Question about HP Compaq d530 SFF PC Desktop
I have quite a few d530-SFF systems. They have the ''standard PCI'' slot ''carrier'' that plugs into 1 of the 3 PCI slots on the M/B and has 2 full-size PCI slots. I installed a PNY Nvidia GeForce 8400GS video adapter in the ''top'' slot on the carrier, but the system would not boot, no video, no network, nothing. So I tried the ''bottom'' slot, same thing. Tried a 2nd system, same result. Looks like the system just won't boot with the GeForce 8400GS in the carrier slots. When I remove the 8400GS, it boots right up. Can you assist? We're trying to use the 8400GS cards to setup dual monitors on these systems. Thanks! --Terry
  • 1 more comment
  • TLeBlanc22 Nov 18, 2009
    We have other "models" of this same type of HP workstation that do not have the "horizontal cage", just have the 3 low-profile PCI slots in the back. The card works in those units.
    I noticed that these HP units have an AGP slot for a video adapter. We were trying to have a common configuration, if possible, using the PCI 8400GS cards. Very disappointing if insufficient power is the culprit, since that's probably something we can't change.
    The HP unit where the 8400GS worked (with the low-profile PCI slots directly out the back) is a DC5000-SFF, an older unit. It's not a d530-SFF. Sounds like it has a larger power supply.
  • TLeBlanc22 Nov 19, 2009
    Yeah, tried that. Behavior changed, but only slightly...got a beep, still wouldn't boot. I unplugged the power cables from the floppy and CD, but didn't unplug the data cables.
    Most of the d530-SFF boxes have 2x1GB plus 2x256M sticks for a total of 2.5GB of memory (the 2x256M were original, the 2x1GB were recent additions to improve performance).
    May have found a solution, at least something to try. Worked with PNY tech reps both from my end and through CDW, did not find a workable solution within the 185W power limit of the d530-SFF.
    May have found a solution from ATI. The Diamond S60 card is a 64MB DDR PCI adapter, says it supports 2 monitors in the specs, but I only see a single VGA connector listed, along with a TV-out. Have 1 on the way, courtesy of CDW, to evaluate.
    Worst case, if I can't get 2 monitors both running from the add-in graphics adapter, we'll continue to use the Intel integrated adapter for one and the add-in card for the other. That's how we currently have the other 2 systems running with the 8400GS right now...have not yet tried to get the 2nd monitor up on the 8400GS, probably have to diable the integrated adapter to do that. Next phase...
    Scholar:
  • 101 Answers
I checked the specs on the video card thinking it must be PCI-e and not old style PCI but in fact there is an old style PCI meant for just what you are trying to do. The problem is the memory at 512meg plus the GPU put your power requirements at 300w and I bet you have at best 185w in those units so they won't even start and you won't be able to cram the bigger power supply in there. Go with a card that has lower specs and 64 - 128 ram and you should be ok. Just check the power req. JC
Posted on Nov 18, 2009
  • Jon Hunter Nov 18, 2009
    There is one thing you can try just for fun - unplu the power (and the data) cables to the floppy and disable it in BIOS. You would be surprised how much juice they use in standby and who needs 'em?
    You'll still be pushing the power requirements but it might work - it will also help to cut back on the # of ram chips if you can use higher density to get the same amount. Main users of power are the CPU, the video gpu, the CD rom when spinning (and the floppy).
    JC
  • Jon Hunter Nov 19, 2009
    You might want pull those 256 meg rams. They could actually slow down memory cycles and they really aren't going to do much for performance even if matched to the 1 gigs. If you unplug power cables you need to unplug data cables or some sytems will hang anyway. For that matter you won't see much diff over 1 gig in XP unless you are running Photoshop, video rendering or CAD - something with big files. In XP change your virtual memory to fixed size 1.5 times ram (preferably on fresh install on a clean HD) to improve virt memory.
    A half height card will usu. have the 2nd video on a separate backplane.
Is the video card PCIe compatible? I just assumed that by its age that it would be a standard PCI. I was wrong. Allan
System features of HP xw4400 Workstation on official HP web site state:
Expansion Slot
6 slots: 1 PCI Express (x16) Graphics slot, 1 PCI Express (x16 mechanically, x4 electrically), 1 PCI Express (x1) and 3 full-length legacy PCI slots
So it should work fine with modern PCIe graphic cards
May 20, 2011 | HP xw4400 Workstation - 1 x Intel Core 2...
What are the three expansion bus slots that are found on the mainboard?
  1. 1 x PCI Express x16 slot, running at x16 (PCIEX16) (Note 4)
  2. 1 x PCI Express x16 slot, running at x8 (PCIEX8) (Note 4)
  3. 3 x PCI Express x1 slot (All PCI Express slots conform to PCI Express 2.0 standard.)
  4. 2 x PCI slots
(Note 1) Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) The DVI-D port does not support D-Sub connector by adapter.
(Note 3) Simultaneous output for DVI-D and HDMI is not supported.
(Note 4) For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot. The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When PCIEX8 is populated with a PCI Express graphics card, the PCIEX16 slot will operate at up to x8 mode.
(Note 5) Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
(Note 6) Available functions in EasyTune may differ by motherboard model.
Feb 23, 2011 | Gigabyte GA890GPAUD3H AM3 Socket 890GX ...
Could you please recommend a graphics card for an HP 530 sff
This is the best one i could find that would meet your requirements
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161318
Jun 27, 2010 | HP Compaq d530 SFF PC Desktop
Firewire PCI card not recognized
Sometimes, when one is inserting a card, one does not push it firmly in place. If some contacts are not well established, the card may not be recognized.
Hope it helps.
Aug 22, 2009 | HP Compaq d530 SFF PC Desktop
ATI Radeon 9250 PCI card not recognised.
Make sure the slot isn't disabled either by jumper settings or in the bios, and the card is securely inserted in the slot. If these aren't the case, you have yourself a bad card, or a bad slot.
Apr 30, 2009 | HP Compaq d530 SFF PC Desktop
No Signal to monitor
Sounds like your integrated Video is at fault. You can add a Video card if you have an available PCI (white sockets) or AVG (usually only one and brownish) slot. I had a Compaq SFF and it did have one PCI expansion slot, so I hope you are not using yours if you do have one.
Apr 26, 2008 | HP Compaq d530 SFF PC Desktop
HP Compaq d530 SFF PC Desktop Problem - Graphics card: Updgrade
Try this site:
http://www.geeks.com/products.asp?cat=VCD
The ATI Radeon HD 2400 256MB PCI-Express VCD w/TV-Out DVI seems to me to be what you are looking for..
Good Luck!
Apr 18, 2008 | HP Compaq d530 SFF PC Desktop
Expanding RAM on D530 SFF
They go right next to the current ones you have in there. If no extra RAM slots are available, you would have to take out your old RAM to make room for the new ones.
There are typically only 2 or 4 slots for RAM.
Jan 29, 2008 | Compaq Refurbished EVO D500 PCO REFURB...
Reply to my motherboard
It looks like your trying to install a PCI Graphics Adapter. If that is the case, I would try the PCI Graphics Adapter any Slot other than Slot 1 or Slot 2. That is unless, your PCI Graphics Adapter Card is a PCI Express, then that must be installed in Slot 1, if the Board supports it. If the PCI Graphics Adapter is a PCI-I Card then it must be installed in Slot 2.
Check AMD's site, they have or already implemented standards on their support chips. The standard, as I understand it, is Slot 1 - PCI Express, Slot 2 - PCI-I, if you're using those Slot for PCI Graphics Adapter.
It should be possible to use those Slots (1 & 2) for any PCI Cards that is not a PCI Graphics Adapter, be careful, I have not checked that out. Those do not handshake as Video Adapter, so the PCI card should not be thrown or overdriven, the PCI-Express and PCI-I, to my knowledge is only for Grahpics Adapters, should that be different, then Slot 1 for only PCI Express Cards and Slot 2 for only PCI-I Cards.
Me, for now, Slot 1 for Express, Slot 2 for PCI-I, and the rest of the Slot for all else. If your PCI Graphics Adapter is not an Express or PCI-I, install in any Slot other than Slot 1 or Slot 2.
Dec 14, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
HP Compaq d530 SFF PC Desktop Logo
647 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
