Question about LG DLE2532W Electric Dryer
My dryer is only 3 years old and it sometimes lately has like a chemical smell after running a while.. its electric.. any reason for this?
    Problem Solver:
  • 12 Answers
In the years I repaired dryers they do have distinctive odors. But dryers each year should be checked for lint. Proper installation is a must. Most modern homes the dryer has little room to repair the appliance when necessary. Some dryers have metal ductwork making moving the dryer difficult. Now the popular method is with flexible hose usually 4 inches in diameter. This makes the job easier but has a distinct disadvantage. The dryer vent hose must not be installed in such a way that the air flow is restricted. Two 90 degree bends are allowed. Vent hoses over 10 feet (two 90s) can fill up with lint a dangerous condition which left unchanged can clog up the vent and passages in the dryer. Lint around the heating elements will burn this is normal when adequate venting is mantained. Elastic and other rubberized waistbands should not be allowed to overheat see the owner's manual.
Keeping filters clean after each drying cycle is a must. It is a good idea to remove the vent hose or tubing and inspect and clean. You may need a service technician to clean areas you can see but not reach. Nothing wrong with shutting off the power to the dryer and using a vacuum to clean dryer areas.
Posted on Nov 18, 2009
My Roper dryer is a little over a year old. When I turn it on it makes a humming noise but the drum does not turn and then I smell a burning smell. I cam move the drum with my hands and it will turn. Of...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Mar 15, 2011 | Roper REX3614KW Electric Dryer
Chemical like smell while clothes are drying
If you have recently painted or varnished something then just air out the house. The fumes can react w/ the heat of the dryer to create this smell. It smells different than the actual fumes, but still like some sort of solvent.
Jul 20, 2010 | Maytag 7.0 Cu. Ft. Electric Dryer
Kenmore side-by-side has CHEMICAL SMELL ODOR inside.
You have a freon leak. With this only being 5 years old, iot's probably worth repairing, unless you are just able to buy a new one. I would have a local tech come out and check it before tossing it. I hope this answers your question and gives you some resolution. I hope to work with you again, so please record our name, email and phone number for future needs. Have a great evening!
Sep 09, 2009 | Kenmore 53642 / 53644 Side by Side...
Burnt smell when dryer running
it could be what your washing your clothes with.
Feb 28, 2009 | Whirlpool LEQ9858P Electric Dryer
Fridgidaire dyrer three years old
the heater has most likley shorted to yhe frame and needs to be replaced
Dec 23, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Maytag Dryer
the high limit switch may be malfunctioning. i would have it looked at by a professional. this could be a fire hazard.
Jul 10, 2008 | Dryers
ELECTRIC DRYER SMELL LIKE GAS
I would imagine that you are saying you have an electric dryer, but it smells like it has a gas leak correct? Let me ask one question, have you used any kind of paints or chemicals in your house lately? If you have painted anything (in any room as well), the fumes of that paint (or other chemical) will get into the elements, and produce that smell for sure. I have actually had customers give me the clothes they dried to smell them, and sure enough, it will get in the clothes for sure. If this isnt the case, be sure that you dont have a gas line behind the dryer that may be leaking, or if your hot water heater or furnace is gas, you dont have a leak there. If you do have gas coming into your home, and you havent painted, etc, call your gas or propane service provider IMMEDIATLY from another home or location and let them come out to be sure you dont have a hidden leak. Good Luck!!!!!
Jan 31, 2008 | Dryers
Stink Smell from Electric Clothes Dryer/Fuse Box
this should be quite easy to solve.remove the circuit breaker and sniff it. if it is the same smell you are getting when the dryer is running that is your problem.have an elecrtician check and replace with correct value.the dryer is most probably running on an overloaded circuit.
Jan 07, 2008 | Dryers
Maytag Atlantis dryer
Unfortunately the motor now needs to be replaced. New motors cost around $125-$150 and are fairly tricky to install.
Oct 15, 2007 | Maytag Atlantis MDE7400AY Electric Dryer
LG DLE2532W Electric Dryer Logo
155 people viewed this question
Top LG Dryers Experts
Tim Whalen
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
