Question about GE Profile WPRE6100G Top Load Washer
I think my machine is unbalanced. I had flooding
I think my machine is unbalanced. I had flooding and put wet rags in to wash. It would not spin.
  • maryjo0905 Nov 17, 2009
    I havn't worked in over a year--please help.
    Sergeant:
    Champion:
  • 289 Answers
I nead more in formation
Posted on Nov 17, 2009
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
I got a new heavy black Tee-shirt. I wanted to pre wash in case of 'bleeding'. No matter what cycle I choose, the spin was very slow, resulting in wet shirt. Why?
I am kind of going out on a limb here but I think you may have an unbalanced load which would affect the extraction stage. Have you selected the smallest load size and normal cycle?
Aug 04, 2016 | Haier Washing Machines
My Whirlpool Cabrio washer model WTW5610XW0 type 588-02 spins then stops and clothes still come out wet.
The washer is unbalanced, make sure it is level and the clothes are distributed even, if this have been check. put the unit on cold water and see how fast it comes in. Safety programmed into the unit if it takes longer then 10 minutes to fill it will just drain. This is to keep the washer from flooding out. Check the water inlet where the hose screws on, it could be plugged up with grit
Dec 12, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
Sometimes it spins sometimes it doesn't had a problem this morning with a king size quilt, it came out soaking so I tried to spin it again & its still wet, I put in another load & then it...
Duvets/quilts are very heavy when wet, causing a very unbalanced load. If the machine could spin such a large uncentred (UK spelling!) mass it would shake itself to pieces, so all modern domestic washing machines have unbalanced load detection systems. In use these systems will vary the drum rotation to try and get the load evenly distributed before going into full spin, but if they can't then no spin occurs.
Very few domestic washing machines can take a duvet or quilt (certainly no front loader which I'm aware of, and only a few top loaders), and those which can fit them in are usually overloaded. There's nothing wrong with your machine, you just need to use a commercial launderette machine to wash and spin your duvet/quilts in future.
Feb 16, 2011 | Washing Machines
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Noisy & shaking spin cycle and smell
The shaking could be your shocks beginning to go bad, an unbalanced load, unbalanced machine, or even possibly weak flooring. As far as the smell you can purchase a product called "AFFRESH" at your local parts distributor which works well to removed the mildew in the gasket. You just put the tablets in and run the machine through a cycle. You could also wipe the gasket out with a wet rag.
Be sure to leave the door cracked open between cycles this will help prevent mildew from building up.
Hope this helps _MJ_
Jan 28, 2010 | Frigidaire Washing Machines
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Spinning but clothes are still very wet ,
unb means unbalanced i had the same problem and i called comet where i got it from and they replaced the chip board and ever since then its been fine i hope this helps you
Jan 27, 2009 | Haier XQG50-QF80 Front Load Washer
GE Profile WPRE6100G Top Load Washer Logo
93 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
