Question about Hotpoint HTS16HBR Top Freezer Refrigerator
My Kenmore refrigerator is making a loud noise when running and when it shuts off it makes a loud clunking noise. Also, it is running about every 10 minutes. The refrigerator is 7 years old.
    President:
  • Hotpoint Master
  • 1,922 Answers
It sounds like the compressor insides are loose and you will be needing a new compressor, but just check and make sure the rubber mounting feet on the outer compressor base where its mounted to the refrigerator base are all tight and the rubber shocks are all good
Posted on Nov 19, 2009
    President:
  • 1,891 Answers
The clunking sound that it make's when the compressor shuts off is bad motor mounts / and may be the internal also . this would also cause the loud running sounds . if it starts every 10 min it may be short cycleing . ( clean the coil's and make sure the fan in back is coling the unit .. and make sure you replace the back when your done .. mm
Posted on Dec 03, 2009
Why does my whirlpool refrigerator makes a very loud clunk noise when it turns off
Try looking for any pipes that are rattling against the cabinet , if not, I'm afraid compressor problem.
May 02, 2014 | Whirlpool 25.6 cu. ft. Side-by-Side...
My Kenmore 61182100 compressor makes a couple of loud bangs when it shuts off
Here is a tip that I wrote about the clunking or thumping in refrigerators...
Refrigerator Clunking in back
heatman101
Jan 29, 2011 | Kenmore Refrigerators
Have Kenmore Model 60284991. It runs all the time and when it shuts off, it makes a very loud clunking noise. Trying to decide whether to repair or buy new - this model was manufactured in 2000 and we...
The unit is running all the time bacause it is loosing freon. It is trying to keep it down to the set temp. The clunking noise is caused by lowe pressure in the compressor. You can have it repaired for under $350 if you get the right company out. I would personally recomend replacing it though, if you had one leak, you will have more.
Nov 27, 2010 | Kenmore Refrigerators
What is the clunking noise made after the refrigerator stops running? Its a Kenmore and is 10 yrs old. We have thoroughly cleaned behind and beneath the refrigerator and now the noise seems louder.
The clunking noise you hear , is probably when the compressor shuts off , due to temp reached or when it goes into defrost . An internal motor mount spring , inside the compressor , is broken ( rusted and broke ) . The refrig can go on working for years , without any problem , except noisey , when it cuts off . To stop the noise , replaceing the compressor is the only option . I have heard of placeing objects under 1 leg of the compressor , to " re-adjust " the ballance , but thru my experience , another spring broke , causing more knocking .
Mar 24, 2010 | Kenmore 64802 Top Freezer Refrigerator
Compressor is making very loud clunk when shutting off.
I think the wire was kinda expensive. If I were you I would try to save the fridge. I think you should unplug it for a couple hours, take everything out for a while and remove any ice. Once the fridge reached room temp, the refrigerant should have made its way back to the compressor. Plug it back in and see if it makes the noise again.
It might just be the fan in the freezer. I would try the unplug/deice for a few hour method first because it is free before you try to replace a fan that might be bumping ice. Good luck!
Mar 10, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
After the compressor runs it makes a loud clunking sound when it stops running. The sound comes from the compressor.
My guess is that it is running on high head probably caused by a dirty condenser. Try cleaning that. The noise itself is the actual compressor and motor bouncing around inside the hermetic can (what you call the compressor).
Good Luck
Gilshultz
Nov 30, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Refrigerator makes fairly loud noises of a clunking kind but runs and stays cold.
Clunking noises usually comes from the rapid stop of the compressor. It will not hurt a thing. The rubber grommets which the compressor sit on for cushioning, have most likely hardened and are transferring the noise to the frame or casing. The compressor runs at 3600 rpm's and when you tell it to stop on a dime, it can't. The result is a couple of clunks or so. Also check the drip pan for improper positioning. I have seen them make noise also.
May 04, 2009 | Hotpoint HTS16HBR Top Freezer Refrigerator
Kenmore elite refrigerator/freezer loud banging
it is compressor shutting off,not much you can do to fix it.you can try changing the snubbers that hold it in place but most likely you will still hear it clunk.
Mar 07, 2009 | Kenmore Refrigerators
Kenmore top freezer fridge does not cool but freezer works
Turned refrigerator off for 8 hours, let the frost melt and the fan in the freezer worked again. The compressor now only has a soft clunk when it goes off.
Jan 30, 2009 | Kenmore 64823 Top Freezer Refrigerator
Hotpoint HTS16HBR Top Freezer Refrigerator Logo
1,695 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
