Question about Panasonic Televison & Video
I have a Panasonic PT51hx41e projection tv( 2001) I was watching a movie an the tv just shut down no light on front or any thing. I waited about 30 min. and tryed again and the tv came on and played great for 10 min and went black again. Any one have the answer for my problem
  • rjshadow0266 Nov 18, 2009
    I think you solved the problem. Is the TV worth replacing the mail power regulator . If so any idea what this part should run?.
    Many Thank
    Russ
    p/s the kids are real happy to see it working again.
    Thank you firesnake09 you diagnosed the problem.Keep up the good work. Thanks again
    Russ
    President:
  • 2,923 Answers
Based on the problem, the mail power regulator is over heating. To test the projection TV, try removing the back panel of the TV and then put a small desk fan up against the back of the projection TV. Then turn the TV ON and see if the same problem will occur.
If the TV remain ON, then my assumption is correct. You need to contact a repair tech to replace the mail power regulator so that there's no need for you to put a desk fan.
Hope this helps and have a great day!
Posted on Nov 18, 2009
Green light flashes several times. Then TV turn off.
look for 1 of 2 lights in front of the tv. after the tv shuts down completley mine would turn back on for another 30-45 min after a good cleaning it will stay off and give a "power light" not Lamp light 2 flashes. I'm waiting on some help myself. But if it's the lamp light you'll need to replace the lamp....approximitly $600 from what i've read so far.
Jan 11, 2011 | Panasonic PT-61LCZ70 Television
Power problem with Zenith D56W25 56 in. Rear Projection Televisi
you can try to shut the tv off ,unplug the power to tv and anything that is powering the tv[pvr] .now plug in the power to the box first wait,30 seconds or so ,now plug in the tv wait,now turn the t.v. on,WAIT unless it starts smoking just wait.see what happens.
Apr 18, 2010 | Zenith D56W25 56" Rear Projection...
My panasonic rear projection TV turns off
this just happened to us, we tried the reset button, didn't work. we unplugged from surge protector and plugged the tv in the regular wall socket and after a few minutes the green light quit and we were able to turn tv on
Apr 08, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Need to know what convergence chips are in Panasonic PT51HX41E
your model has two STK392-110 CONvergence Cs, you will also most likely need at least a few of the 2.2 ohm 2watt convergence resistors. I am posting a link to the actualrepair kit for your model which contains both Convergence ICs and all 6 of the convergence resistors and they send instructions with pictures that show how to do the repair.
http://servicemanuals.vstore.ca/product_info.php/pName/panasonic-projection-tv-convergence-repair-kit-1/cName/convergence-repair-kits
May 28, 2009 | Televison & Video
Rear Projection TV Cuts out Need to wait and then turn back on?
SOUNDS LIKE A FLYBACK PROBLEM AROUND $70.00 FOR PART
Dec 06, 2008 | Panasonic TX-42PT10 42" TV
I have a rca r52wm24 hd monitor the color is bad theres 4 of everything cannot access the convergance on menu ,watched tv repair person one time and he pressed some buttons together to get into a grid and...
Shut off tv, wait 30 seconds, then at the same time press the channel down and the volume down buttons and wait for power light to come on and then release.
Sep 10, 2008 | Televison & Video
Panasonic projection tv (shuts down)
Does the power indicator blink? Let me know and I will try to help you out. Just keep responding to this same psot so previous info will still be available.
Jun 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Need Help
Sounds like you have a loose cable. Check that the connection is really in well. If the problem continues I would get a new set of cables, especially if you are using the ones that came with the receiver or dvd player.
May 05, 2008 | Audio Players & Recorders
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
