How to reset the eeprom on a hitachi 50v500 tv to clear a pink screen
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
I have the Hitachi instructions for attempting this,
Understand---this model is prone to having a bad optical light engine--there are class action lawsuits in several states.
What happens is the heat from the lamp can damage the lens etc inside the engine. Usually there is a large red oval area in the middle of the screen.
Of all the ones I have done the reset on---it only cured the problem in a few of them. You can start out with a pink or red screen and after you do it you may see only the RED oval--if you do the engine is bad and currently is over 600 dollars wholesale--not counting major labor to replace it.
Let me know if you want the instructions and I will post them here.
If this information helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 18, 2009
Testimonial: "Thanks this info is very helpful! My set has a uniform pink tinge so I would like to try to reset the eprom and would appreciate the information."
  • SD Tech
    SD Tech Nov 18, 2009
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    st1\:*{behavior:url(#ieooui) }
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    50V500 PINK OR RED
    Possible symptoms:
    red picture, too much red, pink picture, reddish picture, red overloaded
    picture, bright red picture, white, balance issue, not enough green, weak
    green, etc.
    1. Perform
      memory initialization---NOTE YOU MUST WRITE DOWN SOME DATA VALUES BEFORE
      PERFORMING INITIALIZE.
    1. BE
      SURE TO COPY DOWN DATA SETTINGS BEFORE INITIALIZING I2C SETTINGS.
    SELECT A NON USED OR BLANK VIDEO INPUT OR TUNER TO GET INTO
    THE I2C MENU, ALSO MAKE SURE THE POWER LED ON THE FRONT OF THE SET IS NOT BLINKING
    AT ALL.
    1. ENTER
      THE I2C SERVICE MENU, BE SURE THE POWER IS OFF.
    2. ON THE
      FRONT CONTROL PANEL PRESS AND HOLD THE INPUT BUTTON.
    3. THEN
      PRESS THE POWER BUTTON FOR 2 SECONDS.
    4. YOU
      MAY KEEP THE INPUT BUTTON DEPRESSED UNTIL YOU SEE THE OSD WITH THE SERVICE
      MENU DISPLAYED.
    5. IF YOU
      DON’T SEE THE SERVICE MENU, REPEAT THE PROCESS MAKING SURE YOU WAIT UNTIL
      THE POWER LED STOPS BLINKING AFTER YOU TURN THE SET OFF.
    Copy down these settings:
    IMPORTANT: the following are service adjustments. These data values are lost when Memory
    Initialization is performed. It’s
    important to write the values down before proceeding.
    H POSITION________
    V POSITION________
    LCD ADJUST (NOT
    LCD DRIVE)
    >ARROW RIGHT(WITH CURSOR)
    GHOST (ARROW RIGHT) >LCD ADJUST SHP_______
    PRESS SELECT-- LCD
    ADJUST GHOST=R
    _______
    PRESS SELECT-- LCD
    ADJUST GHOST=G________
    PRESS SELECT-- LCD
    ADJUST GHOST=B________
    PRESS SELECT AND THEN EXIT
    V COM----ARROW RIGHT V COM=R________ set for minimum flicker
    PRESS SELECT
    V COM=G________ set for
    minimum flicker
  • SD Tech
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    PRESS SELECT
    V COM=B________ set for
    minimum flicker
    PRESS SELECT, THEN EXIT.
    NRSH--- ARROW RIGHT
    VS-DAT 1 THROUGH – 9
    ________ _______ ______ _______ _______ _______ ________ ______ ______
    PRESS EXIT TWICE
    SCROLL DOWN TO “TA1283’ THEN RIGHT ARROW
    SCROLL DOWN TO:
    CONTM1__________
    CONSTS1_________
    PRESS EXIT
    AFTER WRITING DOWN THESE VALUES :
    SCROLL UP TO “MEMORY INTI”
    Execute the memory initialize operation after all the
    adjustment values have been written down on a sheet of paper. HIGHLIGHT ‘MEMORY INTI”, ARROW TO THE right
    and hold the button to the right (cursor) for approx 5 seconds until a check
    mark appears in that box. This activates
    memory initialization.
    After the memory initialize operation has finished (10-15
    seconds) the channel will revert to channel 3.
    The pink image symptom should be gone.
    Go back and write all the adjustment values you wrote down
    as needed—set the data values back to the data values written down before the
    memory initialization was done. NOTE:
    MAKE SURE THE SELECT BUTTON IS PRESSED ON THE REMOTE AFTER EVRY CHANGE TO THE
    VALUES. FAILURE DO SO WILL RESULT IN THE
    VALUES NOT BEING CHANGED.
    EXIT THE I2C MENU:
    PRESS EXIT REPEATEDLY UNTIL YOU GO BACK TO THE NORMAL
    PICTURE. TURN THE SET OFF AND THEN ON
    AND CONFIRM THE PICTURE REMAINS IN A GOOD CONDITION.
My Hitachi 50V500A LCD Rear Projection Television has an overall pink color now. what could be the problem?
the lcd panels are broken,you need a new one
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Jul 05, 2012 | Hitachi UX21511 Projector Lamp for 50V500
TV HAS A PINK FILM TO THE PICTURE
Go here.... it fixes it free!http://www.fixya.com/support/t973472-light_engine_problem_hitachi_50v500
Jan 02, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
Colour problems
Any developments with your Hitachi?
May 18, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Your light engine is going out. You might be able to get a rebuilt one fron www.vancebaldwin.com
Feb 01, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
50" Hitachi Ultravision 50V720 with pink hue screen
Always research your model at www.HitachiServiceUSA.com.
Many entries for your model.....................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink Screen
There is a service bulletin for this problem - you need to reintialize the memory settings in the service menu - I have a pdf file showing how to do this.
Sep 09, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Um I JUST BOUGHT a 50v500 tv
Contact a parts dist. They may be able to provide you with information regarding this part
Sep 04, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Pink cloud covering most of the screen
If the pink spot appears as mostly a circle in the middle if the screen then a light engine is needed. If it is an even coverage than possibly just a memory initilization needed by a technician.
Jan 13, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
910 people viewed this question
Top Televison & Video Experts
Electro Med Services...
