Question about Canon BJC S200 InkJet Printer
Not taking in paper
I have fed it the paper but it still showsthe out of paper sign .But when it accepts the paper it of takes it from the right side & then it again shows out of paper sign.
    Master:
  • 619 Answers
Clean w/cotton tips one drop of rubbing alcohol the feeding roller and also outgoing rollers.
Posted on Jan 10, 2008
Paper does not go in straight when manualy fed and begins to crumple
When this happens it is usually because there is a small piece of paper stuck in the paper's path, probably just the other side of the roller. If the printer is meant to take listing paper with holes in the edge, it is very easy for a piece to break off because the edge is perforated. Often printers have a 'straight through' pass and you can access the back of the rollers via a door at the rear of the machine.
Make and Model of the printer are useful in such questions :>)
Dec 08, 2017 | Kip 1800 - 1880 toner Case contains 5 -...
Paper is not being fed from paper holding drawer. sometimes makes clicking sound. Copier does work when single piece of paper is fed through right hand side of machine
It sounds like the feed tire is dirty, OR the feed clutch has sprung. Remove the paper tray On the right side of the copier where you feed the single sheet, you pull down the door. This exposes a fat gray or black feed roller. Take a clean dry towel and dampen it with wd 40. Gently wipe the roller with the cloth turning the roller toward the paper exit direction. Let the WD 40 soak in for ten minutes, replace the paper tray and try to make a copy. If it does, you need a feed roller which will rquire a service cal/take it in. If still no feed the 'clicking' may be a sprung clutch, service call required.
If this helps, please let me know with a vote, thanx
Jan 30, 2011 | Canon PC-980 Color Copier
Paper jam/no paper fed
make sure the photo paper is in glossy side face down,
set the paper type to photo.
If it keeps jamming it's because the paper feed is probably dirty and not taking the paper properly
Mar 24, 2010 | Brother DCP 130C All-In-One InkJet Printer
My daughter fed an inkjet iron on transfer and is
Sometimes paper jams (and iron on jams) can cause the paper (or iron on) to get stuck in areas that are not visible to you, usually on the sides of where the paper would go. I don't know the specifics of your particular printer, but I would take a look at the guides on the side of the paper path and there are usually several screws that you can remove or loosen so that you can verify that the paper path is clear. Hope this helps and good luck!
Mar 13, 2010 | Konica Minolta PagePro 1350W Laser Printer
Major paper jam - all the paper has fed into the printer
Take the printer to a qualified technician, for proper repair, if you don't know "HOW" to properly disassemble/reassemble your printer.
Jan 14, 2010 | HP PSC 1510 All-In-One InkJet Printer
Canon pixma ip 1600. paper feed mechanism faulty. will not grab paper and feed through or takes it through at an angle
You said that the paper is fed on one side. Am I right?. If it so,it seems that another material is present inside your printer.
Please check this post for more information
Nov 29, 2009 | Office Equipment & Supplies
My printer won't use regular paper
If there is nothing extra inside, like paper clips, candy, push pins, the roller that feeds the paper may be broken. Feel the rubber roller in the back that pulls paper in, if it flops up and down at all the end may be broken off and a dealer would need to replace it. Look real close with a flashlight and small mirror and see if something has fallen in where the paper goes.
Jun 23, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Paper feds but does not stay alligned. It crinkles paper and pulls it to the right.
something seems to be wrong with the rollers that pull the paper thru. probably one side pulls faster that the other or the other does not pull at all. I recomend you take the printer and get it repaired at the service.
Feb 22, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Canon BJC S200 InkJet Printer Logo
46 people viewed this question
old marine
old marine
