Question about Samson G-TRACK USB RECORDING MICROPHONE Microphone
Samson G-track Hi I just bought this microphone and a got a lil problem first of all i can only record on the leftside so it aint stereo I got the mic volume sett but if i record it doesnt even show peaks and the volume is very low can anyone help me? Im using acid pro 6.0 to record
  • Anonymous Apr 10, 2008
    I'm getting a similar problem. I've tried recording through both KRISTAL and Sonar LE (that came with it), in both the recording volume is very low, and won't pick anything up unless the MIc volume is turned almost up full. In both cases then i will get feedback in the recording from the mic. Is this a problem with the mic or my setup?
  • toffees49 Jun 04, 2008
    I also have the same problem. I CAN'T get the recording volume any higher than the terribly low volume its currently at. I've been in to the sound and audio devices tab and while there is an option for changing playback volume, there is none for recording volume. It's becoming a pain.
Well here's the solution that worked for me. go into control panel and change the input recording device as the samson c01u then press the volume button then readjust the volume =D although the play back i'm still tryign to figure that out
Posted on Jul 22, 2008
It's supposed to only record on the left side. When it's in "INST/MIC" mode the left channel has your mic on it and the right channel has your instrument, so you can mix them separately. Just configure your recording software to put the left channel on one track and the right channel on another track.
Posted on Mar 28, 2008
Can a Samson g track mic be used with the new iPad?
Yes, but the iPad doesn't supply enough power for the G Track to run headphones, so you will need to use a powered hub between the mic and the iPad.
Jun 26, 2012 | Samson G-TRACK USB RECORDING MICROPHONE...
Hi i have connected the Samson G-track with my macbook. also i using Nicecast & Traktor for radio broadcasting. when i talk from Samson G Track my voice comes only from left speaker. I try the...
This is because the G Track's Mic signal is on the Left channel and the Instrument signal is on the Right channel. You are making a stereo recording when you should be making 2 mono recordings. Does Nicecast have an option to set the track to mono Left channel? Traktor should, but I haven't used it so I can't tell you where the option is. There's probably a Track Input drop-down or something like that.
Sep 12, 2011 | Samson G-TRACK USB RECORDING MICROPHONE...
I am having problems recording with my new Samson G-Track Mic on my Macbook Pro. I use Premiere Pro for voice overs (to do the initial recorder) and Soundbooth to clean it up. I've noticed that my voice...
Start here
http://www.samsontech.com/products/productpage.cfm?prodID=1917
scroll down to set up vid, follow the instructions, if it still does not work then call dealer or maker support line.
Hope this helps
Thanks for using FixYa
Aug 18, 2010 | Samson G-TRACK USB RECORDING MICROPHONE...
The mic does not record stereo anymore. when playing back a stereo works fine but when recording in stereomodus only the left channel records, the right channel seems to record silence/noise
This Mic is not a stereo Mic. If you're using a windows computer, check your sound control panel to see if the mic wasn't suddenly set to two channel device.
Sep 30, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson G Track USB Mic
To get sound in both channels in Garageband for a podcast using the G-Track Microphone:    select a voice track to record into    make sure the Track Info window is open (blue i button in lower right region of screen)    at the bottom of the Track Info window you will find Input Source:    Change the default setting of Stereo to Mono 1 (USB Audio CODEC)
This assumes you have gone to Garageband preferences and changed the Audio/Midi settings for audio input to USB Audio CODEC which appears when you plug in the G-Track Mike
Apr 08, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Many Problems with Samson G-Track or not?
Hi.  I dunno if yur using pc or mac but with a mac yu need to adjust the mic settings on the comp. For the static its probably your set up or as i said in another guys problem, the usb cable given with it is **** so try using another one from a printer or wtv to see if that makes a difference for you. Also if you are recording just through the mic i find that it seems to only work well when the input is on line and not inst/mic. Hope this can be of some help. Its a great piece of kit once you get it working well.. Goodluck
Jan 16, 2009 | Samson G-TRACK USB RECORDING MICROPHONE...
Samson co1u recording issue
you first 3 people are idiots... maybe if you had worked with the hardware you would know how the mic works because its obvious you don't. The 4th person is correct because this is exactly how i use the mic and it captures sound in stereo format beautiful when set up rite. Using it in mono, whether use keep on one channel or two drastically reduces the crisp sound that this mic can record.
Mar 18, 2008 | Samson C01U - USB Studio Condenser...
Help
need pre amp with it boost ya and to get it in sterio way should be are u running it direct in usb port and u have usb 2.0 outlets corect
Jan 10, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Samson G-TRACK USB RECORDING MICROPHONE Microphone Logo
880 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
PBandJ
PBandJ
Level 1 Expert
 Grubhead
Grubhead
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
