Question about Palm Tungsten E2 Handheld
How long should the original E2 battery last? It's been a year since I've had it and it now keeps its charge for one day
  • 52 Answers
Its probbly time to get a new battery
Posted on Nov 17, 2009
Finding a new replacement battery for my laptop
The quality of the battery determines the life of the battery.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
Feb 09, 2013 | Affinity Technologies ZT Affinity...
The battery keeps dying and the alarm keeps going off. Alarm switch inside car does nothing to stop it.
Does the battery hold charge? Have you load tested the new battery or left the new battery disconnected for a couple of days to see if it is holding charge.
It does not happen often but the new battery could still be the problem.
The other way to find out what is going on is to remove one or two car fuses inside the dash at the end of each day and if the car battery is not flat the following day you have narrowed down the fault.
Jun 11, 2012 | 1994 Suzuki Sidekick
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Output is only 94 volts after 2 days of charging
Batteries need to be replaced. Some last 5 years while others may only last 2-3 years. Quality is the key to a long lasting battery. Plus when you search for replacements, as long as you stick with what the original physical height, length and width are, you can not go wrong. I found a slightly higher capacity for my 7ah batteries of about 8 or 9ah as I recall and reasonable from an e-Bay store seller.
Jan 23, 2011 | Ultra (ULT31502) UPS System
I charged the Tungsten E and it doesn't show the charge
I didn't solve the problem. I just can't pay right now. I guess I'll keep asking until I get it solved. I purchased a battery last year I just need someone local ( Denver, Co 800014) to put it in for me. I just hope it will work..
thanks for your support
I truly appreciate what you all do.
Gwen
Jan 26, 2010 | Palm Tungsten E2 Handheld
I have a 06' F350 with 27,000 miles and can't keep
you have somewhere short which is draining your batteries.
Jan 07, 2010 | 2006 Ford F 350 Super Duty
Loss of charge on 91 loyale station wagon
the regulator is in the alternator. it sounds like it isn't charging the battery anymore. battery voltage should be around 14 volts with engine running. also check connections at alternator to battery. have seen corrosion here keep the battery from charging
Aug 04, 2008 | 1991 Subaru Loyale
Sansa sandisk mp3 player 1 gig
Theoretically, you should be able to use this one forever, if you keep charging it. The battery isn't replaceable, so hopefully it will last you a good 3 years or more. The #1 threat to Mp3 players isn't the battery, but keeping up with software/computer environment changes. Most mp3 players introduced to date only last 1-2 years - much shorter than everyone had originally thought.
Jun 10, 2008 | SanDisk Sansa Clip MP3 Player
Palm Charging
Synchronize your E2, then work on draining the battery all the way down in order to reduce the effect of battery memory. Memory happens when we repeatedly partially charge a battery. Over time the battery will forget how to keep a full charge, but will remember how to be partially charged. That's usually when users realize there's a problem. The first step is to drain the battery and FULLY charge it at least fully on the battery's indicator, but if you can, let it sit for 24hrs. The second step is to try to use the battery more before charging it and let it charge fully (ie-overnight) before using it when you need to charge it.
Good luck and let me know how you make out.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Palm Tungsten E2 Handheld Logo
57 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
