Question about Sony Cyber-Shot DSC-S40 Digital Camera
The shutter lens does not open then it says turn unit off and on again
3 Suggested Answers
avaya pimp
  • 23 Answers
SOURCE: shutter
try this:
1.turn on yer unit
2.press the menu button(if it gives you the "turn power off and on again message just switch to play mode or preview mode and access the menu from there.)
3.select setup(the option with the toolbox icon)
4.select setup 1 (not camera 1 ayt?)
5.select initialize and select OK for every prompt.
you\'ll know if you\'ve sucessfully initialized the camera if it will ask you to set the date and time.
if this does not work.... i guess it would be better to have th unit checked by an authorized serivicer.
maimai alovera
avaya ****
Posted on Jan 27, 2008
  • 291 Answers
SOURCE: shutter wont open
Try PhotoTech Repair Service, in NYC. They are factory authorized for most repairs, and are able to do warranty service in house. You can ship them your unit and, they are usually faster than the manufacturer, and cheaper! Plus if you join their facebook fan page they give you a 10% discount.
Here in the link to the facebook page, it has all the info you need.
http://www.facebook.com/pages/New-York-NY/Cell-Phone-Repair-NYC/312054784441
Hope it helps!
Posted on Apr 06, 2010
Camera won`t shoot
Have you tried taking off and then re-installing the lens?
Jun 29, 2010 | Canon EOS 40D Digital SLR Camera Digital...
Whiteout on fujifilm f20. how do I remove the lens?
Firstly, to isolate the shutter as the problem, turn the camera on and the flash off. put the lens into full optical (not digital) zoom. Then turn the camera lens to face you and look at the lens and take a picture.
With the camera in full optical zoom the shutter assembly will be right up to the outer lens so you can see it clearly. When the button is pressed you should see the shutter fire across the lens inside. It should cover the lens completely. If it does not or doesn't fire at all then you get over exposed pictures or lines across the photo. The most likely cause for this is moisture residue on the shutter leafs sticking them together.
To clean you will need to strip the lens down almost completely to access the shutter assembly. If this model of camera uses a sealed shutter unit then it will be impossible to clean. The only models i have found so far that use a sealed unit are the F460 and F470. Yours I am not sure of as I haven't opened 1 up but the solution for most is to strip it down and clean.
Tip: use another camera to photograph each stage to help on re assembly
Jan 18, 2010 | Fuji FinePix E550 Digital Camera
Nikon Coolpix S5 camera. Lens shutter remaining open.
From the manual: "Turn camera off and then on again. If error persists, contact retailer or Nikon representative."
Nov 18, 2009 | Nikon Coolpix S51c Digital Camera
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
The lens will not go in. seems like the shutter is stuck. when I press the power button, it feels like the camera is trying to shut the shutter but it cannot. then is says to turn the power off and try...
The problem is in your camera optical lens unit, actually the zoom motor start malfunction and this problem appears here is the part number and the description of the LENS:
Part No. Description
1-788-363-11 OPTICAL UNIT (ED13A)
Change the given part and your camera work fine again.
Thanks for using fixya.
Jul 27, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Shutter
try this:
1.turn on yer unit
maimai alovera
avaya ****
Jan 13, 2008 | Sony Cyber-Shot DSC-S500 Digital Camera
Shutter Won't Open
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... The part number is: 178739811 Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 09, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Shutter will not open/close (Disengaged from motor - "flopping" loose)
Well, replacement of the shutter unit (lens barrier)instead of the repair seems more realistic... Please contact your nearest Sony Service for the price estimate. If you need more info please advice. Arpi
Mar 19, 2007 | Sony Handycam HDR-HC3 HDV Digital...
Sony Cyber-Shot DSC-S40 Digital Camera Logo
21 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
