Tuning in the tv
I have a 15 " lcd tv that works perfect , but cannot tune in any terrestial channels using an aerial, when searching it wont find any??? but the aerail is new and working on other tvs. ive lost the instruction boolklet
  • 579 Answers
Most TV's auto search feature will try both the Cable and the Air frequencies, but perhaps yours doesn't. Go to the menu page for tuner setup and make sure it is set on Air (might be called broadcast) and then run the channel search.
Cable channels and Broadcast channels (above channel 12) are not the same frequencies.
Hope Ya Fix It!
Posted on Jan 10, 2008
SOURCE:
42LG7000 not tuning
is your tuner set to scan for cable channels or tv channels. there is a difference though the cable input and the tv input use the same connector
Mar 03, 2015 | LG 42LG7000 42 in. HDTV LCD TV
Tip
Digitial channel tune in and set up
if you have a problem getting digital channels (uk) find local channel number digital uk can help enter tuning menu go to manuial tune on tv or digi box. it will ask for channel number start with highest number pess ok or search repeat for each channel number normal 4or 5 depends on aera if still not getting all channels put aerial lead which come for aerial into tv bypassing any equipment such as vcr/dvd recorder then start again if still not all channels may need aerial upgrade .if yo get all channels connect vcr/dvd if some channnels disappear need to reset RF out on vcr/dvd remove aerial .connect vcr/dvd via scart reset RF out on vcr/dvd this can be found in vcr/dvd set up menu reconnect all leads should now work ok
Note do not set RF out to any digi channel numer
on Aug 17, 2010 | Televison & Video
I have an indoor digital aerial connected to a free view box but when I automatically tune the TV it comes up with no channels found check aerial connection
Possibly. Try rotating the antenna a little bit and retry tuning. Keep on doing this until you get your channels. If this doesn't work, raise the antenna as high as possible and try again.
Dec 20, 2014 | Goodmans GTVL19W17HDF 19 in. LCD TV
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
Sep 06, 2012 | Hannspree Televison & Video
CANNOT TUNE TV CHANNELS FROM TERRESTIAL AERIAL INTO NEW SAMSUNG RECORDER
You need to purchase a digital converter box in order to receive the proper signal, the only exception would be if your antenna is digital ready. I would suggest talking to a tv tech to find out if you need additional changes.
Dec 29, 2010 | Philips DVDR70 DVD Recorder
Have a new digital TV, can only record the 5 terrestial channels, how do I tune in to the other digital channels, i.e. BBC3, E4 etc.
It's not clear what you mean! So one of these answer might solve it. If you are talking VCR recording it must either have a freeview tuner or have a freeview box connected to it via a scart. Otherwise it will only record the five terrestial.
Digital TV -you must have a good aerial otherwise you will not pick up all the stations. If it has a hard disc drive the same will apply.
If the terrestial stations have any grain or the picture is not as clear as a bell on all, then your aerial will not be good enough. The type of aerial should be for freeview. See image below also you need to have CT100 cable (the stuff used for satellite) not the old brown co-axial cable (see below).
Jun 05, 2010 | Televison & Video
Polaroid FLU-2632 channel searching
Often when using a Sky box, one doesn't use the channel tuning feature of the Polaroid HDTV. Often one connects the Sky box to a component video input, and the Sky box does the tuning.
I hope that helps.
___________________________________________
Polaroid FLM-2632 Manual Download
Polaroid FLM-2632 Service Manual Download
May 12, 2008 | Polaroid FLM-2632 Television
Vason 10.4 inch portable tv tuning problem
I returned my original TV/DVD to the suppliers who then sent me a new one.
I experienced exactly the same tuning problem with the new TV.
The only way I could tune it, was by using the fine tune facility to find and store the missing stations. This took a lot of time and continuous button pushing, so patience is essential.
Once found and stored, the previously missing channels are perfect.
It would appear that the DVD player doesn't like DVD- recordings from my home recorder. If they are re-coded they work.
Anything recorded on DVD+ is fine.
In my opinion this is a good unit let down by a couple of niggling faults.
Feb 08, 2008 | Televison & Video
Televison & Video Logo
330 people viewed this question
Top Televison & Video Experts
Ekse
