Question about Pentax Optio M20 Digital Camera
Put 2 new ordinary batteries in the camera and after couple of pictures message comes as battery depleted and shuts down.
advance
  • 107 Answers
SOURCE: S40 Battery problem
Alkaline batteries are not capable of outputting the level of power required for your camera to operate. Your daughter's camera may have lower requirements and be able to function properly using alkaline batteries. Your standard alkaline battery outputs about 700 milliamps of power when they are brand new. A rechargeable NiMH battery can range from 1200 to 2700 or even 3200 milliamps max power output depending on the quality of the battery. Most compact digital cameras that accept AA style batteries are designed for these high-output rechargeables and will not function for very long even on fresh Alkaline batteries. David Millier Advance Camera Repair
Posted on Mar 23, 2007
SOURCE: Depleted Batteries
I had the same problem...
I tried several different types of batteries.
The only one that I found that works is rechargeable batteries.
I am using the ones that came with my Logitech mouse/keboard, so, I just use the mouse to recharge the batteries when needed.
Other rechargeables don't work...
these are :
Ni-MH AA 1400 mAh 1.2 volt
made by L&K
Posted on Nov 23, 2007
SOURCE: battery
i had the same problem all you gotta do is buy duracell rechargable batteries with the duracell charger and u will be able to take more pics!!
Posted on Feb 28, 2009
SOURCE: my pentax m20 optio wont turn on.. it says battery deplete..
This is not solution..lol..It`s just I have same problem..But i buy new battery and after 10 min is again message:battery depleted... ..What I`m gone do???
Posted on Jun 18, 2009
BillB-SA
  • 2761 Answers
SOURCE: "Batteries Depleted"
Your problem may be due to corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, the camera may have a problem that requires professional repair.
If this response helps, please post a rating for me. A rating of "Very Helpful" would be appreciated . .
Posted on Dec 02, 2009
Testimonial: "SORTED,THANKS"
I have the Nikon Coolpix L100 camera and have had it for several months without encountering a single problem. I got a message saying that the batteries were exhausted and it shut down. I replaced the...
I have the same problem with my Coolpix L100. On 27 December 2010 after taking a few shots with flash, using rechargable batteries for one year, it displayed in Hungarian that the batteries are depleted, but after I have recharged them, the camera did not start again anymore, displaying in continue that the batteries are depleted, and it turn off itself after a few seconds. I think that the problem is with the sensor of the camera that should measure the battery status, because even if I had new batteries it desplayed an icon with half battery but I never let it depleted totally so far. Now I am wondering if NIKON will offer free service for it as I have bought it just about 16 months ago in the Romanian DOMO market chain.
Dec 25, 2010 | Nikon COOLPIX L100 Digital Camera
Battery depleted message after i just replaced batteries
hi there,
may i know the exact maker/model of your camera & the brand of battery you use..
`jack
May 24, 2008 | Pentax Optio M20 Digital Camera
Batteries flat after taking 1 photo
Try cleaning the battery contacts inside the camera with a cotton swab lightly dampened with rubbing alcohol.
Dec 18, 2009 | HP Photosmart M417 Digital Camera
Why does my camera say batteries depleted and shuts down when i put new batteries in it
As a workaround, you need to take out the memory card and take our the batteries as well. let it stay out for like 15 minutes and then put everything back. Or you can try using new and fresh batteries.
This commonly happens if you are using alkaline batteries. You need to use a high capacity NiMH rechargeables for better solution.
Sep 29, 2009 | HP Photosmart M517 Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
Camera says batteries are low but batteries are new
Try cleaning the battery contacts in the camera with a pencil eraser. If there is any sign of corrosion on the contacts, take a q-tip, dip it in white vinegar and clean the contacts....
Mar 21, 2009 | Pentax Optio 30 Digital Camera
Camera keeps shutting down
Yes, that's sounds like a main board.
Mar 18, 2009 | HP Photosmart M417 Digital Camera
BATTERY EXHAUSTED
Make sure you have the internal menu for the battery selection correct.
Choosing the wrong battery may cause this.
Rechargeable batteries and alkaline batteries are not the same.
This may also be a condition and problem caused by the camera itself, and may need repair.
Sep 08, 2008 | Nikon COOLPIX L3 Digital Camera
Battery depleted
Sounds like the battery might be defective/worn out. If it's AA batteries (a.k.a. R6) try with a pair of good-quality alkaline batteries to see if it works then. Cheap batteries often doesn't have enogh "umph" to power cameras.
Dec 20, 2007 | HP Photosmart 735 Digital Camera
Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Dec 17, 2007 | HP Photosmart M407 Digital Camera
Pentax Optio M20 Digital Camera Logo
21 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
