Question about Danby Dehumidifiers
A part broke near the tank for the water. Is there any place where u can get another tank for the dehumidifier?
    Scholar:
  • 117 Answers
Do you put water in a dehumidifier
No, a dehumidifier takes water out of the air where it's placed. If it's very humid in the air, you should have a tank full of water after a few hours.
Nov 21, 2013 | Comfort-Aire BHD-501 Dehumidifier
I have a Zenith Dehumidifier, ZD309Y9 and the water tanks handle broke. How can I get a new tank?
Do a quick search for part # 4839A10004J - this should be the tank assembly for your unit.
Sep 27, 2011 | Dehumidifiers
Hello, I need a dehumidifier of 50pint or more that stop when the humidity level is reach and will restart when is too high. I look for a lot of brand and model and I cannot find one thanks for your...
The fifty pint capacity might be a challenge ... think about this ... 6 + gallon tank @ 7+ pounds per gallon ... 42 pounds of water to drag from the dehumidifier to the drain? Who is going to do that?
All dehumidifiers run at some % of humidity (via Humistat), (like you are asking about) i.e. come on at some % above the setting and go off when the setting is reached. I suggest you find one that has a standard one or two gallon tank that also features a hose connection in the tank. Run the hose from the tank to the floor drain in your basement or a drain near what ever room you are trying to dry out. When you connect the hose --- you will have to put a hole into the fitting on the tank for water to flow. The idea of the tank is that the machine will run on the setting until the tank fills up ... at which time the tank full switch will not allow the machine to run again until you dump the water (and you want to drag a 6+ gallon tank, 42+ pounds, around?) . If there is a hose attached, the tank never fills up.
Some dehumidifiers feature a pump to which will pump the water to a near-by drain. You may be able to rig such a setup yourself using a small pump like a fish pond pump or similar.
You may want to consider using two dehumidifiers (with or without hoses) rather than one BIG machine. I run two machines from a major USA retailer (one in each end of the basement) and they run into the near by sump and the system works fine @ my house.Thanks for your
Thanks for your question @ FixYa.com
Jun 05, 2011 | Dehumidifiers
I bought the eva dry e-333 on 4/30/11. I placed it near my toilet tank in the bathroom. Everything was working fine until two or three days ago. I noticed that the tank had water condensation and the eva...
You are trying to fix the symptoms rather than the problem. The problem is the water going into the tank is colder than the air in the bathroom, which cause condinsation on the tank. If you can, take the chill out of the water. By exposing the pipes, which may cause the pipes to sweat. Or cool the room air. Is the bathroom vented so that the warm moist air is carried outside? There are liners that go in the tank that work well. If you use a liner make sure you will still have enough water to flush with, as they will take up some of the water volume.
May 27, 2011 | Eva-Dry E333 Dehumidifier
How do you put floater device back in water tank
It should just snap back into place, inside the small compartment in the top left of the water tank.
When you snap it back into place it should be able to move freely, up and down.
Hope this helps you.
May 09, 2011 | Maytag M3DH30B2A Dehumidifier
My unit stopped working after less than 1 year . It will occ start up dor a few secs and then stop again??
The tank may be full. Your dehumidifier has a safety device that turns off the dehumidifier when the water tank is full. Usually the tank itself either presses against a switch or there's a device connected to the tank that triggers a switch when the tank is in place and full.
If you've emptied the tank and the unit doesn't run, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Good luck
Aug 15, 2010 | LG LHD45EL Dehumidifier
My dehumidfier runs for about a min and then stops running
If you've emptied the tank and the unit still stops running after a min, inspect the place where the tank rests to see if there's a switch or mechanism that's not being activated. You may be able to turn it on with a simple flick of your finger.
Take care.
Aug 12, 2010 | Goldstar DH304 Dehumidifier
My dehumidifer kr923317 283w will not come on it just beeps
Good luck.
Aug 12, 2010 | Maytag M7DH65B2A Dehumidifier
My dehumidifyer won't continuously run
HI,
Take care
Aug 11, 2010 | Whirlpool Dehumidifiers
Dehumidifiers Logo
53 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
