Question about Kitchen Ranges
How to replace light globe in Chateau Grange rangehood
Chateau Grange rangehood which I assume would be at least 7 years old and I cannot work out how to access the light to change the globe which is not working?
  • rexwarehouse May 11, 2010
    If this is the light holder then the bulb will twist a half of turn to remove. Never seen this rangehood but from all indications it is from Austraila.
  • Anonymous Mar 18, 2014
    chateau grange ranghood 500mm
I have a 600mm Chateau range hood with the same problem. To access the globe chamber, you need to first remove the plastic diffuser from the underside of the rangehood. Located at one end of the diffuser will be a small slot approx 10 mm long. Insert a small flat blade screwdriver into this slot and carefully depress the plastic tongue of the diffuser by gently pushing the head of the screwdriver away from the diffuser. As the tongue disengages from the frame you should be able to grasp the edge of the diffuser and pull it away from the frame. Once the diffuser has been removed from the frame, you will be able to change the globe.
To reinstall the diffuser, insert the plain end of the diffuser into the frame of the the rangehood (above the globe) and gently push the clip end back to its flush position.
Posted on May 22, 2010
  • Anne Berry-Smith Mar 31, 2012
    Hi there I am looking for new filters for the same range hood- ie Chateaux Grange. Any ideas of where to obtain....thanks heaps
  • jan3989
    jan3989 Sep 28, 2012
    I've got a model C991N (dated 1997). there is no slot, but I could lever the diffuser out anyway
Torin E13 Rangehood. Blown light globe needs replaceing
Gee I think I could figure that out by looking at it .
Jan 17, 2016 | Kitchen Ranges
Robinhood grange change light bulbs
If you are talking about the front lights, there may be an access panel in the wheel wells.
Aug 30, 2014 | Cars & Trucks
Lights not working in Technika Rangehood (900m Model - D8900HASS)
TECHNIKA Pty. Ltd. 77 FILLO DRIVE, SOMERTON, VICTORIA 3062 PH 03 9948 4500 TOLL FREE
ABN 38 069 686 326 PO BOX 543, SOMERTON, VICTORIA 3062 FA X 03 9948 4555 1800 649 969
Online customer care contact for support: http://www.technika.com.au/contact
Dec 05, 2013 | Dryers
Technika rangehood parts
please follow the steps and fix it. God bless you
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
May 27, 2013 | Microwave Ovens
We have a keruig model 4o and the temp dose not seem to be hot enough please tell me what i can do to correct it thanks, John White La,Grange.N.c.
KEURIG will first tell you that the temperature is pre-set. then they ask if you are using room temperature water. Also you have to make sure you PUSH the K-Cup into the holder to make sure it works probably. If it is under a year old they will replace it free of charge.
Contact info from their website
Phone:
1-866-901-BREW (2739) Representatives are available 7:00 am to 12:00 midnight EST, 7 days a week Fax:
1.781.245.1869 Mail:
Keurig, Inc.
At Home Customer Service
55 Walkers Brook Drive
Reading, MA 01867
Nov 28, 2012 | Keurig Elite B40 Coffee Maker
Rangehood lights not working
I have a Fabyka Range Hood and know three other people who have had this exact problem (i.e both lights go out simulatneously but fan works fine). In my case I was able to pin it down to the transformer used by the halogen lights. This is an electronic transformer so it is less tolerant of power surges and such.
In the case of Fabyka the transformer is a black box connected to the inside of the hood with sticky tape with a black and white wire and two red wires. It is only used for the lights.
It is connected to the AC power via a black and white wire. you can disconnect this and us an LED power tester (about $2-$5 at most hardware stores) and see if you have power when you hit the switch.
In my case it is a 70W 120v to 12v halogen transformer. You can by a replacement off Amazon for about $12 including shipping or you can by a new one from Fabyka for about $30. I would suggest getting a slightly higher wattage transformer (I bought a 105watt for a dollar more).
You will need to disconnect the power before replacing but it is an easy fix.
1. Disconnect the AC power connector (black and white wires.)
2. The red wires coming out are the 12volt lines. If there is a connector, you can disconnect this, if not, you may need to cut these off.
3. Pull the tranformer off the back of the inside of the hood.
4. Cut the connectors off the old transformer. (Unless you buy Fabyka's.)
5. Connect them to the new transformer using wire connectors or crimps. (Make sure you connect black to black, white to white, and red to red.)
6. Make sure you have no exposed wires.
7. Connect to the corresponding connectors inside the hood. Connect the AC connector last.
8. Verify that the lights work properly.
9. Use sticky tape (or Gorilla tape) to attach the connector to the inside of the hood.
10. Enjoy the light.
Jul 17, 2009 | Kitchen Ranges
Replacement of Light globe in Ice Dispenser
USE LESS THAN 5W GLOBE IF AVAILABLE
OR
7 W IS A STANDARD GLOBE BEING NORMALLY USED, WILL & SHOULD NOT AFFECT THE POWER CIRCUIT AS PER MY EXPERIENCE
BEST WISHES
Dec 12, 2007 | Refrigerators
Kitchen Ranges Logo
2,391 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
