Question about Panasonic TC-32LX85 LCD TV
Red LED 3 times flashing, nothing else
I have a similar problem to those seen on other panasonics. Power does nothing except produce a red LED blinking 3 times. Other posts for other TVs recommend changing two ICs (STK392-XXX). I can't find anything labelled anything close to STK392 on this particular TV. Nothing else seems out of the ordinary in the TV...the fuse on the power board is fine.
Any help would be appreciated.
    Problem Solver:
  • 5 Answers
On Panasonic 32LX TVs this is a known fault, repairable by a firmware upgrade. John Lewis in the UK sent out an engineer under their 5 yr TV guarantee and completed the firmware upgrade for me. The only other store to compare with them for price and service is Richer Sounds but I believe you now have to buy the warranty for 10% of the purchase price. This problem will persist unless the upgrade is completed. For those of you in the UK, I would insist the seller (not manufacturer; your contract is with the seller) repairs the problem under the Sale of Goods and Services Act as the TV is not fit for purpose without the upgrade.
Posted on Feb 13, 2010
Should I get a flashing red light on my Panasonic TC-P42C2 tv even if nothing else comes on?
That is a known issue with the Panasonic plasma TV's, the flashing red light is a diagnostic light, you might hame issues with the internal power supply board.
Nov 17, 2014 | Televison & Video
PT54DL50
MOST LIKELY problem is the convergence amps but.....
It might be your vertical or horizontal circuit...those initiate a 3 blink failure code too....
Dec 01, 2007 | Panasonic PT-50DL54 50" Rear Projection...
Hi Friends! I have a Panasonic TH-L32C20R. When
Something worth trying that worked for me and costs nothing is; remove all leads except the power lead. Hold the on/off button on the TV in until the light stops flashing, release button and and press again. If it fires up your good to go if not your nearly finished disconnecting everything ready to send off for repair! Good luck, BTW the number of flashes indicate a fault code that you can look up online.
Sep 22, 2013 | Panasonic TH-42PX60U Television
Mysteriously stopped booting up
I hate when people just guess what is wrong at sites like this, but I'm "guessing" your power supply needs to be replaced. I've seen similar symptoms before. They're cheap and easy to replace. I'm 80% sure that will fix your problem. Just make sure it has the correct standard or SATA power connectors for your hard drive(s) and CD drive.
Oct 07, 2012 | Asrock K8NF6G-VSTA Motherboard
Panasonic pt47wx52 will not power on
i have a panasonic pt47wx52 hdtv projection monitor . It will not power on and the red led light flases 3 times pause 3 times. What is my problem.
Feb 21, 2010 | Panasonic PT-47WX53 47" Rear Projection...
My Panasonic PT-60Dl54J tv shut itself off and the power button is now flashing red 6 times. What has happened, how do I fix it?
This is straight from the service manual (I'm not sure what the problem is but it sounds serious):
8.2. Power LED Flashing timing table
When an abnormality has occurred, the protection circuit operate and cuts the power supply. At this time, the defective line can be
identified by the number of flashes (red) of the power led indication at the front of the unit.
NUMBER OF FLASHES CIRCUIT MICRO PIN
1 LOAD SHORTAGE 92
2 OVER VOLAGE 93
3 FAN SOS 94
4 MAIN 3.3V 88
5 LAMP DISABLE 61
6 GC3FM-IIC IIC
7 GC3FS-IIC IIC
8 GC3I-IIC IIC
9 COLOR WHEEL STOP 110
Dec 06, 2009 | Panasonic PT-50LC13 50" Rear Projection...
No sound or picture, 2004 pt50dl54j
remove back panel. blow out all the dust from all the components except the fan on the right.
Vacuum out all the dust.
Have you replaced the lamp? that would help too.
There are 2 small red lamp. One indicates HEAT problem. The other one is the LAMP indicator.
Jun 13, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-43LC14
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
May 24, 2009 | Panasonic PT-43LC14 Television
Red led light flashes 6 times and tv won't turn on
Hi friend,,,,,,
it is an indication of an error code ,,,,,,normally 6 blinking code refers to an power set up problem,see incoming voltage with an multimeter.......
thank u,,,,,,,,
May 03, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic TC-32LX85 LCD TV Logo
341 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
