Question about Microsoft Xbox 360 Console
A game is stuck in the tray. The green light is
A game is stuck in the tray. The power button is blinking and the tray will not open.
    Problem Solver:
  • 13 Answers
There is a way to manually remove it. First you will want to unplug the power for a few minutes to let your Xbox reset. Re-attach the power cord and see if you can now eject your DVD. If that did not work turn the power off and unplug it. Remove the faceplate on you Xbox console. You will need a thick paper clip or something similar. Straighten one end of it out. With the faceplate removed you will see 2 small holes right underneath the DVD player and one hole to the right.
Since Microsoft decided to use 3 different DVD drives the procedure will vary. If you have a Samsung or Toshiba drive use the small hole on the right. Should be right underneath the X on the DVD drive faceplate. Push your straightened paper clip in the hole until you feel it hit the gear. The gear needs to be spun from left to right. Poke around until you find it then push in gently until you feel it move. You will see the tray start to move out.
For Hitatchi DVD drives go for the first hole on the left. Beng DVD drives will use the middle hole. This requires the most pressure to get the gear to turn. You will see the tray start to move take your time and do not push too hard in case you are missing the correct spot. Once the tray starts to eject you can pull on it slightly to help it open. You should now be able to remove your Game.
Posted on Nov 17, 2009
Once my game is loaded into tray the screen comes up and tells me to open back up and close again. This occurs all the time not just with one game. Any suggestions???
Yes. First when the tray is opened watch the green light . It should
blink then stay on steady.
When the tray is closesing you should see a blinking
green light in the center of the ring of lights .When the tray
is fully closed and engaged the light will stop blinking then you
should hear the drive spin-up. If not open the tray then close
it ,just as the tray is almost closed push it close hard then the
green flashing light should be steady on.
This is cause mostly by friction in the drive or a bent
leaf switch that the tray engages to tell the console
the state of the tray .
The remedy is either you or a shop
will need to open the drive and remove the frictions
points which very from drive to drive. and check the
leaf switches . cost 40.00 or so . or you could
simply buy a "new" drive on ebay and swap the
Drives P.C. board from the old drive to the new one
price 40.00 but you supply the labor.
I gave you more info than you need but this is
common problem and I hope it will help others also
If you have any questions please feel free to ask
Rob
Nov 14, 2010 | Microsoft Xbox 360 Console
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
My xbox keeps telling me to open the tray and wont play the game. i blew it out,turned the power off and on.can anyone help
X-box's are notorious for having bad hardware. Chances are, the drive is faulty. You may need to have it serviced or replaced. If you still have a warranty on your 'Box, I would suggest calling Microsoft and discussing this more in depth with them. Good luck!
Jan 29, 2010 | Microsoft Xbox 360 Console
My xbox now have an blinking green light and the tray would come out
The blinking green light is because your 360 is not understanding that the disc tray is closed. That's also the reason that the tray comes back open. It's not getting fully closed. Next time you insert a game push the drive closed with your hand. You'll know the drive is closed when the light stops blinking.
Dec 23, 2009 | Microsoft Xbox 360 Console
Power symbol on power button keeps blinking green and doesnt stop and doesnt open the tray or read discs
You might want to ask Xbox directly for this one.
Call them at (800)-469-9262
Email them here
Or use Ask Xbox
May 21, 2009 | Microsoft Xbox 360 Pro System Console
The power button symbole on the power button blinks green
Hi I will try to solve your problem. power on by the eject button tray should open fully if it goes back in by itself then its the belt that is on the motor you can see it sometimes when the faceplate is off
if it does this as it is opening give it a helping hand to come out fully
and visaversa going in also if you have an aftermarket faceplate on it the chrome or white facia on the tray interfears with it closing just take that bit off (carefully dont break it) if its the belt problem give me the thumbs up then I will know to post how to fix it easyily
May 18, 2009 | Microsoft Xbox 360 Console
Xbox360 tray ejects itself
The only thing i can think of is that something is stuck in the tray. Sorry about your luck
Apr 30, 2009 | Microsoft Premium System for Xbox 360
Ps2 cd tray does not open and the eject button light flashes
This is the tray getting stuck on the PS2 shell/casing. I can fix mine as it does the same thing but I tap it one quick time after I hit the eject button and it will usually open. Don't try to pry the tray open or this will make the problem worse.
Jan 08, 2009 | Sony PlayStation 2 (PS2) Console
Red and Green lights are together blinking continiously
I had this problem. The cancel button was stucked. Open the toner tray and slighly push the button side top-cover up. It released the cancel button for me (actually I was trying to open the top, but it worked). The cancel button was released and the blinking red-green stopped. Printer now working.
Mar 03, 2008 | Samsung ML 1610 Laser Printer
Microsoft Xbox 360 Console Logo
47 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
