Question about Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor
What size deck belt do i need for ys4500 42" cut
  • dontbother10
    dontbother10 May 11, 2010
    Hello, we are having a problem with self rating by our experts. If you did not rate this or do not believe it warrants a rating of very helpful please rate it as NOT HELPFUL. Experts cannot override your rating and seems to be the only way to stop this practice.
3 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: need belt for craftsman 42
You will probably need more info.
The belt is listed in your manual, if you have one.
If you can bring the belt in, a good auto parts store will have it in stock.
If you have the model no. we may be able to find the size for you on the internet.
Gary
Posted on Aug 21, 2011
SOURCE: Belt provided by Sears and installed according to
went over a rock now there is a bang sound like as if there is a rock in it can you he
Posted on Apr 23, 2011
DIAGRAM OD DRIVE BELT ON 46 INCH CUT HUSKEE MOWER
You will need the model number to find this info. Usually on a plate or sticker under the seat. The use a parts site like jackssmallengines.com or simply Google your make and model followed by "deck belt"
Oct 07, 2016 | Huskee Tractor Replacement Riding Lawn...
How to adjust tension on belt of John Deere Ride On D140
How to adjusted Cutting Deck Belt Tension
You do not say which size cutting deck you have. I will be writing about the 48", 3 blade cutting deck
The belt on this deck is self tensioned. The tension is provided by a spring attached to a moveable pulley on the deck. When the belt is in place you can manually force this pulley forward/backward and it will release the tension.
If the belt is off track, place the belt back around all the pulleys in the correct path, lastly force this spring loaded pulley forward/backward (depending on your deck, the direction is not important, the tension is) to get the belt around the pulley. If the belt is placed correctly, when you release the spring loaded pulley it will properly tension the belt.
Typically, these belts should not be jumping off. If yours is coming off frequently the belt may be worn. When they wear they get quite a bit longer, then the tension pulley cannot apply the correct tension. Rarely does the tension spring have to be replaced.
The other problem that causes belt jumping is worn spindles and stationary pulleys. The spindles are the most likely to need replacement. You can buy excellent replacements for JD spindles on Amazon for very reasonable prices. The following spindles are super replacement spindles for the 48" deck. They may very well be the same for smaller and larger decks; I have not researched that. Just search Amazon for Silver Streak # 285851.
Silver Streak # 285851 Spindle Assembly for JOHN DEERE GY21098, JOHN DEERE GY20962,
Product description:
Spindle Assembly / John Deere GY21098 Pack Size:1 JOHN DEERE GY21098, JOHN DEERE GY20962, JOHN DEERE GY20867, JOHN DEERE GY20454 OREGON 82-359, ROTARY 12910, ROTARY 11964 JOHN DEERE D100, D110, D130, D140,D150,D160, LA100, LA105, LA110, LA115, LA120, LA125, LA130,LA135, LA140, LA145, LA155, LA165, X110, X120, X140 Includes grease Zerk, pulley lock nut, blade lock nut, and washer , Height: 7 ", OD: 5 "
You can also find replacements for the flat pulleys on Amazon. If you cannot find what you need there, go to http://www.greenpartstore.com//
Mar 08, 2015 | John Deere D140 48 in. 22 HP Front-Engine...
John deere lx188 48 deck belt size
Contact John Deere directly to inquire about belt size.
May 26, 2017 | John Deere Starter Tractor Lx188 Kawasaki...
12 hp roper lawn tractor need belt size for blade drive
take a piece of rope and run it around all the pulleys a mower shop or parts store can match it to that
May 18, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need to fine out if it would what other size of belt you can use on 38 inch cut on poulan riding lawn mower
Are you asking what size belt to use or are you asking what other size belt, like you want to use one a little smaller or a little larger? If that is the case, what difficulty are you having that you would need to do that? Did you put a Craftsman deck on a Poulan or something odd like that?
Aug 06, 2011 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Diagram for belt on mower deck of an old Roper
I think I have a diagram for this, what hp is the mower 12hp? what size cutting deck? I have an old roper 12hp which needs a new belt but don't know what size belt to buy?
My email is richy.furlong@hotmail.co.uk
Sep 24, 2009 | Garden
Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Jul 02, 2009 | Mtd Garden
Craftsman 21 Hp 42" Deck, Ys 4500 Lawn Tractor Logo
818 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
