Try creating a normal CD-R for example just a picture using windows transfer which is simply double clicking your CD drive icon in my computer dragging a picture on to it then burn the files should be on the left, if so then your burner should be fine. I Would suggest using NERO to burn DVD's
You first remove that device from device manager. Then restart the pc. You may check the BIOS menu for that device for any clarification. After restart since u have removed it the OS will detect the device and install it automatically. Hope this helped.
Select {4D36E965-E325-11CE-BFC1-08002BE10318} at the end of the following path: HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318}
In right pane select UpperFilters — do an Edit/Delete
In right pane select LowerFilters — do an Edit/Delete
Exit REGEDIT
Right click MY COMPUTER Properties Hardware Device Manager
Uninstall CD/DVD player/burner
Restart the machine and it will find and reinstall the burner
NOTE: if you’re uncomfortable deleting registry entries, rename them (e.g., w/ “.SAV” extension)
Hi I have Hp pavillion dv6000. When am using yahoo msnger or msn ..the web cam not working. There is one message coming Your web cam is not connected. Please give me a solution for this....
