Question about Airtemp B6D30E7A Air Conditioner
Broken Switch on Airtemp Airconditioner.
I have an Airtemp Airconditioner in my house. It was installed in the late 80's. The switch is broken. Can I get someone to fix it. Kath
  • 400 Answers
Yes you can.
Posted on Nov 18, 2009
Why does my kenmore ultrasoft 250 keep shutting off
It i s possible he door switch if front loading, has a broken housing. If it works sometimes but then out out of the blue it is very likely the door closed switch plastic housing is broken.
Sep 15, 2014 | Washing Machines
Why doesn't it spin?
Could be few reason such as no power chck out house breaker or fuses ,broken parts,defective door switch or defective componants ,Need multimiter and knowledge of electricity
May 07, 2014 | Hoover VHC391 T-80 Dryer
Switch on Toastmaster stick blender model 1740 is broken.
Superglue a small tab of cut from an aluminum sheet to the the broken plastic tab. Drill a small hole in the aluminum tab to grab the protrusion in switch housing.
Apr 05, 2014 | Toastmaster 2 Speed Stick Mixer
Brake light stays on a hd 2003 fxsts Problem
Usually when the brake light stays on it's because the front brake light switch is broken. You can try loosening the front master cylinder clamp and slide it back against the right handlebar switch housing. If that doesn't extinguish the brake light, the switch is probably broken. You'll have to go inside the right handlebar switch housing to replace the switch. Loosen the adjustment on the throttle and idle cables, remove the two screws that holds the switch housing halves together and separate the halves. Take the cables loose from the throttle sleeve, don't lose the ferrules on the ends of the cables. Lower the lower half of the switch housing and you'll see the switch in the front of it. You'll probably have to desolder the wires, replace the switch, the resolder the wires to the new switch. Make sure you get the throttle assembly back together correctly and that it works properly. Don't pinch any wires when putting the switch housing back together
Good Luck
Steve
Jun 03, 2011 | Harley Davidson FXSTS Springer Softail...
How do you fix a broken stop switch on a 455 rancher
The stop switch is just a red plastic rocker that connects the earth cut out wire from the ignition unit, to a grouding wire to cut the ignition,it can be changed on the machine, however it is much easier to remove the air filter housing, start by removing the screws, two at the top and two at the bottom, disconnect the earth wire and the earth return wire, the upper wire has a spade conection onto the earthing strip, the lower wire also has a spade conection but just pushes into the red ignition rocker switch,unhook the choke from the carb, once the housing is removed gently pry out the blue choke pull from the housing, once removed pry off the broken rocker switch, this is sprung loaded via the earthing strip, pay close attention to how this is fitted, so as you know where to re fit if ( take a photo with a mobile phone to help with re instalation )now fit the new rocker switch, re install the earthing strip, re fit the choke pull, re assemble the air filter housing onto the back of the carb, re connect the wires.
Feb 26, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How to replace horn button switch? I have the horn button wire which doesn't look broken yet it doesn't seem to want to stay in the hole in the steering column that it is suppose to go into to make...
the wire has a housing with a tiny stem that locks the housing in place by twisting it 15 degrees
the switch is the contact inside the horn pad
Jun 05, 2010 | 1993 Chevrolet C/K 2500
Broken sub tank switch in 80 series toyota landcruiser
Replace it. Most switches are mounted to plastic snap clips than can be removed with a simple Flathead screwdriver.A $5 plastic pry tool set is the best, but a butter knife or two works wonders sometimes.
Jan 05, 2010 | 2004 Toyota Land Cruiser
Kenmore Series 80 washer doesn't always spin, only 1/3 of time.
First of all check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely,if it's frozen or stiff,replace it. If the pump belt is broken or looks quite worn, replace it but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Sep 05, 2009 | Kenmore 24902 Top Load Washer
Honeywell manual fan switch broken
The fan limit switch is basically like a thermostat. When the plenum heats up to a certain degree it turns on the fan to start heating your house, and turns off when the fan off when the plenum gets around 80-90 degrees so that you’re not pumping cold air in to house. It also acts as a safety switch if the fan does not come on the plenum will get way to hot so this fan limit will kick the furnace off before that happens. As far as that little white button it should always be on auto you can try to use needle nose pliers to get it back into the auto position, or if you have the broken piece you can try to glue it back on. The white button goes in and out it does not turn or anything just make sure you turn the power off first and if u can’t fix it replace.
Oct 13, 2008 | Honeywell L4064B2236 Fan/Limit Control...
Kenmore 80 series won't spin
If it is draining then the motor is turning the pump so it is ok.
This washer has no belt so that is not the problem.
Remove the cabinet and bypass the lid switch wires and put into a spin. Watch the clutch to see if it is turning. If the clutch housing is not turning and you know for sure the coupler is not broken then you need a new transmission. If the clutch housing is turning but the basket is not spinning you have something binding the basket or you need a new basket drive and clutch.
If you have only looked at the coupler from underneath you may not be able to tell if it is broken in the center. If it is broken again your transmission is not staying in neutral drain until the water is drained. That means it is going into spin with full load of clothes and water. This puts a lot of pressure on the coupler and causes them to fail prematurely. If this is the case you will need a new transmission.
Post back if you have any questions.
Nov 05, 2007 | GE WSM2700D Top Load Stacked Washer /...
Airtemp B6D30E7A Air Conditioner Logo
48 people viewed this question
Top Airtemp Heating & Cooling Experts
Tim Whalen
David White
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
