Question about Frigidaire GLTR1670A Front Load Washer
How to remove timer
Looking to replace timer but dont know how to remove can you help please?
You should call someone who knows what they are doing...
Posted on Apr 25, 2008
I'm having the same problem. Does anyone know if it is necessary to dismantle the entire top of the machine, including the tub suspension springs?
Posted on Feb 23, 2008
I require a raco expert 736 user / operation manual
If this is a water timer start looking at www.raco-expert.com/en/products.php?serial=4
Dec 14, 2014 | Hardware & Accessories
My ge washer wbvh6240hww wont advance in time
the timer motor on the timer that advances the timer is defective,replace the entire timer as a motor for the timer will be just as much as a timer if its available separatelyanyway
May 16, 2011 | General Electric WBVH6240HWW Front Load...
Dryer will not turn off after cycle is complete
You Have a Broken Timer... There are metal points inside the Timer and can melt together so when the dryer reachs its end cycle they should come apart to leave the circuit open but wont since they melted together and continues to run. Also if the dryer has a computer board controling everything that would have to be replaced if it dosnt have a timer.
1. You will have to replace the timer if your going to accomplish this on your own you will need the model number which is located on the inside of the door opening will say mod or model.
2. You will need to find a appliance parts house in your area and call them to find out how much the new timer will cost plus to make sure they still make them and if on there shelf.
3. Once you have the new timer you will need a small flat head screw driver, 1/4" - 5/16" socket and a Phillips head screw driver to remove back panel bolts.
4. (WARNING) Unplug the dryer always make sure its unplugged or you risk being severly injurded or possible death the dryer has 220 volts running thru it!
5. Remove the back panel on the dryer where the dash is once removed you will see all the wires connecting to the timer. This is where the 1/4" or 5/16 socket comes in unless its a phillips head screw driver should be 1/4" some models will require a specail star bit normally on GE Dryers
6. Remove the timer knob should slide right off then remove the 2 1/4" screws holding the timer to the dash.
7. With new timer in hand make sure it lines up with the old one so you can put the wires back where they go (IMPORTANT THERE WILL BE 2 BLACK OR BROWN WIRES GOING TO A METAL LOOKING ROUND THING THATS THE CLOCK IT DRIVES THE TIMER LEAVE THEM WIRES WHERE THERE AT) now slowly remove 1 WIRE AT A TIME off old timer and connect to new timer where they go so you dont get wires hooked up to wrong post and fry the new timer if wires wont pop off yous your flat head screw driver to gently pry the wires off the post.
8. Place timer back where it goes there are aligment holes to help and replace the 2 screws you took out earlier from the timer.
9. Replace the back panel to the dash once completed plug in your dryer and replace the timer knob and set it to 5 mins let the dryer run till it shuts off to make sure its working properly.
If your dryer has a Computer Board the new board you order will have instructions for installing it alor the them are different on how the go in.
If unsure or dont want to fool with it call a qualified techinician to service your dryer for you but hopfully this will get you back going again have a good day.
Jan 05, 2011 | Dryers
My frig. is not cooling in upper areas of both compartments. I can here the compressor kick on, I cleaned all debris from condensor, its fan motor is working, but removed the panel on freezer side and...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 21, 2010 | Refrigerators
My dryer comes on but stays on, the timer switch is broken or something?
Hi, You can remove the rear panel on the controls and test the timer for voltage. There are two black wires going to the timer motor. Start the dryer and see if there is 120V going to the timer motor. If there is voltage and the timer does not move, replace the timer.
I hoe this gives you some help. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Dryers
Where is the hard drive located ?
moz-screenshot.jpgplease copy and paste the link below to access the user manual.
search hard drive as key word for easy reading.
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Compaq%20Presario%201230-1250.pdf
Apr 16, 2009 | HP Compaq Presario 2200 Notebook
Looking for a timer for a kenmore 90 series dryer Model M-460-G
HI, I would check the fuse in the dryer first. here is how: UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it. This is very comon problem and the timer will still make a noise when the fuse is bad.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Mar 22, 2009 | Kenmore 75944 Gas Dryer
My maytag MDE6400AYW was getting more and more difficult to start. I could pull the knob in different directions to start it, but now it wont start at all. I removed the starter, then the panel, then the...
no way around replacing the timer now. dont think youll get a rebuild diagram on this they come sealed form the factory, problem is they build these cheap a** timers with pull starts in them and they do have a tendency to fail.
Mar 20, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag Atlantis....how do I get the timer off the console ??
easy lau...ok since you have the console of ,,just go to the timer knob you see that round piece in center thats just a cap take screwdriver and pop it off gentle...noe remove that clip,,theres a spring under thre dont let it bounce away ,,easy,,now remove the dail just pull it of with your hand,,,ok see the 2 scerws holding the timer,,,orayyy,,if you need help im onthejob
Dec 31, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
60 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
