Question about Viking VGSC306-4B Gas Kitchen Range
I have a 30" NG gas Viking range. Oven will not ignite / operate. Broil works fine and top burners work fine. replaced oven ignitor and electric valve/seleniod that turns the gas on/off to the oven. Any suggestions
  • Richard Bedwell May 11, 2010
    the control panal is bad.
Call a viking repairman
Posted on Nov 18, 2009
Top oven not heating up on BAKE, broiler gas and flames come on. Stove top burners work, Bottom oven heats for BAKE and BROIL.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jan 08, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
I replaced what I thought was a bad igniter.But still had no glow from new igniter. Must be something else.Where do I go from here?
Hello there: The oven bake burner and ignition components are located beneath the oven cavity. In most cases the oven bottom panel can be removed for access (check your owner's manual) but on some models the oven burner has to be accessed from below in the warming or broiler drawer area. If accessing from the top, a 'flame spreader' (flat metal plate) above the burner may also need to be removed to see the burner itself.Many ovens use a single oven burner in which case they only have a single gas valve and ignitor. The same burner is used for both bake and broil functions, the broil usually being in the drawer area below the oven. Higher-end models may have a separate bake and broil burner. On such a system there will be two ignitors, one for each burner. They may also employ a 'dual' gas valve (see illustration above) instead of using a separate valve for each burner.Some range models may have an additional broil burner located at the top of the oven cavity which may be referred to as a 'waist high' broil. If not, broiling usually takes place in the drawer area below the oven, which uses the same bake burner for the broil function. Most gas ranges currently available employ one of 3 basic gas ignition systems; pilot ignition, hot surface ignition system (which uses a 'glow bar' or 'glow coil' - aka an "ignitor") and a spark ignition system. The latter two being referred to as "electronic ignition" systems as they use electricity in one form or another to operate the oven heating system. Only the pilot ignition system has an actual "pilot" (which is a small but real "flame") which might need manual lighting.
If the surface burners of a range are a spark ignition type, the oven IS one of the possible kinds of electronic ignition systems and thus will not usually have a "pilot" which needs lighting. Be aware though that just because the surface burners might light via a spark doesn't necessarily mean the oven uses the spark type ignition system too.
There is one older style of electronic ignition system which does also use an oven pilot but it is very rare and such a system hasn't been used in oven models since the early to mid 70's. It is the 'constant pilot' *electronic ignition* system.
Making Observations
The oven burner's operation will usually need to be directly observed while in operation as the first step to troubleshooting problems.Ignition System Type Links
Ignition System Types:
  • Pilot Ignition
  • Electronic Ignition with Constant Pilot (rare)
  • Electronic Ignition with Glow Ignitor (most common)
  • Spark Ignition System
  • Is there continuity between the oven gas valve's terminals?
    Hot Surface ('Glow Bar') Ignition System (most common)
    This is the most popular system currently used for ovens and is comprised of a control mechanism (whether thermostat or electronic control), the oven ignitor and an oven gas valve.
    What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame.
    It should usually only take in the area of 30-90 seconds for the oven ignitor to reach the proper resistance to allow the proper amperage to reach the gas valve to open it and for the ignitor to ignite the gas at the oven burner.
    Dec 30, 2009 | GE Ovens
    Have a Viking range, gas top, electric oven, neither work.
    Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
    Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
    KENMORE GAS STOVE OVEN LOWER BURNER WON'T WORK
    Most likely a hot-surface ignitor has failed. If it doesn't consume enough current, the gas valve won't open. It's usually a fairly easy fix, once you gain access to the ignitor and have a new one to replace it with. Make sure you unplug the range...
    Apr 25, 2009 | Ovens
    Oven won't broil
    You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
    Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
    Oven out/flat top has hot spot/burners ticking everywhere
    heatman101
    Jan 11, 2009 | Viking VGRC605-6 Gas Kitchen Range
    Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
    No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
    Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
    Burner ignitor will not turn off after the burner lights Viking
    replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
    Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
    Viking VGSC306-4B Gas Kitchen Range Logo
    498 people viewed this question
    Top Viking Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    paulcarew
    Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
