Question about Magic Chef CER3725AA Electric Kitchen Range
Magic Chef Oven 3888VRA beeps and shows F-1.
Magic Chef Oven 3888VRA beeps and shows F-1. Everything works but the beeping.
  • 6,784 Answers
Hi this is indicating a Defective touch pad or clock (ERC).
This simple test will help determine whether the ERC (Electronic Range Control board or Clock) or the touch pad is defective when F1 error code is present. Follow carefully, and with caution.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: Do not preform this test if you feel as if you are not qualified to do so. Contact your local service depot, if needed.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Nov 17, 2009
I have a magic chef stove Im not sure the age however it keeps beeping and showing me a F2 message
Hi pamelajo,
The failure code F2 means the Oven temperature is too hot. Please check the sensor harness. Replace relay board, if present, or oven temperature sensor (RTD).
Hope it helps.
Thank you for using FixYa.
Feb 07, 2011 | Magic Chef 31000 Gas Kitchen Range
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
MCO160UQ magic chef oven how to mute the beeps
Sep 05, 2010 | Magic Chef Ovens
1989 Magic Chef gas range digital display keeps beeping and says
This is a common failure in the control board. Here is an article that discusses the details.
http://www.fixyourboard.com/techzone/ovens/f1_error/f1_error.html
We repair a lot of these at www.fixyourboard.com, so you don't have to scrap out your oven.
Jun 26, 2010 | Magic Chef Kitchen Ranges
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
F 1 beeping on Magic Chef oven ?
The F1 code is a defect touch pad or membrane
May 01, 2009 | Magic Chef Ovens
Have a magic chef oven, f1 display after self cleaning, stove top works fine, any thoughts
F-1 is a fault code.
Disconnect the power plug or turn range power off at circuit breaker. Wait a couple of minutes, then plug the range in or flip the range circuit breaker to ON.
Oven control beeps & displays any F  code error (for example
F11) - Electronic control has detected a fault condition. Press
CLEAR/OFF to clear the display & stop beeping. Reprogram
oven. If fault recurs, record fault number. Press CLEAR/OFF
contact an authorized service agent.
Dec 01, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef electric range model # 3888VRA
Sounds like the oven control needs to be replaced.
Sep 24, 2007 | Magic Chef CER3725AA Electric Kitchen...
Magic Chef CER3725AA Electric Kitchen Range Logo
233 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
