I have an older electric oven with a noisy clock. How do I disable it?
    President:
  • 1,922 Answers
You will need to remove the rear upper access cover and pull the connections off the clock and tape them so they don't short out the rest of the unit
Posted on Nov 19, 2009
I have no electric power (i.e., clock, oven don't work) but the gas works fine.
Older stoves didn't have electric start so pilot stays lit on burners when power goes therefore burner will still light. Oven won't work since it probably needs electric power or has electric starter.
Feb 15, 2016 | Kitchen Ranges
How do I opetate my electric oven?
have you set the clock, quite often the clock flashing may well disable the oven.
Oct 01, 2014 | Ovens
How do I change Bosch oven clock from military time?
We have an older Bosch Oven (maybe circa 2010), and the way to access the special settings is to hold down the "Temp" button for 2 seconds which reveals a hidden menu of goodies. I made two changes in there--changed it back to 12 hour instead of military time as well as disabled the annoying beeps every time you press a button. Manual is here: https://media3.bsh-group.com/Documents/9000369981_A.pdf
May 17, 2014 | Bosch Ovens
Moved Kenmore electric oven (2 yrs old) and now neither the oven or stovetop heat up. The clock is set.
This may sound silly, but go check your circuit breaker and flip it completely off and then back on. Sometimes it does not completely trip and your clock only needs 120 volts to work which you have, but the heating coils need 240 volts. If you have an older house that has a fuse panel instead of circuit breakers you could have a blown fuse.
Feb 12, 2014 | Kenmore Ovens
Viking oven buzzes all the time when not in use
the low voltage transformer on the ERC control is vibrating from not doing anything,when you put a load on this transformer it will quit,only fix is to possibly remove ERC and jam a piece of NON-Flammable/NON-electrical metal to keep it from vibrating and try this first,if this doesn't help,replace the noisy board with this transformer on it
Jan 12, 2013 | Viking 27" Professional Select Built-in...
Old hot point oven clock is noisy. Can this be fixed. I haven't seen the oven so I don't have any details, sorry. It has chrome on it so I know it's old.
Those clocks are no longer made. To repair we had to remove and send to a rebuilding facility. I d not know if these places are still available but I would leave well enough alone until it dies completely.
Eric
Sep 15, 2009 | Ovens
Oven won't work - its a timer problem how do I reset the timer?
I believe the control's child lock function is enabled. To disable it, press and hold the cancel key (will have small padlock icon under the word "cancel"). That should clear the condition.
Dec 24, 2008 | Whirlpool RBS305PDS Electric Single Oven
DOUBLE OVEN,GAGGENAU
this oven could be in display mode this only allows non harmful functions to work eg lights etc but no heat this can be disabled through clock test prog reset but you will need an engineer to do it as complicated.
ring 08705 678910 for service and advise
good luck
Dec 16, 2007 | Gaggenau EB 270/271 Electric Single Oven
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
