Question about LG Washing Machines
LE code appeares on my LG front load washer
L E code appeares on my LG front load washer wm2077cw what can I do to fix
A majority of the time when the LE code appears.. the Hall sensor in the motor is bad. Replacing it. Part # 6501KW2002A from MCM electronics... can help. Good luck.
Posted on Dec 02, 2009
Lg tromm wm2077cw le code
Replace "hall" sensor. Motor sensor is an easy fix and a known problem. Try appliancepartspros.com. They have video to show you how. And part.
Feb 27, 2015 | LG Washing Machines
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
LG Tromm WM2077CW error code LE
No all you have to do is watch how much and what kind of soap you put in that washer...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 15, 2010 | LG WM-2277HW Front Load Washer
LE CODE AND A BURNING SMELL
The LE code represent a failed or locked motor. the replacement of the electrical motor will be needed in this situation.
Jul 19, 2009 | LG WM2077CW XL Front Load Stackable Washer...
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
Le code appears during normal cycle
LG recommends unplugging the washer for 15 - 20
minutes to reset the microprocessor.
The most common cause for the LE error code is over-sudsing in the machine from using regular detergent instead of a high efficiency detergent. The HE detergents are designed for lower suds levels and enhanced cleaning performance in front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. LG recommends loading the washer until the clothes in the drum are no more than three-fourths of the way up the window of the door. This will allow them sufficient room for tumbling.
http://tclaundryrepair.com/
Feb 26, 2009 | LG WM1814CW Front Load Washer
Wm2077cw
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened..........
Use powders for 'front loading machines'. And pl rate me if helped.
Jan 10, 2008 | LG WM-2277HW Front Load Washer
Error code LE
Suggestion: Your wash could be overloaded; put in clothes within machine's capacity. What is written in your manual's max clothes capacity. If your heater is on; switch off machine and wall plug. Reset the machine with the heater on minimum & resume your normal cycle.
May 27, 2007 | LG WM2077CW Laundry XL Front Load...
Washing Machines Logo
522 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
