Question about Sony Handycam DCR-TRV130 Digital Camcorder
Batteries won't charge?
A year ago I purchased an original Sony InfoLithium NP-F960 OEM battery for my DCR-TRV130. I installed the battery and all was working fine. I plugged the a/c adapter into the camera to charge the battery. Within seconds the yellow charging LED started to blink rapidly. According to the manual that meant the battery was dead. OK, so I let it charge overnight. Same result. I conceded defeat and assumed I was ripped off. Recently bought a new battery, placed it in the camera and it worked great. But when I charged it, I had the same rapidly flashing LED. The camera works fine when the power adapter is plugged in. I put a meter on both batteries and they read 7.36 volts. The contacts on the adapter reads 8.39 volts.
It there something I'm doing wrong or do I own some expensive paperweights?
  • stevedawg989 Feb 17, 2008
    I also just purchased a Sony DCR-TRV130 and it will not charge my batteries. I plug it in to charge and the orange light will come on for maybe 30 seconds and then go back off. Twice it has blinked rapidly, meaning the battery was dead, and i left it overnight to charge and nothing. It works fine with it plugged into the wall.
I would return it and get a new one, and if that doesnt work then buy a different one because these ****. I am stuck with mine, but I wouldnt suggest it to anyone...
Posted on May 30, 2008
  • maximumclift May 30, 2008
    all i said with the ****'s was s u c k
Sony DCR-HC40E when turned on using battery (NP-FP50) power will display the following mesaage "Use InfoLithium Battery Pack" and then switch off.When on DC power it works fine. Also, when I...
It means the camera has detected that the battery is not genuine or not compatible. sony batteries has the data chip that provides the 'info' in infolithium.
check with the vendor who sold you the battery.
Sep 21, 2011 | Sony Handycam DCR-HC40E Mini DV Digital...
While inserting battery Sony NP-FP90 in my Sony Handycam DCR HC46 , it gives error mrassage " use infolithium battery and camera switch off Pls help
You can attempt to fix an InfoLithium battery which has developed passivisation by a process of charging and discharging several times.
try this while the camera is turn off.
let me know the outcome.
May 11, 2011 | Cameras
I have used my Sony Handycam DCR-SR40 and the battery went dead. I then charged the battery several times and still won't turn on. I even attach the camcorder to the Sony base and connect it to the...
This is usually caused by a failed component in the power circuit within the camera and can be repaired fairly inexpensively. However, it’s not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I’m a professional repair technician with over 20 years in the business and have repaired many of these. I’m semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on .
Sep 06, 2010 | Sony Handycam DCR-SR40 Camcorder
Battries run out of power,while camera is turned of.
The batteries on the DSC-V1 will be around five years old now so that's to be expected. You need to replace faulty batteries with genuine and new Sony InfoLithium NP-FC11. Many cheaper "compatibles" exist, but at best they don't last as long and will not give any battery charge indication (they lack the InfoLithium chip) and at worst they can damage the camera.
Unfortunately, genuine batteries are so expensive that you might decide it's time to upgrade, but as the DSC-V1 is such an excellent camera it's not a straightforward decision. Newer = more megapixels, but also = noisier images. 5MP is easily more than enough for prints up to A4 size even allowing for a bit of image cropping.
Oct 24, 2009 | Sony Cyber-Shot DSC-V1 Digital Camera
Battery NP-FM30
If you want to buy locally , here a list of the biggest Sony authorized resellers near Harrisburg,
In Harrisburg try:
Camera Repair Japan Co-
(770) 849-0555
One of the biggest ones is the one below in Lancaster.
Perfect Image Service Center Inc. 1862 Lincoln Hwy East, Lancaster - (717) 397-3019 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you want to buy online try one of the following sellers:
Sony InfoLithium M Battery NP-FM30, NP-FM50 ... $25.99 –
SONY Camcorder Battery NP-FM30 NP-FM50 NP-FM51$23.00
Feb 28, 2009 | Sony Handycam DCR-TRV250E Digital...
You need a separate battery charger for this camera. It does not have a battery charger built into the camera itself and can not be recharged thru any cords connected directly to the camera. The USB cords only transfer the files to the computer, they don't recharge the camera.
Dec 30, 2008 | Sony Cyber-Shot DSC-P50 Digital Camera
Battery life?
Here is a replacement source
The batteries are covered under warranty for three years. Sony batteries are know for not keeping a good charge after a few years.
If there not holding a charge, they wouldn't appear on the LCD screen at all. I the AC power is working fine, then that probably isn't the source for not getting a charge.
You could try lightly scraping the contacts on the battery and see if that makes a difference and recharge them.
Jul 18, 2008 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
PD150 battery problems
Sony has had a few large scale recalls of Lithium Ion batteries in the past 3-4 years or so. I have a feeling that NPF960s may have been involved. Best idea would be to contact an authorised Sony service centre and quiz them about it. You may score a free replacement battery out of it, even if yours is out of warranty.
Sep 15, 2005 | Sony Dvcam DSR-PD150 DV Digital Camcorder
Sony Handycam DCR-TRV130 Digital Camcorder Logo
250 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
