Question about Ariens Garden
Where is the drain plug to change motor oil arien 8hp
3 Suggested Answers
  • 1114 Answers
SOURCE: I have an Ariens 16H40 and it has no extension
You can find the parts in the plumbing section of any DIY store (hardware store, Lowes, etc.), and make up your own extension. Take the plug with you to match up the thread size.
Just make sure the extension is not in the way of anything such as the deck, or in your way where you'd step on it.
Posted on Jul 02, 2009
  • 6468 Answers
SOURCE: How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Posted on Jun 28, 2012
This id an Ariens 8 hp reasr engine rider
areins RM830e I found some info on Parts tree and Utube for you, take a look Ariens 927025 RM830E Ariens 30 Rear Engine Rider 8hp SN 000101 004000... . If not the right one repost and exclude this model .
Mar 16, 2016 | Ariens Garden
Oil
10 W 30
May 02, 2013 | Honda 8 HP Engine
Where is the oil drain plug?
Usually the drain plug is located under the deck by the shaft. It looks like a inverse plug. Use a socket wrench to undo it.
Apr 23, 2013 | Ariens 21 In Classic Walk Behind Push Lawn...
Does the zoom 34" zero turn have an oil drain plug? if so, where is it located?
some of the newer engines have a oil drain that you turn a quarter of a turn that it drains look at the bottom of the dip stick tube
Jul 09, 2012 | Ariens Zoom 34" (Stamped Deck) Zero Turn...
Jun 27, 2012 | Garden
I have bougt an old Ariens RT 254 and wonder if I shall use petrol with oil or not.
I can't find anything on an RT 254, but if you meant RT 524, that is a rear tine tiller with a 5 horsepower gasoline (petrol) engine. That engine should not require you to add oil to the petrol. You can purchase a generic service manual which does includeyour tiller here if you like.
Or, just look for a crankcase oil drain plug which sticks out the side of the very base of the engine, and a fill plug, which is angled and higher up and usually plugged with a screw-in plastic plug. Take that plastic plug out and check the oil - in fact, if it's an old machine, I recommend you drain the oil (using the lower plug) and refill it (until it is at the level of the upper plug). In any case, this confirms you don't need to add oil to the petrol. Happy tilling! Please rate my solution if helpful, thanks.
Aug 15, 2010 | Ariens Garden
Ariens 8hp Formula rototiller with tecumseh engine- will not start.. have checked spark plug... gas was drained last fall. troubleshooting tips please
well you should really cheek your spark to see if you are getting spark by using a screw driver in the spark plug agents the metal and see if their is an arc from the points
May 04, 2010 | Garden
I have a 2005 ariens zoom 22/50 and it won't start. Battery and starter are new. Both work (tested) It doesn't seem to turn over. half a cycle and boggs down.
more info would be nice. did you check the oil ? may be too much oil in motor ,(may be gas in base) change oil if needed. remove plug or plugs,ground them, try starter now. (if there is gas in base, your float may be full of gas,"sinking",replace float", ) if motor still dosn`t turn, try removeing all drive belts,and try again.
Dec 13, 2009 | Ariens Garden
I have an Ariens 16H40 and it has no extension from the oil plug, to the outside of the mower to drain out the motor oil. Is there a part available?
Jul 01, 2009 | Garden
Garden Logo
79 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
