Question about SPARKLE Computer GeForce 6600GT, (128 MB) AGP Graphic Card
Flickering monitor attached to notebook.
I recently added and new 24 inch LCD monitor to my HP Pavilion dv9000nr notebook running Vista Operating System. I have a Nvidia GeForce Go 7600 integrated graphics card. I run the monitor from a HP expansion base via an analog VGA connection. I have tried the connection directly from the notebook but the same problem persist. The problem is that the monitor flickers as if there is some interference. This is the second 24 inch LCD monitor (different brand) I have connected with the same flickering. I have tried to reset resolution and refresh rates but this does nothing. Drivers appear updated. No electrical device or cord problems seem apparent. I have my monitor set as a single monitor rather than a clone or dualview. Doesn't seem to matter anyhow as far as the background flickering is concerned. This flickering does not appear on the notebook screen. Any suggestions?
  • Berserk Jan 10, 2008
    It has a DVI input. I don't see a 720 p tv out to display manger. I will try the resolution and refresh rate settings.
    Thanks
    Genius:
  • 1,067 Answers
Doe syour lcd screen have pc input or dvi > also in your nvidia control panel u nee dto tell it add 720 p tv outto display manger always 60 hertz try differt resultion 1024x 768
Posted on Jan 10, 2008
  • nick helpap
    nick helpap Jan 10, 2008
    ok let me know try 1024 x768 on crt screen so u can see it at 60 hertz then shoot it the lcd tv see if it works again
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
Which model of Inverter Board does HP pavilion f1503 uses? My backlight keeps on dimming after 10 secs of start up. please be spefic with the model number
The part is a "ribbon cable" for an lcd monitor...ribbon made by Youngshin (AWM 2896 30V 80C VW-1).
2 ribbon cables for a hp pavilion f1503 LCD monitor (the two from the AD board to the TCP)
The LCD panel is made by HannStar (HSD150SX84).
Also, looking for other LCD parts, particularly:
the AD board for a Proview Pro-576 (I assume Sylvania PL-576 & Mag LT576s are similar); Board #: 200-100-AS576 Rev: B MV5-S2?
It uses a sampo inverter (QPWBGL8621DG) & a AU Optronics M150XN05 LCD.
Jun 20, 2012 | HP Pavilion F1503 15" LCD Flat Panel...
Keyboard lights up screen stays black....after inserting recovery disk screen still remains black...
Would like you to attach an external monitor for a diagnoses.
A VGA monitor.
Can be a CRT monitor that resembles a small TV, or a flat LCD screen monitor, that has a VGA cable attached,
http://en.wikipedia.org/wiki/VGA_connector
1) Laptop OFF, monitor OFF, attach the VGA cable of the monitor to the laptop's VGA connector.
[For the HP Pavilion dv6000z Notebook PC, the VGA connector is on the Left side at the Rear. Second port from the rear. 15 pins.
3 rows of 5]
2) Turn the monitor on. If a CRT style allow it to warm up.
3) Turn the laptop on.
By default the display should show on the external VGA monitor.
If not, press, and hold down on the FN key,
(Second key from the left, on the Bottom row on the Keyboard),
and tap on the F4 key.
(Top of Keyboard towards the left)
Still no? Hold the Fn key down again, and at the same time tap on the F4 key.
There are 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
IF, the display shows up on the external monitor, and if it is OK, the problem lies in the Display Assembly, and/or the Video Cable.
More on that in a moment.
IF, the display does Not show up on the external monitor, or if it is garbled, the graphics chipset is bad.
HOWEVER, there is a problem with the graphics chipset, for the dv6000 series of HP Pavilion Notebook PC's.
More specifically it isn't actually the graphics chipset itself, but the mounting of the graphics chipset to the motherboard.
More on this in a moment.
External VGA monitor shows a good display;
Video Cable:
The video cable is checked for apparent damage first, and at the same time, see if it's connectors are tightly plugged in.
On one end, the video cable is plugged into the motherboard.
(ALL power removed, AC adapter { Charger} and Battery, the Switch Cover is removed, and the Keyboard, far enough to lay it back out of the way. Keyboard Cable still attached to motherboard. The Display Cable is the one to the Far left, right under the left side of the LCD screen. The cable next to it, to the immediate right, is the Microphone Cable )
The video cable routed from the connection on the motherboard, up under the left Hinge Cover, and into the Display Assembly, where it then attaches to the Back of the LCD screen.
THIS connection must be checked also.
{ Just gave advice similar to this earlier. The asker's problem turned out to be a loose video cable connection, on the back of the LCD screen }
Examine the sheath of the video cable. See if there are signs of damage. If so the tiny wires inside the cable could be damaged.
Apparent damage or not, you may want to remove the video cable, and perform a continuity check with a multimeter. (Ohm's. Check each wire in the cable)
Video Cable connections prove to be tight, video cable continuity check proves video cable is OK, move on to the screen Inverter.
Primer:
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, or a series of LED lights.
The Backlight is a CCFL for an HP Pavilion dv6000z Notebook PC.
[It is 2mm Wide, and 334mm Long. Or a little thicker than 1/16th inch Wide, and a little over 13 inches Long ]
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
A screen Inverter is used to convert power (Electricity) from the laptop, FOR the Backlight, and LCD screen.
90 PERCENT OF THE TIME the fault is a bad screen Inverter.
Example of a screen Inverter for a Pavilion dv6000z Notebook PC,
http://www.nylaptopparts.com/index.php?main_page=product_info&products_id=560
The thin plastic frame that surrounds the LCD screen, and is in front of the LCD screen, (Resembles a picture frame), is the Display Bezel.
The screen Inverter is located behind the Display Bezel, and at the bottom of the LCD screen area.
http://www.insidemylaptop.com/remove-replace-lcd-screen-inverter-hp-pavilion-dv6000-laptop/
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
External VGA monitor does NOT show a good display, it is a graphics chipset mounting issue, more to follow.
Regards,
joecoolvette
Jan 15, 2012 | HP Pavilion dv6000z Notebook
Hi, I was using my HP Pavilion notebook with Vista when it froze. The cursor wouldn't move and I was unable to do anything. I tried contol/alt/delete to shut it down, but that didn't work. I then held the...
you could have accidently changed to external monitor with Fn +F(the number is 8 on my comp but could be 5 on yours-check keys on top of the keyboard it has a picture rectangle / little TV), anyways to check that attach external monitor to your laptop(must have a VGA cable) if you have a picture on external monitor try Fn + F(depends on what you have on ur keyboard) it should bring you a window with choices to choose laptop LCD or external LCD choose 1st one .
hope that is it.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
HP G6000 laptop, screen completely green. top and bottom taskbars are black/ red flickering.
Seem like your video is going bad on the motherboard or your LCD screen. This is how you can determine which is going bad:
- Connect a monitor to the output and toggle Fn+F4 about 2-3 times or until you see video on both screens.
--If you have that same picture on the monitor then its the internal video....new motherboard needed.
--If you don't have that problem on the monitor then its with your LCD screen and it will need to be replaced.
IF THIS HELPS PLEASE VOTE.....GOOD LUCK AND THANKS..
Nov 12, 2009 | HP Pavilion dv6000z Notebook
My HP 9311 Tx does not give display on its LCD screen
after loading Operating system just press F5 and wait for 2-3 seconds. if display not appear try 1-2 times. it will come. plz replt if ur problem solved
Apr 10, 2009 | HP Pavilion dv9000z Notebook
Screen always flicering
If the screen is flickering then I would assume its a dry solder on the inverter board or the LCD panel is about to die. Are you skilled in electronics?
Feb 19, 2009 | HP Pavilion F1903 19" Flat Panel LCD...
Audio and vedio drivers
Go start run then type DXDIAG and let me know for system models and i will find right driver for you!
Jan 06, 2008 | HP Pavilion dv9000z Notebook
HP f1903 LCD Monitor mild flickering & color variance
I would bet it is the cable or connection. Have you tried connecting the monitor to a different PC?
Feb 14, 2007 | HP Pavilion F1903 19" Flat Panel LCD...
SPARKLE Computer GeForce 6600GT, (128 MB) AGP Graphic Card Logo
191 people viewed this question
Top SPARKLE Computer Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a SPARKLE Computer Computer and Internet Expert? Answer questions, earn points and help others
