Question about RIM BlackBerry 8707v Smartphone
My Desktop Manager for Blackberry 8707V does not allow manual reconciliation of my emails via USB connection. Greyed out. IS there a way to manually sync (Do not have wireless)
How do i connect my bb 8900 to my pc?
I'm guessing you mean Blackberry.8900..
your blackberry should have come with a tools disk containing a copy of the program Blackberry desktop manager.. install this software and then you should be able to connect via USB (with the usb cable) or via bluetooth
you can download the latest version of Blackberry desktop manager from the RIM website
Jun 19, 2010 | HP Computers & Internet
Tip
Load applications onto your blackberry.
<span> <p>To load applications onto your BlackBerry, you need to work closely with your PC. On your PC, you use an <span>application</span> called <span>blackberry desktop</span><i> Manager</i> (BDM), which comes on a CD along with your BlackBerry. Application Loader is a mini application within BlackBerry Desktop Manager.If you have an employer-issued BlackBerry, your company might impose guidelines on what applications (if any) can and cannot be installed and uninstalled from your device. Be sure to familiarize yourself with your IT department's policy before attempting to install or uninstall software from a company-owned BlackBerry.<span>Accessing the Blackberry Application Loader</span>After BlackBerry Desktop Manager is installed on your PC, do the following to access Application Loader:<span>1. On your PC, select Start --&gt; Programs --&gt; BlackBerry --&gt; Desktop Manager.</span>BlackBerry Desktop Manager opens.<span>2. Connect your BlackBerry to your PC via your USB cable.</span>Doing so connects your BlackBerry to your PC. If successful, you see the password dialog box. If not, check to see whether the USB cable is connected properly to both your PC and your BlackBerry and then try again. If all else fails, contact your service provider, or contact your system administrator if you're an enterprise user.<span>3. Enter your password.</span>This completes your BlackBerry-to-PC connection.<span>4. On your PC, double-click the Application Loader icon in BlackBerry Desktop Manager.</span>The Application Loader Wizard welcome screen opens. At this point, you're ready to use the functions of Application Loader.<span>Using the Blackberry Application Loader</span><br /> <p> <span><span><span> <br /> <span> <p>To install an application onto your BlackBerry from your PC by using Application Loader, you first have to install that application onto your PC. The installation onto your PC varies, depending on which application you choose to install, so be sure to refer to the manual that comes with the application you choose.After you get the application onto your PC, you need to locate the application's ALX file (a file with the .alx extension). The ALX file isn't the file that gets installed on your BlackBerry; rather, it tells Application Loader where the actual application file is located on your PC. You can usually find an application's ALX file in the folder where you installed the application on your PC.you can install it on your BlackBerry by using Application Loader as follows:<span>1. Launch Application Loader from BlackBerry Desktop Manager.</span><br /> <p>The Application Loader Wizard welcome screen appears.<span>2. Click the Next button.</span><span>3. Enter your password, and then click Next.</span>If your handheld isn't connected properly, you see the Communication Port Selection screen. Connect your BlackBerry to the USB cable and make sure that the USB cable is connected to the PC. Then click Next.The Handheld Application Selection screen appears. This screen lists the applications that are already installed on your BlackBerry.<span>4. Click the Add button.</span>An Open file dialog box appears, which you use to locate the ALX file of the application you want to install.<span>5. Locate the ALX file and then click Open.</span>You return to the Handheld Application Selection.<span>6. Click Next.</span>Doing so brings up the confirmation screen, listing the application to be installed.<span>7. Click Finish.</span>The installation process starts, and a progress window appears. When the progress window disappears - and if all went well - the application is on your BlackBerry<br /></span></span></span></span><br /></span>
on Nov 23, 2010 | Cell Phones
I can not pait my blackberry with my laptop for picture trasfer
by pair I assume you are referring to bluetooth. desktop manager does not allow you to pair via bluetooth for media transfer, it only allows for data like call logs and contacts. try using the usb cord and then if you have a memory card select mass sotrage if you do not use the media manager tab.
you can download the latest version of desktop manager right off blackberry's website for free
Feb 10, 2010 | RIM BlackBerry Storm 9530 Smartphone
Phone is locked it wants to spell blackberry but the a is not working and the scroll button is red
Try removing and reseating the battery to reset the device. Once powered back up, then download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Connecting the uSB cable to your BB and computer will allow you to enter your password using the computers Keyboard.
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Jan 11, 2010 | RIM BlackBerry Bold 9000 Smartphone
Unable to receive emails on verizon blackberry
First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Jan 09, 2010 | Verizon Communications BlackBerry Pearl...
Cannot access yahoo email on blackberry
If the issue is still present, then it could be hardware related, and may need to be repaired or replaced. I would then suggest contacting your Provider for Hardware Support.
Jan 03, 2010 | Yahoo Mail
How do I load and coordinate my MS Outlook address book and calendar with my Blackberry Curve 8330?
Here is how you do it:
1Install Blackberry Desktop Manager Softwarewhich included in your Blackberry Installation CD. If you don’t haveone, you may download software from Here
2Make sure you set an Outlook profile that the Desktop Manager can use.3Start the BlackBerry Desktop Manager.4Connect your Blackberry with your computer via USB cable and allow Blackberry device driver install.5Click on Synchronize in BlackBerry Desktop Manager.6Activate the Synchronize organizer data checkbox: BlackBerry Synchronize.7Click on the Configuration tab. Then, click on the Configure synch: BlackBerry Synchronize Configuration.8Check the data you want your BlackBerry being synchronized to. Choose CONTACTS, TASKS, CALENDAR, and NOTES databases.9Afteryou check each item, the software will ask which application you wouldlike to sync it with, you will choose OUTLOOK for all.10Nowgo back to the Desktop Manager. Make sure that the SYCHRONIZE ORGANIZERDATA check box is checked. And select the Synchronize now button at thesynchronize dialog to begin synchronization.
Thank you for using FixYa! Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
Dec 30, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
8330 show no driver on desktop
Hi, When the BlackBerry device is connected by Universal Serial Bus (USB) cable to the computer, it is not detected as a BlackBerry Device on the Windows Device Manager. Universal Serial Bus controllers does not show any BlackBerry device, even though it has already been connected to the computer.
It is because Blackberry Desktop Manager drivers are not registering with the Windows operating system.
To resolve this issue,
1) Uninstall and reinstall the BlackBerry Desktop Manager.
2) Connect the BlackBerry device to another desktop computer to determine if the issue could be related to USB port hardware.
3) Update the BlackBerry device drivers manually.
I hope this information will help you.
Nov 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I cannot find pin email received
Try this solution: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Apr 08, 2009 | RIM BlackBerry Bold 9000 Smartphone
Red light
Connect via USB to computer and see if computer recognizes the phone, if it does back up phone using BB desktop manager and get the handheld software from your service provider or blackberry.com and redownload software via the application loader.
Jan 21, 2008 | RIM BlackBerry 7250
RIM BlackBerry 8707v Smartphone Logo
219 people viewed this question
Top RIM Cell Phones Experts
Computer Repairing
Computer Repairing
Longtime User
ismael castillo
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
