Question about Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dishwasher does take electricity
Our SGS 5332 dish washer is nt taking electricity while it was workin fine a day before
    Problem Solver:
  • 19 Answers
Check breaker, Check under sink and see if its plugged in there or hard wired underneath. You need to make sure there is actually power making it to the dishwasher. Check breaker box first
Posted on Jan 04, 2009
    Genius:
  • 1,003 Answers
MAKE SURE THE DOOR LATCHING MECHANISM IS OKAY IT HAS A SAFETY POWER SWITCH CONNECTED TO IT
ALSO USE VOLTMETER TO MAKE SURE THE AC SOKET ITS CONNECTED TO IS GETTING POWER
Posted on Jan 18, 2008
6ya staff
SOURCE:
My Bosh SHX7ER55UC door won't latch. Trying to figure out the 2-screwdriver method but can't figure out what part to push/pull.
HOW TO FIX YOUR BOSH DISH WASHER DOOR LOCK ...
? 11:11
https://www.youtube.com/watch?v=_uPK5mJmvZM
Jul 23, 2013 - Uploaded by Andrew Wallace
Dishwasher Door Latch (part #W10275768) - How To Replace ...Dishwasher Door Latch Replacement - Bosch DishwasherRepair (part ...
Nov 29, 2015 | Bosch 800 Plus SHX7ER55UC Fully Integrated...
Bosh dishwasher loose handle
I really don't wish to seem a jerk here, but your question leaves much necessary information out. Bosh makes more than one model of dishwasher, and that model information is essential for a good answer.
Additionally, a loose lever assembly may need something as simple as tightening a couple screws to full assembly adjustment. Also, it will make a huge difference if your children have used the door as a diving board, jumping on it as if it were a playground ride.
With 40 yrs in the industry, repairing dish washers,stoves, furnaces, and air conditioners; I have seen many remarkable things done by users to appliances. More information is needed to give you a real answer.
Mar 06, 2015 | Dishwashers
I think the rinse cycle is not working on my Bosh dishwasher. It is leaving a soap residue on the dishes.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Jan 14, 2011 | Bosch SHU9915UC Dishwasher
Main Motor won't start-up in my dish-washer model SGS 5302 GB/07 - How would I know if the capacitor was faulty ? there is no smell or no visible damage - could this be tested with a multi-meter ?
not easy to test without special equipment. if capacitor is faulty, then motor will not move but will get quite hot as current is passing thro the run winding but motor not being cooled.
it is not an expensive part - about £8 in the uk. note the value of the capacitor and you should be able to source from a friendly electrical dealer. that will be a lot cheaper than buying it as a manufacturer's spare part
Jun 25, 2008 | Bosch Dishwashers
Bosch Dishwasher Classix
Had similar problem on my Siemens which is the same as Bosh. I started to take it apart to see what had gone wrong. Eventually I had to disconnect the cable going into the washer - its in a small box at the front at the bottom. The wire nut connectors had melted and shorted out. Unfortunately now it won't fill with water. The smell was not like wood so maybe a different problem.
Mar 21, 2008 | Dishwashers
Bosh dishwasher not starting
Since the power is fine, now to get to the issue. You will need to pull the front panel and see if there is power to the on/off switch. There should be the same as what is at the junction box of the incoming power. If there isn't the proper voltage there, then you have a broken wire. If the voltage is there, then check the voltage going over to the control with the on/off switch in the on position. If power there and not lighting up or starting. Then the control is bad.
Jan 19, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh does no wash dishesses
Do you have any further information? Do you hear the water arms moving? Is this an issue of the detergent, possibly, or is this definitely something with the dishwasher? If it is the latter, I would suggest taking the racks out, and checking the bottom for anything clogging the works. A small lid or silverware may have dropped down there.
Dec 16, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Nov 30, 2007 | Bosch 23 in. SHU 8805 Built-in Dishwasher
Water/steam coming out of top right side.
where you see the steam use electrical tape over that area and see if it stops.it does sound like a seal problem but another thing to check is to make sure the unit is level.
Aug 25, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
170 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
