Question about Dryers
My whirlpool dryer makes a loud noise and shakes while operating
My whirlpool dryer, model LG441XWWO, makes a loud thumping noise and shakes while it operates. i don't know how to open the dryer to look inside, or what the problem might be.
  • 1 more comment
  • dlewisk45 Nov 18, 2009
    Hi - you mentioned the "right" roller. Does that mean there is a left roller, too? If so, how do you know the right roller is the bad one?
    Sergeant:
    Champion:
  • 289 Answers
You have bad a bad roller.first you nead to remove the lint filter.next you nead to remove the two screw's at lint filter opening.now grage top on both side's and pull forward and up.ther are two 5/16# screw's one obnthe left and one on the right.pull frount panal forward and u[p to remove frount panal.position panal on the right side.reach under drum and release the drum belt.now you can take the drum belt and lift it up and remove the drum.now you see the right roller.ther is a plactic holder that hold's the roller on.remove the holder and remove the roller.replace the roller and the holder.now reinstall everthing.
Posted on Nov 17, 2009
  • Richard Bedwell Nov 18, 2009
    the drum turn's clockwise so the right roller take's most of the abuse.
Whirlpool dryer leq8611lw0 shakes violently and makes loud noise
Something must be inside the blower wheel. I cannot imagine why it would shake like that. This dryer has 4 wheels instead of 2 so it oughta be stable. The only thing to do is get inside the machine and see what is causing it. The dryer with a filter inside is also sometimes known as a series 90 dryer. Look for some series 90 dryer videos on youtube. Like this crappy one I made:
Apr 22, 2014 | Dryers
The dryer works but makes a loud thumping noise model#GLEQ642AS2
All dryers have some type of roller system that supports the drum as it turns. It sounds like one of the rollers or roller bearings has worn and is making that thumping noise. If you have some basic skills and good general mechanical sense you could fix it yourself. Make sure the dryer is unplugged before you attempt anything.
Feb 25, 2011 | Frigidaire Dryers
My whirlpool gas dryer makes a really loud thumping noise while it operates like rocks are in it.
Check the tub rollers and front seal on the tub.
One of the rollers has probably flattened.
Jul 19, 2010 | Whirlpool Dryers
I have a whirlpool model# LE5700XSNO that makes a
One of the drum supports has gone bad. Usually these come as a pair and are not bad to change.
Jan 26, 2010 | Dryers
My dryer is making a very loud thumping noise, what could it be..it also shakes
brum suport springs have broken or come off dont use it till ts fixed you will smash it up?
Oct 24, 2009 | Maytag LSE7806A Top Load Stacked...
New dryer makes a loud thumping full or
I hope he did nt charge you. Because of the seam in a dryer drum, they do make a slight thumping noise but it should not be real loud. I hope the tech took the dryer apart and checked the rollers. One of them may have a flat spot.
I would ask for a factory represent ive to come out and see if they think they would want a dryer in there home that make that much noise.
Please rate solution
Sep 03, 2009 | Dryers
Dryer makes a loud thumping noise when running
A thumping sound in your dryer could be caused by a flat spot on one of the drum support rollers. It can also be caused by a problem with the drum. An idler pulley on for the belt on the drive motor can also make a thumping noise when the dryer is running. Check to see if the cabinet is properly leveled with 4 feet firmly on the floor. Push down on opposing corners to check for play. Adjust the leveling legs if necessary.
Without a model number of your Whirlpool dryer, I am not able to provide much more help. If your dryer has the lint filter that pushes down into the top panel of the dryer, then here are a few tips for accessing the inside of the cabinet:
  • Unplug the dryer to disconnect electrical power.
  • Pull the lint screen out.
  • Remove the screws that secure the top panel to the lint screen housing.
  • Use a putty knife to release the clips on the front of the top panel (about 4" in from each side) that secure it to the dryer frame.
  • Hinge the top panel up and back.
This will provide to access to the inside of the dryer cabinet. Manually spin the drum in a counterclockwise direction and see if you can determine the source of the noise.If you need more help, resubmit your question with additional details and the full model number of your Whirlpool dryer.
Aug 08, 2009 | Whirlpool Dryers
Loud squealing noise from Drum belt looks fine other solutions
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
May 06, 2009 | GE Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Fisher and paykel dryer works but very noisy
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Dryers Logo
191 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
