Question about Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72
Need to know the type of oil that the skilsaw 7 1/4'' mag 77 use
I also need to change the lube in my mag 77. manual says skil part # 8011. You sugessted anti foam gear lube. where do i get it besides a skil dist. grainger? autozone? pep boys? dont use saw frequently but am firm believer in frequent preventative maintainance. im sure skil hoses users on cost.
Posted on Mar 08, 2010
  • 2,176 Answers
Skil recommends using their lube 80111 for an 8 oz tube or 80112 for a pint. however any good quality worm drive lube will work. Don't use a gear lube because the worm drive has additives for anti foaming and gear wear added. Let me know if you need more help
Posted on Jan 24, 2010
What type of oil does the saw require and how much?
Your Skil tool has been properly lubricated and
is ready to use. However it is recommended
that the gears be relubricated only with Skil
lubricants: No. 80111 (8 oz. tube), No. 80112
(pint) or No. 80113 (1/2 gal. can).
Always check the
oil level before
using the saw. To
check and add oil:
Remove plug from
power source and
place the saw's foot on a horizontal surface.
Remove oil plug using the same wrench used
to remove the saw blade. The oil level should
never be below bottom threads in the housing.
When adding oil, fill until oil starts to run out of
oil hole at arrow on housing and replace oil
plug.
part #80111 and is available from http://www.ereplacementparts.com.
Sep 27, 2012 | Skil MAG 77-75 7-1/4-Inch Magnesium Worm...
How do I replace the spring on the retractable blade guard on a model 77 worm drive skilsaw?
Bearings maybe......I'd also check the armature fan and see if it came loose. Either way it doesn't sound cheap!
Aug 07, 2011 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a Skilsaw wormdrive Mag 77 circular and the case on it says Oil is low what oil is best to use?
they make special "wormdrive" oil that is similar to gear lube but i has an additive for foaming. You should be able to go to any repair shop and buy a small bottle of the wormdrive oil. I would not recommend using anything else or you might damage the gears. Let me know if you need help finding the oil and if so give me your general location in the US and I will try and help you further.
Mar 31, 2011 | Saws
How much/what type of oil goes in my old wormdrive saw?
their owners manual doesn't give an exact quantity however they say to unplug the tool first then remove the fill plug and the lower plug and the oil should run out past the first thread. they recommend using their oil 80111 8 oz. tube however any good worm drive lubricant will work, Don't use anything like gear lube because the worm drive lube has an additive for anto foaming. Let me know if you need more assistance
Nov 18, 2009 | Saws
Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Nov 09, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Describe your Skil 7 1/4" Magnesium
You have large plastic screw on the saw, remove it and fill the oil to bottom of threads and that should be it.
Sep 15, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I have a Skilsaw Model 77 Type 16 and I need the power switch
i think skil was taken over by ryobi some time back
Jul 26, 2009 | Saws
Skilsaw motor runs blade won't turn
It sounds like you bought a lemon possibly. I am thinking that the gears are bad. What you can do is remove the blade and unplug the saw. locate where the screws holding the bearing cover are and remove them to get to the gear and check it. Let me know if you need more help
Jun 27, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
I need to know how much oil goes into a skilsaw worm drive resvr.
Haven't heard anything so I checked the Milwaukee worm drive saw and they recomment about 1/2 oz. Make sure you use an oil for a worm drive that is not foaming. Hope this helps. Also when checking oir level have the shoe set for max depth and on a flat surface remove the oil plug, when filling tip the saw on its side and fill, turn back over and allow excess oil to run out if overfilled.
Jan 20, 2009 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Manual for Skil Saw model 77 type 17
I have a Skilsaw model 77 type 16. I have the original owners manual and would be willing to fax you a copy.
The manual only lists a part number for the gear oil, it is No. 249. This is for a 5-3/8 oz tube of gear oil. I checked with my local hardware store which services this saw and they called a factory rep. They told the hardware store with shipping and handling it would cost about $17 for the oil! However they also said that a 90 weight gear oil is close enough to solve the problem.
Hope this helps.
Sep 22, 2008 | Skil 7 1/4" Magnesium "Mag 77" Wormdrive...
Skil 7 1/4" Magnesium "Mag 77" Wormdrive Saw With Twist Lock Model # SHD77M 72 Logo
1,046 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
