Question about KitchenAid KESC307 Electric Kitchen Range
My kitchenaide gas range "beeps" when the temo is reached - say 350 but it actually takes almost 30 minutes for the oven to actually get to that temp. Why does it beep when the temp was actually +/- 275?
Does anyone know what the code F7;eo means
Posted on Nov 18, 2009
  • 6,784 Answers
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
Additional Information_ The oven control will sound a beep, if there are issues with the resistance transfer between the control and oven sensor. The sensor is located, inside of the oven, on the back side of the inside wall. It will look like a 5 inch probe. You will need to remove the sensor from the back of the unit. be sure to unscrew the screws that hold the housing on the inside of the oven back wall. once they are removed, the sensor can be extracted for testing. Use the sensor contacts for testing.
JSP26GP code f3 then f2
What is the complete model number of the unit?
Dec 08, 2012 | GE Kitchen Ranges
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid gas range superba not reaching/registering right temp.
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Mar 14, 2009 | KitchenAid KGST307 Gas Kitchen Range
KGST307 gas stove has a temperature control problem.
the least expensive fix would be to buy an oven thermometer and note what setting is needed to attain 350 degrees and go from there. please rate me
Jan 06, 2009 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaid Model KGST307HBS5 intermittent will not heat up
the gas leak can be the safety valve. in side the oven where the burner sits on you have to remove the burner to get to it.
Dec 09, 2008 | KitchenAid KGST307 Gas Kitchen Range
TAKES TO LONG TO PREHEAT
sounds like the thermostat may be open and nees to be replaced. have a technician take a look at it.
Sep 07, 2008 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid superbra range KGST307
I am not a repair man or anything, just an owner with the same gas range slidein appliance. What we have found to work was 1) plug in the probe into the socket in the oven 2) Turn on oven with the probe set at the minimum 160 degrees. and oven temperature to 325 degrees. 3) click start 4) wait for oven to reach probe temperature. 5) oven will then beep show end 6) Click cancel 7) open door and remove probe. 8) wait five minutes before trying to use again. I hope this helps you it has work for us so far. 6)
Aug 27, 2007 | KitchenAid KGST307 Gas Kitchen Range
GE Profile Spectra JGBP85WEB5WW Range
It sounds as if you might have a problem with the gas valve for the oven. This is something that I would not reccomend that you try and fix yourself.
Aug 12, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KESC307 Electric Kitchen Range Logo
162 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
