Question about Toshiba Satellite L25-S119 Notebook
I tried to restore my system and nothing happen my sound still didn't come on and it still says no audio device so how would i fix this
  • 92 Answers
Did your system restore or not?? Try downloading the sound drivers for your system and installing them...
Posted on Nov 18, 2009
I have a problem PC audio - there is no sound. On the device manager, under "Other Devices", The "Audio Device on High Definition Audio Bus" has a yellow exclamation point. And I don't...
The yellow symbol with the exclamation point means your hardware is not functioning, but you already know that as there is no sound produced.
What you need are the proper drivers for your sound card/device. These can be found on many manufactures websites in the "drivers/downloads" section.
Unfortunately because you didn't name the specific make and model of your computer, I cannot help you further. If you don't know the make/model of your computer (usually written on the front or back/underneath) You can try a program like driver genius - http://www.driver-soft.com/download.html which will automatically scan your hardware drivers and download the latest updates for you.
May 04, 2011 | Microsoft Computers & Internet
No sound on dell dimension 4700c
There can be more than one reason, why the computer can't play any sounds. These are discussed below:
If you have a desktop computer, it may or may not have a separate sound card. But in case of laptops, the sound card is integrated into the motherboard and cannot be removed, so some of the solutions may not apply to laptops. Also, new laptops come with built-in speakers, so the external speakers and cabling problems may not apply here, unless you use external speakers or headphones.
So, where do you start, when you can’t hear any sounds from your computer?
Before we start with the solutions, did you try the simplest solution first? Rebooting or restarting the computer is the simplest solution and should be tried first. If you didn’t already reboot, try it now. The sounds may just work after a reboot.
Can you hear the Windows startup sounds from the computer? If you can hear the Windows startup sounds, the sound card is working fine. If you can’t hear any startup sounds, enable the System Sounds in the Control Panel, if they are disabled. If you aren’t able to enable the system sounds and they are grayed out, you may need to install the sound driver.
Are you trying to play an audio CD, and not getting any sound? If you can hear the System Sounds, but can’t hear anything from the audio CD, even though your audio player software tells that it’s playing the disc, the problem is most likely with the digital cable that goes from the CD/DVD driver to the sound card (or to the motherboard).
One side of this cable goes into the back of the CD/DVD drive and the other goes into the sound card or on to the motherboard (in case of motherboards with built-in sound).
Are the speakers connected to the proper sound port / jack, at the back of the computer? Are they powered ON? External speakers generally have a separate power adapter, which plugs into the wall socket or any other power source. Is the speaker volume control, set to a comfortable level? If not, turn it to the middle position.
If in doubt, test your speakers by connecting them to another sound device like CD/DVD player or a radio/tape player, or any sound source. If you can hear sounds from the speakers, they are fine.
Check that the speaker pin is connected to the green jack on the back of the computer. Also, check that the sound (check speaker icon in the system tray) isn’t muted. Such a simple thing, which can happen accidentally, can confuse some people when they can’t hear sounds from their computers. This can get overlooked because the speaker icon may be lost between many other icons. Click it and un-mute the sound, if it’s muted.
Note: If you can’t see the speaker icon in the system tray, you may need to enable it from the Control Panel. From the Control Panel, double-click “Sound and Audio Devices” and check the box that says “Place volume icon in the taskbar” and click OK.
Try plugging in a pair of headphones in place of the speakers, to check whether you can hear anything. Play a song or music CD or any sound file, which you may have on the computer. If you don’t have one handy, you can run a command to test your sound:
Click the Start button, and then click Run (or Search, in Windows 7 / Vista). Type the following command and then press the Enter key: dxdiag
Click on the ‘Sound’ tab to see the details of your sound card. You can also test your sound card from this tab. Note the name of the sound card and the manufacturer, on a piece of paper.
If you can’t see the name of the sound driver, or aren’t able to hear the sound by using the ‘Test DirectSound’ button, or you get an error, the problem may be with the sound driver. If the sound worked sometime ago and now it isn’t working for some reason, the simplest solution for re-installing the sound driver is to do a System Restore. Restore the system to a date that you know, when your sound worked. Check out the following links for a short tutorial on System Restore
Note: Current documents, files and e-mail are not affected by System Restore. If you get an error like “Restoration Incomplete. Your computer cannot be restored“, undo the last action by selecting “Undo my last restoration”.
Here’s a youtube video on how to restore a system with System Restore: http://www.youtube.com/watch?v=mU5yqvye57E
Here are step-by-step tutorials on System Restore:
For Windows XP:
http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/
http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista:
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore
http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
If System Restore didn’t help or you get a message that System Restore couldn’t be completed, try the following:
Start the Device Manager (Start -> Run -> devmgmt.msc and hit the Enter key). In Device Manager, Click the + sign next to “Sound, video and game controllers”. See that the sound driver that you noted from dxdiag above, is listed.
Doube-click this sound driver. Device Manager should give a status message that the driver is working fine. If the driver isn’t there or if it shows a yellow exclamation mark, shows under other devices, or gives any other kind of status message, reinstall the driver. In any case, it doesn’t harm to uninstall and reinstall the driver.
From this sound driver properties page, you may also click the Troubleshoot button, to open the Sound Troubleshooter in the Windows Help and Support Center.
You can also visit the following link about tips for fixing common sound problems:
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-sound-problems
Hope that helps,
Regards,
Raspal
For Windows XP Driver Files and How-to Resources, visit XPDrivers.
May 03, 2010 | Dell Dimension 4700C PC Desktop
Sound is not coming from attached speakers I have window xp and ''zoltrixound'' speakers
There can be more than one reason, why the computer can’t play any sounds. These are discussed below:
Before we start with the solutions, did you try the simplest solution first? Reboot or restart the computer. The sounds may just work after a reboot.
For Windows XP: http://www.howtogeek.com/howto/windows/using-system-restore-in-xp/ http://www.5starsupport.com/faq/xp-system-restore.htm
For Windows 7 or Vista: http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/ http://www.vistax64.com/tutorials/76905-system-restore-how.html
For more information about System Restore, visit the following links: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx http://support.microsoft.com/kb/306084http://en.wikipedia.org/wiki/System_Restore http://windows.microsoft.com/en-US/windows-vista/System-Restore-frequently-asked-questions
Hope that helps,
Regards,
Raspal
May 02, 2010 | Audio Players & Recorders
I didn't able to hear sound in my computer from speakers and headphones.
For Windows XP:
Hope that helps,
Regards,
Raspal
May 02, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I deleted my sound device and i need to reinstall it
if you can select the day / week prior to you deleting the sound device (system restore)...this will make every thing work as once did....you will not have to reinstall anything
May 06, 2009 | Audio Players & Recorders
My Acer Aspire 5315 says I have no audio output device
do you think you got a virus or spyware on your system, i would first try system restore on the start acc,system tools system restore
set back to last week ,
if that dont work needs to reinstall windows
Mar 14, 2009 | Aspire Acer 53152826 Notebook
No Audio
I have a friend with a systemax, same thing happened to him.
Go into the control panel, select sounds and audio devices, go over three tabs to the audio tab, make sure the sound default device is the onboard audio card. Should be all set.
Let me know how it works out.
Nov 23, 2008 | Systemax Venture S519J (988868) PC Desktop
Sound and audio devices problem
all the options in sound and audio device properties are in active no sound is heard
Dec 17, 2007 | Edirol UA-4FX External Sound System
Lost my sound
go into device manager and try updating the audio drivers are inabled and on then update drivers, Other wise you can go into the system restore in accessories and restore you system to just before you lost you audio drivers, that should get you up a hearing sounds now, If not just let me know and I will find another solution. OK Thanks again and Happy Hoidays
Dec 17, 2007 | Compaq Rugged tr3000 (DV133U) Tablet PC
No sound in my laptop
if you are using windows xp operationg system, use system restore, to restore your system seting by choosing start menu, all programs, asccessories, system tools, system restore. then pick the date where your soundcard was work fine, let your pc restart. done.
Aug 10, 2007 | Emagic EMI 6|2m External Sound System
Toshiba Satellite L25-S119 Notebook Logo
43 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
