregent tablets and help them dissolve.
The result is a solidified mass of wet detergent that doesn't come out of the compartment when it opens, and slowly dissolves onto the dishes leaving them coated with alkaline detergent at the end of the cycle. The residual lump of detergent is in the compartment or on the bottom of the dishwasher (refer photo).
The solution is to remove the compartment cover and look for the small gap at the top of the compartment as in the photos. Clean the surface and fill the gap with epoxy glue. This will keep the detergent dry until the cover opens, allowing the detergent to fall freely out of the compartment._1583.jpg
Jun 23, 2010 | Dishwashers
D/w doesn't dissolve deterg. & therefore not washing dishes
Do this test:
-Upgrade to a name brand detergent like Cascade or Electrosol.
-Do not over fill the dispenser cup
-Do not place large items near the door/near the dispenser cup.
-Make certain that both spray arms can spin freely after you load the dishwasher but before you close the door to begin the wash.
Please report back what you find, OK?
May 20, 2010 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore Elite dishwasher will not dissolve soap or wash well.
Temperature should be 140F. and the units heater should energize during fill to achieve this.
May 19, 2010 | Kenmore 24 in. 15173 Stainless Steel...
Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Jul 31, 2009 | Electrolux Dishwashers
Hotpoint dwt 10 dishwasher - the dishwasher tablet is not dissolving and remains in the bottom of the dishwasher after running a load therefore dishes arent cleaned!
I know it sounds strange, but many times when detergent dissolve, a failed heating element is to blame. The detergent needs that water to be hot to dissolve and activate the detergent.
Recommend you check the heating element for obvious damage/failure. When you run the full cycle, does the heating element get hot? If not, replacing it is not as hard as it appears. Post back here with further questions, OK?
If the heating element _is_ working, the other possibility is a failing wash pump motor, but depending on the age of your dishwasher, replacing
May 03, 2009 | Dishwashers
RESIDUE ON DISHES-NOT CLEANING WELL-DETERGENT NOT DISSOLVING-LONG CYCLES
The first thing to check with any of the newer dishwashers is the water temprature coming into the machine and the amount of water coming in. Since you are having trouble with the detergent dissolving, I expect the water is not hot enough. Many of the detergents require 140 degrees f to dissolve properly.
The incoming water should be 120 degrees minimum, then the dishwasher will heat it up some more. The cooler the water, the longer the cycle will take. It won't advance to the next step until the water reaches a certain temp, depending on the cycle selected and the model of dishwasher.
If the dishwasher has to heat the water too much, it will cause the heat element to fail prematurely.
If your water heater is set to the average 130-135 setting, then you may be able to solve your problem by running the hot water at the sink before turning the dishwasher on. This will get the cold water flushed from the pipes so the washer fills with hot water on the first fill.
Also. start the washer in a cycle, let it fill and start washing. Open the door and see how much water is in the tub. It should come up to the bottom of the heating element.
Post back and let me know what you find out.
Oct 22, 2007 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
295 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
