Question about Euro-Pro Shark GI490 Iron
Shark iron-61468-10 steam button stuck on dowm position.thf cap on the water well not ckose.brought iron on 5-10-09 at walmart.how do I get it fixed?
Pull the button up. You may have to coax it up; I pried it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only). Below the button is a stem that operates the valve, gently full it back up with a pair of needle nose pliers (careful - the stem is plastic). Replace the button (align the stem into the hole on the bottom of the button. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :) It seems like it sticks when the iron is left unused for a period of time; as if the valve sticks when dry. I'm going to leave water in it this time, although the instruction manual says not to.
Posted on Feb 07, 2010
Tip
How to release the stuck steam button in Shark iron-61468-10?
If the steam button is got stuck in the down position in your iron then follow this procedures to release the stuck button:--
1) First of all pull the button up. You may have to coax it up; you can pry it back to the up position with a needle. Grasp it firmly and pull it straight off (it is fitted in place by friction only).
2) Below the button is a stem that operates the valve, gently pull it back up with a pair of needle nose pliers (careful - the stem is made up of plastic material).
3) Then replace the button (align the stem into the hole on the bottom of the button to its exact position. Cycle the button a few times with water in the reservoir. You should be back in the ironing business now! :)
It seems like it sticks when the iron is left unused condition for a period of time; as if the valve gets stuck up when dry. leave water in it this time, although the instruction manual says not to. But leaving the water in it may not let it get dry.
This will help.good luck.
on Feb 28, 2010 | Irons
Steam Button Sticks in
vinegar the iron its calcified,it will clean out
Sep 30, 2009 | Euro-Pro Shark Rapido Electronic Iron -...
My shark iron get hot but it will not put out any steam none
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Sep 26, 2009 | Euro-Pro Shark GI490 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
Stopped producing steam
Iron not heating up sufficiently to produce steam. Threw it out!
Jun 24, 2009 | Euro-Pro Shark GI490 Iron
Leeks water sometimes and steam does not always work
I would trash it. New ones are very inexpensive now at Walmart, 10-20 dollars.
Mar 16, 2009 | Euro-Pro Shark GI490 Iron
Paid $50.00 for Shark model G1405Z. It lasted 3 weeks.
WalMart would have replaced it with or without a receipt for an identical priced product. You can take the bad one back with the receipt and ask for a refund, provided they ARE identical. The barcode is scanned onto the receipt.
Feb 12, 2009 | Euro-Pro Shark GI490 Iron
My husband threw away the opereating instructions for our iron.
SELF CLEANINGIt is important to “Self Clean” the iron at least every two weeksto remove scale, calcium, etc. The harder the water, the more often the iron should be self cleaned.1. Set the variable steam control dial to any steam position.2. Fill the water tank up to the “MAX” level.3. Stand the iron on its heel. Plug the iron into the electrical outlet.4.Press the electronic temperature control button until you get the “MAX” temperature setting on the display panel and wait until the iron heats up and temperature setting light stops flashing.5. Turn the variable steam control dial all the way to the right to the self-cleaning position and hold the iron horizontally over the sink (Fig. 8).6. Boiling water and steam will now be ejected from the holes in the soleplate. The impurities and scale are washed away with it. 7. Move the iron back and forth as this happens.8. If there is any water left in the water tank after the iron stops steaming, just empty the remaining water in a sink following the instructions for emptying the iron. 9.Turn the variable steam control dial to the “0” position when the water tank is empty.10.Place the iron back upright on its heel to cool down before storing.
Nov 23, 2008 | Euro-Pro Shark GI490 Iron
Brown water drips
This may be down to contaminants in your water supply, or any "ironing water" you may be using.
There will be a build up inside the hotplate where the water is vapourised.
To clear this, refer to your manual or simply put on high steam setting, rest on it's heel, and wait for the indicator light to go out, then unplug, and hold horizontal over the sink. Press any steam boost buttons you have untill the iron is cold - and you just get water flowing out.
The best and cheapest water to use I've found - is the condensate from condensing tumble dryers. Which most people just tip away! It is condensed steam - so contains no minerals to fur up irons. If you don't have one - ask a neighbour for a few gallons.
Jun 29, 2008 | Euro-Pro Shark GI490 Iron
Euro-Pro Shark GI490 Iron Logo
1,128 people viewed this question
Top Euro-Pro Irons Experts
Henry  Thomas
Henry Thomas
Are you an Euro-Pro Iron Expert? Answer questions, earn points and help others
