Question about Cameras
Will not power up
I just took the camera off the charger. all lights sre green, full charged. When i turn the camera on, the lens moves, a startup picyure apperars in the viewer, then everything goes off. If i switch it to look at pics on the disc, everything works in the viewfinder. Only when i try to turn it on, does it not work and shut off. any help would be appreciated....Jim
    Scholar:
  • 78 Answers
There are several reason why digital camera doesn't stay ON even when the batteries are fully charge or use brand new batteries. You can try to do the following steps to make sure that there is something wrong on the camera and not just batteries.
- Remove the batteries from the camera and the memory card
- Make sure that your using a brand new batteries
- Clean the battery contacts with a clean dry cloth
- verify that the batteries are inserted correctly
- Set the camera in Auto then turn it on
[Listen if there is a grinding sound on the lens part of the camera.]
Most Digital Camera turn itself Off when the lens won't zoom. So, if your camera start up and lens moves before it turns off and you can switch it on a different mode and it works. You need to contact your camera manufacturer and have the camera sent for repair. It might be wiring issue on the lens part of the digital camera
Posted on Nov 18, 2009
Turns off right after startup chime lens does not retract
This can happen when you use a battery that is almost without charge. Please remove the battery and charge it, before placing it back. Then be careful not to touch the lens, till the camera has a chance to retract it.
After you place the battery the lens should retract.
If the battery is really charged. You should not think it is charged, because you had it on the charger till the light indicated battery full.
There is also a chance you stopped the lens while it was coming out. A sensor detected this. To avoid damage to the lens construction, the camera switched off automatically. Also remove the battery and after a few seconds replace the battery and switch on the camera. Careful you don't touch the lens again.
Dec 26, 2013 | Sony Cyber-shot DSC-H5 Digital Camera
The battery wont stay charged .when you plug it in to charge the green light comes on ,when fully charged the red light is on,when you turn it on no power
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Mar 30, 2010 | NRS Hoveround MPV 5 - Used Power...
Camera turns on then off immediately
Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
Pls test with an alt. batt.
If you do not have access to a dif. battery.
Pls. take the batt out of the camera. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the batt. If not you will need to order a No power repair.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Nov 04, 2009 | Kodak Easyshare M893 Digital Camera
Vivicam 8300s
I've been struggling with the same problem and could not figure out what the heck was goin on. When I would connect the camera to the charger the red light (indicating charging) would come on for like maybe 10 minutes. I could take pics for like 30 minutes then the camera would lose juice. Also, the green battery icon (indicating a full charge) would only stay green for like 1 minute then it would go right to the yellow battery icon (half charge). After a couple of weeks the red light indicater would only come on for like a second. I played around with mine and realized that the battery terminals were not connecting to the power source inside the battery holder. Basically the battery wasn't snug enough inside the battery holder to connect to the power. When I pushe the battery in with my finger the red light indicater would stay on. So I took a little piece of paper (folded slightly) and wedge it in the battery holder and closed the battery holder cover. Hope this makes sense! (And helps.)
Feb 28, 2009 | Vivitar ViviCam 8300s Digital Camera
Kodak Easy Share M873 suddenly not working
What happened is that the camera got turned on in your pocket or somewhere and the lens got jammed trying to open up. The problem is that the outer lens ring is not turning all the way and the camera doesn't fully load.
Solution 1: Put the camera into the charger, press the power button so the green light is flashing, unplug it from the charger. The camera will try to realign its lens. (You might have to do this a few times.)
Solution 2: Manually help turn the outer lens ring clockwise when it turns on.
Oct 29, 2008 | Kodak EasyShare M873 Digital Camera
Battery pack or charger
Hi!
When you insert the battery , plug the power into the charger and the light turns ON (red or green) - the charger is OK. One indication that the battery is dead is when you charge it, after just a few minutes the full charge indicator will turn ON ( with Canon chargers the light for full charge is green). If that's the case, purchasing a new battery is the only option.
Have a nice day!
Oct 02, 2008 | Canon PowerShot SD600 Digital Camera
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Kodak Easy Share Z1275 stuck lens
I have a Kodak 1275. Green light would go on the off and lens was stuck open. Now for solution that worked for me. Get a can of compressed air, like what you use for computer keyboards. Blow the compressed air all around your stuck open lens, not to fast and switch directions of where you blow air around stuck opened lens. Make sure batteries are fresh and fully charged. Tap your camera against the palm of your hand twice, not to hard or you may damage instead of jarring lens lose. Next lay your camera on a table lens facing up, push power button on so camera will try to auto focus and lens should reseat itself and lens should move freely. It doesn`t have to look dirty or dusty, little tiny particles can cause the lens to get stuck and shut off fast because it is a safety feature. If this does not work try plugging your camera into computer so the lcd screen does not try to go on , thus giving even more power to get your lens moving . Do not try to force it closed by pushing or twisting with your hand or you may cause damage that will cost as much as the camera to fix.
Jun 05, 2008 | Kodak EasyShare Z1275 Digital Camera
Camera won't turn on
If when you press the power button the little green light on the right blinks it indicates that your circuit board is still ok. It would most likely be a bad lens unit. If you press the power button and the little green light does not blink you have a bad circuit board and it needs to be replaced.
Jan 24, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
SOLUTION: Fot the past two years, fully charged NiMH and new alkaline (generic and fresh Name Brand batteries) in my CX7530 always gave a red light and immediate power off -- symptoms of low batteries. Today I tried it again with the same problem. This time, I folded up a small piece of stiff paper to depress the small Lithium battery module detect switch in the battery compartment, and put my NiMH batteries back in -- it WORKED for the first time in two years! After removing the paper and reinserting the batteries, it still works. I suspect this somehow recalibrates the low battery detect circuit. I hope it helps you as well.
Oct 18, 2007 | Kodak EasyShare CX7530 Digital Camera
Cameras Logo
83 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
