Question about Pantech C470 Matrix Smartphone
I have a usb cable for the matrix and was going to put songs on my mp3 however it says that i need a disk to instal for my driver software what disk are they talking about. my computer is windows vista
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
Tip
Connect MP3 Player To Computer and Transfer MP3 Songs From Computer To MP3...
To successfully transfer songs either MP3 or WMA files to your MP3 player follow these steps.
1) If your device came with a CD insert this into your computer and follow the on-screen instructions.
If the device has no CD most PCs will recognise the device and update the drivers automatically once you have connected it via USB cable.
2) Connect the device to the PC using USB cable. With many players this is the only means of charging the device.
3) On your computer go to 'Start' - 'My Computer' and you should see the device listed as a USB Mass Storage or Removable Disk.
4) Click and highlight the songs you want to transfer to the MP3 player. You can either drag and drop them directly into the USB Mass Storage Folder shown in Step 3 or you can right click the song file and select 'Send To' USB Mass Storage Device.
5) The songs are now on your MP3 player.
6) Disconnect the player from the USB cable. The player will take a moment to update and you can now play the songs on the player.
Note: In order to transfer music files from a CD these must first be converted to MP3 in order for the player to be able to play them. To do this you can use Windows Media Player to 'Rip' the songs onto your computer in MP3 format. From here use the steps above to transfer them onto the player.
If your MP3 player has video capability these files will need to be converted in to a format that the player can handle. To do this, use the software that came with the device on the CD or you may use a free converter like this one if the original software is lost.
Hope this Tip has helped.
Please do reflect this and indicate your rating using the Yes/No buttons below.
on Jan 01, 2010 | Audio Players & Recorders
How to put songs on my mp3 player
Hello, if this Mp3 player has a driver software you have to install that (like ex.: I tunes) and you have to plug this device using the usb cable and you can use the software to transfer the song. but if it does not have any software you can plug the usb and transfer the music to the music folder inside that MP3 player... Thank you for using Fixya
Mar 04, 2011 | Audio Players & Recorders
Idonot know how to put song onto my sansa from computer
Usually you need to download the songs to your computer & then connect your unit via USB cable to your computer to be able to download it to your unit, make sure that you have the software for your computer so you could build your driver for it.
Jun 29, 2010 | SanDisk Sansa m240 MP3 Player
How do I put songs on the MP3
IF YOU HAVE A DRIVER THAT YOU GOT WITH THE MP3 PLAYER THEN INSTALL THAT FIRST ON A COMPUTER.IF YOU DIDN'T GET ONE THEN YOU MIGHT NOT NEED IT. YOU MUST HAVE A USB/DATA CABLE FOR SONGS TO BE TRANSFERED. OK NOW CONNECT YOUR MP3 PLAYER TO THE COMPUTER WITH THE CABLE,COMPUTER WILL AUTOMATICALLY DETECT IT. GO TO MY COMPUTER AND CHECK YOUR DEVICE LISTED AND RIGHT CLICK---OPEN CHECK IF YOU HAVE ANY SONGS ALREADY LISTED IN THE DEVICE FOLDER OR IT MIGHT TAKE YOU DIRECTLY TO THE SONGS LIST.THIS IS WHERE YOU NEED TO PUT YOUR SONGS. SIMPLY COPY THE SONGS FROM THE PC AND PASTE IT INTO THE MP3 FOLDER OR YOU CAN OPEN TWO WINDOWS AT A TIME AND USE THE DRAG AND DROP OPTION. I HOPE IT HELPED.
Jul 19, 2009 | Audio Players & Recorders
Its not working as it says it should on the package
try with usb cable check your usb cable is working fine aslo uninstall all usb driver then install again go to my computer property then hardware then device maanger then you see usb drivers uninstall all then just restart computer it automatic install all usb driver.
ten check in my computer yourt meory card is found as removable disk or not.
if not then reattch memory card to it.
Jul 11, 2009 | SanDisk 2GB microSD Memory Card
GoGear MP3 player-How to put music onto it?
First You need to connect your player to the computer using a USB cable. Most mp3 players will be shown as a removable disk drive in my computer as soon as they are connected. Just copy and paste your mp3 files on to it. Dont forget to use safely remove hardware option before disconnecting it from the computer. Also if you got any software with your player on a CD i recommend that you install it on your comp so that it will help you organize you songs in a better way.
Feb 15, 2009 | Philips SA6025 Digital Media Player
MP4 won't download
Install the Philips Device Manager software and drivers from the product CD.
You then need to use the Windows Media Player, Sync function to transfer music tracks.
Apr 11, 2008 | Philips GOGEAR SA6045 MP3 Player
Delete songs
You should be able to hook your mp3 player up to your computer with the USB cable. This will allow you to browser the directory where the songs are and delete or add new songs. Your mp3 player will appear in your computer as a removable disk. The songs that you put on your mp3 player need to be in mp3 or wma format. I also found the instruction manual for your product in pdf format. http://www.gpx.com/shop_ind.php?id=%20%20344#
Dec 11, 2007 | GPX MW3816 MP3 Player
Is the software packaged better than XP driver?
It's always better to install the original software over XP default driver, Try to install it – it should help. Make sure you power off the player before insert the USB cable. If the problem still exists, try different USB port/cable. Good luck.
Aug 11, 2005 | Jwin JX-MP124 (128 MB) MP3 Player
Pantech C470 Matrix Smartphone Logo
Top Pantech Cell Phones Experts
Abdul Mannan
Abdul Mannan
Jax Planet
Jax Planet
Are you a Pantech Cell Phone Expert? Answer questions, earn points and help others
