1998 Pontiac Grand Prix Logo
Posted on Nov 17, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi I have a 1998 Pontiac Grand Prix and the heater blower motor does not work, if I turn the ignition on and the blower motor is in off position my headlights come on. when I turn the blower motor to the 1st setting the lights go off but the blower motor does not work. I checked the blower motor with a 12 volt battery and that works. i put a new resister in and it did not slove the problem
Anonymous
Level 2:
Sergeant:
  • Expert 198 Answers
  • Posted on Nov 17, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
198
Questions
Helped
70157
Points
633
This sound like the blower motor relay(lo relay) is wired in to the head light switch voltage.You need to follow the wire from the blower relay (there should be 4 wires) thats hot when the ignition is on and make sure it goes to the blower motor.It sounds like a couple wires got switched.
How do I remove and install heater blower motor
04-08 Pontiac Grand Prix - Blower Motor Resistor ... - YouTube
? 7:32
https://www.youtube.com/watch?v=Cn0HeJP8bZQ
Oct 8, 2012 - Uploaded by GPVlog
04-08 Pontiac Grand Prix - Blower Motor Resistor ReplacementPart 1 ..... Loosen, but do not remove the two frontward screws, then remove the single rearward .... Pontiac Grand Prix StereoRemoval 2004-2008 - Duration: 4:27. by Factory Car Stereo ...Pontiac Grand Am ,HVAC, Heater Fan will not turn on.
04-08 Pontiac Grand Prix - Blower Motor Repair (Part 1 ...
2000 grand prix, temperature won go from ac to heat, stuck on ac.
Pontiac Grand Prix Climate Control/AC - Car Forums at Edmunds.com
forums.edmunds.com > Pontiac > Pontiac Grand Prix
Dec 29, 2007 - 30 posts - ‎20 authors Hi Joe, I had the same problem with no heat on my 2000 grand prix. .... motor and the exterior temperature sensor have both been replaced ... Pontiac Grand Prix Electrical/Lighting
Aug 3, 2009
Pontiac Grand Prix Heater blower relay switch
May 13, 2009
Pontiac Grand Prix Starting / Stalling Issues
Feb 9, 2008
More results from forums.edmunds.com
Fixing AC Temperature Control on my 2002 Pontiac Grand ...
? 9:58
www.youtube.com/watch?v=2BOdhWMdxXc
Jul 13, 2014 - Uploaded by Turbo231
Fixing AC Temperature Control on my 2002 Pontiac Grand Prix... How To Install Replace AC Heater ...
1998 Pontiac Grand Prix GT - Blower Motor will not blow in the lower speeds, High Speed (5) only. Resistor has been replaced 3 times in the last twenty four hours, blower motor has been replaced twice in...
Your ignition switch is bogus. High speed runs directly off the speed control but the lower speeds go thru the ignition switch. Do not know why but that is the way it is!!!!!!!!
Replace the ignition switch and you will be back in business.
1998 grand prix gt blower motor stays running even when the car is turned off with keys out of the ignition. had to disconnect battery to stop it. not sure which fuse to pull because i have no diagram. any...
The blower should stay on for about 5minutes to cool the engine off. It isn't a problem unless it is running continuously after the engine is cooled.
1helpful
2001 pontiac grand prix, replaced blower motor, would only work on high, most of the time, at times it wouldn't work at all and when it did on high only. so I also replaced the resistor. I still only have...
Check for power at the HVAC CNTRL fuse with the blower set at any speed less than high speed. There should be power anytime the key is in the run position. If there is no power turn off the blower. If there is power with the blower off you need an ignition switch. The ignition switch is what supplies power to the lower speeds.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
1helpful
2answers
I have a 97 Pontiac Grand Prix, The blower motor only work on high. I have replaced the switch, the resister, and the blower motor. Also when I turn the blower motor on in any of the first 4 position the...
Wires need to be tested at certain points to find out whats going on. It could be as simple as a bad ground somewhere. This needs to be looked at by someone with experience so that more damage is not done. Hope this helps.
2helpful
1997 Pontiac Grand Prix GT; Elec problem with fan
Replace the blower resistor that is mounted next to the blower motor on the passenger side of the vehicle.
This will restore correct blower operation and I suspect it is also back-feeding voltage resulting in your electrical issues.
Two screws hold the blower resistor into the heater case and it is very easy to replace.
Good luck
1helpful
2answers
Where is the blower motor located on a 1998 pontiac grand prix se?
under the dash below the glove box
if the blower motor is inop then
1st check for power on the purple wire at the blower motor
if it has power then you need a blower motor
if it does not have power then replace the resister
located beside the blower motor5-7 wire connector
TRICK TO REMOVING THE RESISTER
you will see 2 goldish colored bolts they are 5.5mm remove them
now the TRICK
there is a 3rd bolt you can't see pull down then pull towards you
this will BREAK THE RESISTER OR SLIDE OFF THE BOLT
then when the resister is out LOOSEN THAT BOLT OFF
the resister is slotted slide the NEW RESISTER in the bolt you just loosened then tighten the other 2 leave the hiden bolt loose
hope this helps
2000 Pontiac Grand Prix: Metal-on-metal Noise
heater blower motor bearings are going bad...replace blower motor...Lee
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
