Question about ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card
Monitor/card problems I recently moved house and when I reconnected all leads etc, I can't get my lcd screen to pick up a picture, it sounds like the pc is booting up ok but as I can't see anything on the screen I can't tell. I have tried all connections on the back of the card which is 2 x dvi and 1 s-video but still the nothing on the screen. I know the screen is ok because it's my tv too. any suggestions?
  • 3 more comments
  • beaneruk Jan 10, 2008
    Thanks, but I can't see anything on the screen so can't change any options...kinda stuck, can't even see bios.
    I've already tried that but no luck, it's seems that the computers booting up fine tho as theres no beeps and the hard drives etc, all sound like they're booting up. even if there was a problem surely I would still be able to see bios?
    It's a Sharp LCD tv, I have it on the correct input, PC input Ext 5, but all I get is a out of range message on the screen...pc's only 6 months old and tv is about 4 months old. I think I will have to take another look at it and unplug everything from the motherboard again etc....I just don't get it, it was working fine before the move!
    I have thought of connecting it to a monitor, unfortunately I don't have one. nothing's ever easy is it!! Think it's going to end up in the thames tonight, if I don't get it working, thanks for the help though, just wondered if anyone else has had the same problem and managed to fix it.
  • roguetrooper Dec 31, 2008
    gforcenvidea7800
    Scholar:
  • 134 Answers
Since you mention that you just moved, try reseating all the cards inside your computer, The vibrations of the moving might have slightly pop your graphics card out of its socket. Just disconnect the power, open you case, make sure you ground yourself by touching something like a sink to avoid electrostatic discharge which could damage your pc components, then take each card out then plug it back in firmly but not too hard either.
Posted on Jan 10, 2008
  • Alex J.
    Alex J. Jan 10, 2008
    I understand your frustration, but trust me, moving a PC does more damage than one think, reseating all your cards might help but it's true that the bios should catch it during P.O.S.T. Have you tried to connect it to a normal PC monitor? I know it sounds stupid but PCs can be maddening like that. try that and go from there.
    Genius:
  • 1,067 Answers
Might hav eto reset the video card options by usinga reg crt screen or dvi is it pluged in pushed down tight in pci slot or agp once uuse reg config it agian to go tv out u hav eto tell it s video out dvi u dont tho but u may need itto be in tv mode in ati options menu
  • 1 more comment
  • nick helpap
    nick helpap Jan 10, 2008
    no cuse tv out puts aint set up or your tv not accepting that signal is it on right input on tv s video ect dvi do u have old crt screen put that on it once see if u can see
  • nick helpap
    well your video out must be at 60 hertz ok try 1024x768 ok
  • nick helpap
    well u gotta get in menus with crt ok screen or monitor then adjust outputs 60 hertz 1024 x768 try that 1st ok
Computer screen flickers with horrizontal lines and image is distorted. At times the screen turns white starting from the top left corner and slowly moves throughout the entire screen. Sometimes if i...
sounds like the LCD cable connection to the motherboard is loose. if you can, refer to the manual to remove and reconnect the LCD cable connection to the motherboard making sure it is securely attached. if this does not work, test if the same display problem will appear to an external monitor once connected to the laptop. if it does, it would be a video card problem and you'll need to get it replaced. if it only happens to the laptop LCD even after reconnecting the cable connection for it, you may need to get it replaced. hope this helps.
Feb 03, 2011 | HP Pavilion dv9000z Notebook
"Cannot display this video mode"
first thing check all power cables and monitor cables are plugged in properly , also you might check the monitor cable , inside the medal housing to see if any pins were broke off while moving. this would be an easy fix , just buy a new cable. if not check to see if you have a video card and that it is not moving around and properly seated to motherboard. if not most pc's are onboard video which would be entirely different issue. most of the time when moving pc's its usually a simple fix.
Apr 04, 2010 | Dell E153FP 15" LCD Monitor
Movedcomputer & monitor to different room and now I do not get a picture or anything on the screen, just black
Take the side cover off the PC make sure the graphic card is seated firmly in its slot. This has no doubt moved when unplugging or putting it back together. Check other boards and connections while youre there. Hope this helps ............cheers from Scott
Please dont forget to rate me
Nov 02, 2009 | ViewSonic VX910 19" LCD Monitor
Unhooked and moved my computer to another part of my room and the monitor now comes on with the power saver display and button is blue, then power saver display goes off and button turns yellos light and...
Sounds as if your monitor is not receiving a signal from your video card. In all likelihood, the video card came unseated during the move. Open the case and re-seat the video card, that should do the trick.
Write back if that does not solve the problem.
-Jon
Sep 29, 2009 | Gateway FPD 1730 17 in. Flat Panel LCD...
Monitor gets power but no picture
check the cable connections
reconnect them. if nothing happens try hooking it up on a different computer.
if picture does appear still, check the video card of your computer, it could have been damage.
Oct 30, 2008 | Samsung SyncMaster 193V 19" Flat Panel LCD...
Fujitsu-Siemens P15 TFT power/picture problem.
  1. No start-up. Clicking sound from speakers
  2. solution
  3. Replace C922 and C923 (both 1000uF/16V). Also replace C924 and C925 (both 470uF/16V). on powerboard
JK electronics
Den Helder
document.getElementById('showwaitmessage').style.visibility = "hidden";
Aug 11, 2008 | Fujitsu Siemens Premium Line P15-1 15" LCD...
Before we moved to a new house my samsung syncmaster 710v monitor was working fine but when I reconnected monitor to the cpu, no picture appears but green power led flashes and when i disconnect the...
First make sure all cables are tight and secured, and try pressing the Auto Button on your Syncmaster? It's for auto configuration.
If problem persist and if possible can you try using another known normal monitor/LCD? Also try your monitor using another cpu or laptop.
May 12, 2008 | Computers & Internet
PROVIEW FLAT SCREEN TFT 17" MONITOR
the vga mode not suppopt is on and not working
May 07, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Screen Problems with my Laptop
hi dear
1. That can be connection related problem. I check connection between the video cable and the LCD screen, try reconnecting the video cable. It’s necessary to take apart the display panel, unplug the video cable from the connector on the back side of the LCD screen and then plug it back in. In some cases reseating this connection helps. 2. If reconnecting the video cable doesn’t help, here’s what I do in this case. While the display panel is still disassembled, I turn on the laptop and wait until image appears on the screen. Then I move the video cable a little bit without touching the LCD screen. If moving/touching the video cable affects image on the screen, it’s possible that there is a problem with the cable. Apparently there’s a short somewhere inside the cable. In this case, replacing the video cable may fix the problem.
3. If reconnection the cable doesn’t help and moving/touching the cable doesn’t change image at all and the only way to get better picture is moving/touching the LCD screen itself, apparently there is a problem with the LCD and it has to be replaced.
oke
Posted by Laptop Freak on March 22nd, 2008 Filed in Video Problems, LCD Screen Issues, LCD Displays Lines -->
Mar 24, 2008 | Compaq Presario 700 470024-192 Notebook
Power issue
See if your video card inside your PC hasn't come loose. Take it out and push it back in again to reseat the card. Then, once it's firmly secured, try the monitor.
Jun 06, 2007 | Acer AL718 17" Flat Panel LCD Monitor
ASUS EN7600GT/2DHT/256 (256 MB) PCI Express Graphic Card Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
