Question about Lucent AT&T Speakerphone 832 (21215)
Can I use this phone with a digital line (not regular analog) I have a Toshiba system with several phones attached. The AT&T is (as far as I know) a analog unit.
    Problem Solver:
  • 11 Answers
Whether the AT&T is analogue or digital it will not work with your Toshiba system
Posted on Nov 18, 2009
8860 wont send or recieve fax on cable modem
Fax machines usually only work over regular phone lines, not through digital cable or DSL systems. If your phone is a VOIP phone, it is a digital system and your fax will not work. It needs to be plugged into the Plain Old Telephone System (POTS) which is an analog system.
May 05, 2012 | Xerox Office Equipment & Supplies
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
Have a kxt-7453 and need to attach a heart monitor which needs an analog phone line. On the back of the kx-t7453 is an XDP jack to attach a fax machine. This would be the analog port; however, there is...
It depends on the system the phone is wired to. A TD-816 has modular plugs on the base cabinet, but uses an Amphenol cable for the expansion units, and a 1232 is all Amp. You need 4 wires to make it work. The quickest way to test is is to unplug the digital phone and plug a single line set into the same jack. If it works, then you need to do some system programming. If it doesn't some wiring.
The digital phone uses the outer paris of a 4-conductor jack, and the analog/XDP is on the inner pairs. We always use 2-pair jumper wire on TD systems, but some installers cheat and don't wire both pairs. You'll know if it works because the single line phone you plug into the jack alone will have the same extension number as the digital set.
If you have dial tone there, by default, when you plug in the digital set, the XDP has to be turned on in program 600 and there's a merge/unmerge comand. The XDP port is 100 more than the station (ie 103/203) and the code to merge/unmerge is 390 and 391 (I can't remember which, so look at the display as one merges (probably 1 and one doesn't 0)
You'll have to teach the device to dial "9" or an access code 81-88 to get a specific line or group.
Outside of that, it's not that bad to program.
Carl
Sep 18, 2010 | Panasonic KX T7436 Corded Phone KX-T7436
Bizhub 161f not always answering an incoming fax...2nd try works but not always? Using the avaya phone system.
Avaya is a DIGITAL phone system, all fax machines are ANALOG. You nes a regular phone line for your fax
Jan 08, 2010 | Minolta BIZHUB 161F Black and White Copier
I have Comcast bundle service for my home that includes tv, phone and internet which is digital. Can I use the Sensaphone 400 with this digital system?
This model may not be used on a digital system. It can be used on a standard phone line only, only engineered to handle standard phone line with pulse or tone dialing. I hope this helps!
Sep 20, 2009 | Sensaphone Computers & Internet
Pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
Apr 09, 2009 | General Electric RCA-25424RE1 4-Line...
Phone lines
All tranzs are designed to work on analog phone lines. It might work for a short time on digital or VOIP, but it can burn out your modem. There are no internet connections built for this terminal
Nov 06, 2008 | VeriFone TRANZ 380 Transaction System (X2,...
I have changed from a 2 line phone system to a 1 line. I am still using the same 2 line wireless telephone/answering machine. The telephone will only work for outgoing calls and not for incoming. The HP...
I just bought a used hp 3200se and am trying to use it as a stand alone fax. It (so far) does not answer incoming calls. I found that I can manually answer a fax call and then the machine seems to work fine.
I tried connecting to ...oh, by the way, I have digital phone service from Comcast, an analog line and it seems to work fine. So maybe the 6310xi is the same or maybe there are setting to deal with a digital line. Maybe something in this will help.
John Mavis
Nov 03, 2008 | HP Office Equipment & Supplies
Do you need to purchase a special plan from your phone provider in order to use a digital cordless phone...or can you use your regular landline connection?
Nope you can you use a digital cordless phone on any analog or digital line. The term "digital" in refrence to the phone just means that the wireless signal between the base and the cordless is digital. Where as the actual line that the base is plugged into can be analog or digital.
Hope this helps
Jul 06, 2008 | Lands Phones
Brother Intellifax 770 fax machine failure to receive faxes
I HAVE A BROTJERS 770 AMD ALL I DONE WAS GET A 2 SPACE TELE JACK AND PLUG IT INTO MY MODEM FROM COMCAST AND PLUG MY PHONE AND FAX INTO IT AND CAN RECEIVE AND SEND
Mar 24, 2008 | Brother IntelliFAX 770 Plain Paper Thermal...
Lucent AT&T Speakerphone 832 (21215) Logo
42 people viewed this question
Top Lucent Lands Phones Experts
Paul C.
Computer Repairing
Computer Repairing
Michael Galve
Michael Galve
Are you a Lucent Lands Phone Expert? Answer questions, earn points and help others
