Question about Miele 23 in. KM490 Electric Cooktop
Miele KM490 Displays e0013 on power on and then powers off after a few seconds.
The control panel displays LOC and the time. oven door opens but unable to reset any controls. is there a way to reset the controls??
Look on the panel for a key that says lock or has a key on it and hold it for10 seconds to see if that clears our
Sep 26, 2014 | General Electric CGS990SETSS GE Cafe 30""...
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
Westinghouse 808 cooktop clicking noises
Sometimes after a power failure the p c board needs re setting. Turn off the power for a few minutes that allows it time to re set. Turn it back on then individually turn on each element for a couple of minutes.
Apr 22, 2014 | Whirlpool Cooktops
Electrical panel does not work
Hey John, this is JK. I understand that the display on your range is not working. You may have a faulty Electronic Oven Control (EOC). Please confirm there is power to the appliance. If there is no power verify that the power cord is properly attached to the unit, plugged into a dedicated outlet correctly, and that the circuit breaker/fuse is not tripped or blown. Also verify the power at the plug is correct. Is the time of day displayed when the clock button is pressed? Are you able to turn the clock OFF or ON? When the display is turned OFF the time of day will re-appear for a few seconds any time the pad is touched. To toggle the display ON or OFF, press and hold the CLOCK button until the control beeps once (about 15 seconds). If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
Apr 07, 2014 | Frigidaire FPGS3085KF Professional 30"...
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
Miele ceramic hob
I would check the incoming power. If you have the proper voltage, then your electronic module is the problem and would need to be replaced, or the hob is dirty where the control panel is and needs to be cleaned because it's not sensing that its being touched.
Feb 05, 2012 | Miele KM5816 25 in. Electric Cooktop
Display blinks and then lights go out
I have the same problem. i've been on the phone with Miele tech support. i'll let you know if i have any luck.
Mar 26, 2008 | Miele 30 in. KM443 Electric Cooktop
Miele 23 in. KM490 Electric Cooktop Logo
141 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
