Question about Dayton Gas Furnace Heater
I have a dayton fuel trimmer gass furnace in the garage. the electonic ignitor does not light the furnace. the fan will come on after about 5 min. the number on the name plate is 3e406d
After fussing with the furnace for a couple of weeks of double checking everything i found that the switch for the exhaust was triped. i had checked it 3 times and i thought that it was in the reset position but i found that when i reset it with a pocket screw driver that is was not reset. thanks for the information on your sight.the furnace has ben working for the last 2 weeks with no problem. the dogs will be happy this winter
Posted on Nov 27, 2009
2 Suggested Answers
  • 31 Answers
SOURCE: I have a dayton fuel
I have the same heater,every winter I have to bleed the gas line & push the spill switch on the heater. hope this helps you
Posted on Dec 30, 2010
Where is the summer/winter switch located on Dayton Fuel Trimmer furnace model 3E438A.?
The typical 'summer/winter' switch is an added switch associated with OLD heating systems back in the 50's and 60's before central air conditioning became common in homes. I doubt that your new furnace had one installed because you can accomplish the same thing by switching the fan on at the thermostat sub-base. That is, of course, providing you have a subbase with 'fan-on-auto' on it.
Jan 07, 2015 | Dayton Heating & Cooling
I have a hanging Dayton in garage pilot lights fine furnace fires up runs 6or7 min. then burner and pilot go out
Does unit fan come on ??? Is flue clear as most units have a safety klixon if exhaust not venting properly.
Nov 24, 2012 | Dayton Gas Furnace Heater
Furnace fan runs costantly
Check to see if fan setting is summer or winter.
Feb 05, 2012 | Dayton Gas Furnace Heater
Dayton 3e226e fan runs but burner will not light
Hello, since the inducer motor is running this can be either a bad ignitor or a pressure switch problem. Jump the pressure switch to see is the furnace will run, if it does there is a problem such as clogged vnt pipe, tubing clogged from switch to inducer motor, or the switch itself is bad. If it does not run most likely a bad ignitor
Nov 13, 2011 | Dayton Heating & Cooling
Furnace will kick on, begin heat up, go to the point where the fan should start and the whole thing shut down. If I move the thermostat down below the temp it show, it will start again and do the same...
Sounds like the blower motor is bad and then the unit is kicking off on high limit....
Probably nothing you can do with out getting a new motor to replace the bad one...
heatman101
Feb 02, 2011 | Dayton Gas Furnace Heater
Have 30,000 btu Dayton heater m#3e3665 when reaches temp. fan
Hi blow heater out with air line flame sensor could be dirty check out pressure switch jump this out see if it lights
Feb 09, 2010 | Dayton (3E379) Heater
I was wondering if the Dayton fuel trimmer model# 3E369B can be placed on blocks in the floor of my garage
Yes, it can be set on concrete blocks or anything non-flammable.
Also make sure that you do not run it if you are working with flammable gases or materials. I don't believe that that heater is sealed combustion.
Make sure also that you have correct venting so you don't wake up dead...
If you can take good precaution then go for it...
Heatman101
Jan 14, 2010 | Dayton Gas Furnace Heater
Need ignitor and gas valve for heater
They sell dayton stuff at Graingers
Dec 04, 2009 | Dayton G73 Utility Heater
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
Dayton Gas Furnace Heater Logo
764 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
