Question about Kenmore 20722
My 70 series washer does not spin. The washer made a banging noise (we thought it was out of balance) but still spun slowly through the first spin cycle. After the rinse cycle, the drum would not spin and the noise was gone. The water was drained, but the clothes were still soaked. I opened the cover and bridged the lid switch to look for problems, but it seems there aren't any visible moving parts (maybe that's the problem). Can someone tell me what the problem is?
  • Chaz Conrad
    Chaz Conrad Dec 01, 2009
    the model number is 110.20722990
    If the problem is the clutch, drive tube, or transmission assembly is the washer still worth fixing? I purchased another washer until I can get this one working.
  • 5,911 Answers
The problem is usually attributed to either a bad gearcase (transmission), or a broken motor coupling.
Since the washer still drained, this indicates the drive motor is still working as the drain pump is driven by the motor. The easiest (and least expensive) part to check first is the coupler. The coupler is located between the drive motor and gearcase and takes the place of a drive belt. This type of configuration is known as "direct-drive". The following link explains how to access and/or replace the motor coupling (if required):
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is comprised on three pieces (two plastic pieces with three tines, and a rubber bushing). Usually the tines snap off, the rubber bushing shears apart, or the center hole that the motor shaft is inserted rounds out and the coupling slips. Newer versions of the motor coupling have a steel grommet in the center to make it more resilient. The part number is included in the link I provided. A replacement can be purchased at appliancepartspros.com for about $11 or $12.
If you inspect the coupler and discover that is still intact, I'm aftraid you may have a gearcase that has gone bad. The gearcase price averages about $150-$160 if you wish to replace it yourself. If you wish to pursue the repair on your own, it is not difficult. The following link explains:
http://www.fixya.com/support/r699497-replacing_gearcase
A replacement gearcase can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
repairclinic.com
I hope I've given you enough information to work with. If you have any questions, or need assistance with identifying part numbers, please post back with your model number (located on a nameplate along the wash tub rim) so that I may be able to provide you with better assistance. I hope this helps you.
Posted on Nov 17, 2009
Testimonial: "jsrock516 gave a fantastic reply to my issue. The solution was very thorough and he was extremely well versed with my appliance problems. Thanks!"
Loud banging noise during spin cycle
If you balanced the machine, the only other problem could be the load itself. Either the load is too great or if washing a single item its falling to one side, tilting the drum and when spinning it will thump. Try even lodes.
Jan 31, 2018 | Washing Machines
Noise during spin cycle
check the counter balance weight
Jul 26, 2009 | Maytag SAV571EEWW Washer
MY SON LOADED A LARGE AMOUNT OF CLOTH INTO THE WASHER AND WHEN THE SPIN CYCLE CAME ON THE WASHER STARTED MAKING A HORRIBLE BANGING NOISE. it does not look like the springs are broken but the washer seems...
I'm suprised the unit was not able to spread a large load around to balance the drum. Maybe some item bunched up and made one side heavy. For a front loader, a proper load is just about all you can cram in there dry. You'll notice when the clothes get wet, they take less space, and when they are spun, there should be lots of room in the middle.
Apr 29, 2009 | Kenmore HE2 Plus Front Load Washer
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER MAKES A BANGING NOISE WHEN SPINNING
Try redistributing the wet clothes for better 'balance'.
Jan 08, 2009 | Whirlpool LHW0050PQ Front Load Washer
Not draining and spins a little but makes a whirring sound
you need to clean your pump something in your pump is causing your motor to work harder
Dec 26, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
386 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
